Just finished a script that allows users to download the entire documentation
from the wiki for offline reading.
All the non-OpenSCAD-related stuff (like wiki menu, wiki warning, etc) are
stripped off.
Here are 2 screenshots:
http://forum.openscad.org/file/n13096/openscad_offliner_screenshot1.png
http://forum.openscad.org/file/n13096/openscad_offliner_screenshot2.png
It has only one file. You can find it in the repo:
https://github.com/runsun/openscad_offliner
Require: python 2.7, BeautifulSoup 4.0 above
Usage:
1) Save this file in folder x.
2) In folder x, type:
python openscad_offliner.py
or to save log to a file:
python openscad_offliner.py > openscad_offliner.log
All web pages will be saved in x/openscad_docs,
and all images in x/openscad_docs/imgs
It will generate 94 pages (1.3 MB) + 102 images (1.4 MB).
$ Runsun Pan, PhD
$ -- OpenScad_DocTest: doc and unit test ( Github , Thingiverse )
View this message in context: http://forum.openscad.org/Use-openscad-offliner-to-download-online-doc-tp13096.html
Looks pretty good.
documentation from the wiki for offline reading.
stripped off.
Usage:
$ http://forum.openscad.org/mailing_list/MailingListOptions.jtp?forum=1 Runsun
Pan, PhD
https://github.com/runsun/openscad_doctest, Thingiverse
https://www.thingiverse.com/thing:410831 )
http://forum.openscad.org/parameterized-models-td8303.html#a8306, here
http://forum.openscad.org/Can-I-get-some-code-review-up-in-here-tp12341p12355.html
2015.04.01.nightly
View this message in context: Use openscad_offliner to download online doc
at Nabble.com.
It is possible to :
This way, the wiki page becomes the only source of doc we need to maintain.
$ Runsun Pan, PhD
View this message in context: http://forum.openscad.org/Use-openscad-offliner-to-download-online-doc-tp13096p13098.html
If this works, and I will check if it does a little later.
If it does, and includes the cheat sheet, then maybe a future version of
openscad could have an optional Environment Variable to point to the
docroot (like file:///blahblah/), or if no env variable found, what it
points to now.
Jerry
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
I
Anonymous
excellent code requires no comments at all!- Ken Thompson
On Tue, Jul 7, 2015 at 11:46 PM, runsun runsun@gmail.com wrote:
It is possible to :
$ Runsun Pan, PhD
The scraped HTML would need quite some additional clean-up
I guess all that is fixable, but I do wonder how much of a moving
target this is chasing as it's trying to handle the output of
another generator which could change with every Wikimedia release.
It might still be a good idea to at least have a look at the
export option and render the original data.
But then if the script is maintained and updated to follow the
changes, that might not be a huge issue.
@Torsten,
Thx for pointing out those issues. I'll get them fixed.
tp3 wrote
Where are index and chapter links ? Maybe because thatI have
css files linked to the web(which should be fixed) so that I don't
see any problem ?
I think before we figure out a better way to solve the burden of
having to maintain several sources of doc, this might serve as
a temporary solution.
$ Runsun Pan, PhD
$ -- OpenScad_DocTest ( Thingiverse ), faces , Offliner
View this message in context: http://forum.openscad.org/Use-openscad-offliner-for-offline-documentation-tp13096p13118.html
Btw, the [edit] => [] is intentional. I figure that there's no point of
editing an offline wiki doc ('cos it needs wiki's editing feature) so I
remove the word "edit".
tp3 wrote
$ Runsun Pan, PhD
View this message in context: http://forum.openscad.org/Use-openscad-offliner-for-offline-documentation-tp13096p13119.html
see any problem ?
I mean the file://document#chapter links. The #chapter part seems
to be missing everywhere (maybe due to the link rewriting?)
Example:
file://.../openscad_docs/OpenSCAD_User_Manual
3.2 Primitive Solids - cube, sphere, cylinder & polyhedron
The "cylinder" link should go to Primitive_Solids#cylinder to
jump directly into that chapter.
Ah, all the remaining [] looked a bit strange. If it's easy, it
would look better if those are removed completely. But that's
just minor cosmetics.
Talking cosmetics... :-) is it possible to add .html to the
files? It seems to work fine without, though.
I agree, it's much better than having different sources and it's
the only working solution to get a usable off-line documentation
right now.
Reading https://en.wikipedia.org/wiki/Wikipedia:Reusing_Wikipedia_content
it looks like the footer should also be extended a bit to clarify
the license. I currently think it's best to use the CC-BY-SA, but
I'll have a look at the GNU-FDL too.
Using CC-BY-SA would mean to also add a license link and a short
info that the content was modified (maybe something like "page
modified for off-line reading" is sufficient?).
All issues are fixed (not update in repo yet), except the license part.
Please let me know what's the best description.
Will do more offline tests to make sure before I push it to the repo.
Also, if this comes to being usable, maybe consider if there's a better way
of using it. No matter how I'll write down clearly development instruction
in case someone wants to modify it.
$ Runsun Pan, PhD
View this message in context: http://forum.openscad.org/Use-openscad-offliner-for-offline-documentation-tp13096p13129.html
Just pushed it to the openscad_offliner repo. It seems working fine with
offline test on Chrome and Firefox.
Here are the fixes to tp3's findings :
it fires of a number of JavaScripts that access the Wikibooks site ==>
ALL javascripts are shutdown
all the CSS files are loaded online ==> All needed CSS files are
downloaded. There is still at least one page (Positioning_an_object)
trying to link to remote css, but it's not harmful ('cos all required css
are already downloaded) and hard to clean out (they seem to be retrieved
by javascript), so I leave them there.
most of the images don't work (at least in Firefox) as they have a
srcset attribute (which I did not even know until just now) ==> all
srcset attributes removed
the index looks strange due to missing SVG files ==> fixed
the chapter links into other pages don't work ==> fixed
the edit links are displayed as [] ==> all [edit] removed
is it possible to add .html to the files? It seems to work fine without,
though. ==> added
$ Runsun Pan, PhD
View this message in context: http://forum.openscad.org/Use-openscad-offliner-for-offline-documentation-tp13096p13131.html
