Fwd: dxf and stl import/rendering issue
Thu, Feb 4, 2016 6:04 PM
Ronaldo said: "Best than just eliminating the top level implicit union
would be to have another operator: the set (or aggregate) operator. The set
operator would collect a set of bodies preserving each one as a separated
entity. If you union the set, then they become one (possibly manifold) body
only but before that the set may not represent a manifold. Its bodies may
not even be disjoint."
We already have a "set (or aggregate)" operator. It is called "group". The
explicit syntax is 'group() { shape1; shape2; ... }'. You can see this
operator if you display the CSG tree. Nobody types it explicitly, because
groups are generated implicitly for every module call (the 'children()' of
a module call is represented by a group, and the output is always a group).
There is a design flaw in how groups currently work. In short, too many
groups are being implicitly generated. If the tail argument to a module
call is a single (non-compound) statement, like a for loop or a module
call, then the results returned by that statement (which may be a group)
are wrapped in another group with a single element. This prevents you from
feeding multiple outputs from one module call into another module as its
children(). This is why intersection_for() exists.
There is a plan to fix this problem, but it is called "lazy union", because
the same feature also eliminates the implicit top level union.
https://github.com/openscad/openscad/issues/350
OpenSCAD2 fixes the problem by adopting so-called "lazy union" semantics
for module calls, and also by reinterpreting the "{ ... }" syntax as the
group constructor. In OpenSCAD2, groups are always constructed explicitly
using {...} syntax, except for at the top level, where all top level
objects are implicitly collected into a group.
Even in OpenSCAD2, there is a requirement that each element of a group be
either another group, or a manifold shape. The CGAL union operator requires
that its arguments be manifold; that's where the restriction comes from.
Doug Moen.
On 4 February 2016 at 11:13, Ronaldo Persiano rcmpersiano@gmail.com wrote:
doug moen brings another important aspect to this discussion: " the top
level implicit union that occurs before exporting an STL file". STL is
intended to represent one object only presumably a 2-manifold and this is
a serious limitation of STL format. I agree that, excluding numerical
approximation issues, STL allows the recovering of the missing topological
information if and only if the geometrical embedding of it is a manifold.
As I showed before by examples, we can represent several non-disjoint
manifolds in STL as far as they do not have common vertices. But that is
very restrictive.
I would like to represent not only one body in OSCAD. I would like to
represent a set of distinct (not necessarily disjoint) objects. One simple
application of that, besides the ones Arholm brought, is an animation of,
say, a ball bouncing in a billiard table. If I define a fixed table and a
ball on it, as their union is not a 2-manifold, I may have problems. Two
gears may have contact. In the real world, objects have contact.
Best than just eliminating the top level implicit union would be to have
another operator: the set (or aggregate) operator. The set operator would
collect a set of bodies preserving each one as a separated entity. If you
union the set, then they become one (possibly manifold) body only but
before that the set may not represent a manifold. Its bodies may not even
be disjoint. May be, I don't know, there is no non-manifold objects in the
world but the world itself is not a manifold.
If we go in that way, STL should be abandoned.
2016-02-04 13:17 GMT-02:00 doug moen doug@moens.org:
"a non-manifold face is a face internal to the body, it has material on
both sides and does not describe the external surface of the solid body."
The ability to partition a solid into a collection of disjoint subvolumes
with shared faces is also useful in OpenSCAD; it's not just a ship
design/ACIS thing.
One obvious example is 3D printing of multi-material/multi-colour
objects. There have been a number of discussions about how to support this
in OpenSCAD. Internally, the volumes for each colour/material need to be
kept separate and labeled. To export such a model, you either need to
export multiple STL files (one per material/colour), or you need to export
an AMF file with distinct volume elements for each colour/material. In no
case should any of the individual volumes that we track internally or
export contain non-manifold faces.
This situation can arise in feature request #1562, which requests a
convex_decomposition() operator. The result of this operator is a group of
solids which share faces between them. Each group element is a convex
polyhedron, which is manifold. This feature isn't useful unless we get rid
of the implicit union that would otherwise occur when passing the results
of convex_decomposition() to another module: see issue #350. But, issue
#350 also eliminates the top level implicit union that occurs before
exporting an STL file. If we get rid of top level implicit union, and the
top level element in a script is a call to convex_decomposition() on
non-convex input, then we can't meaningfully export to STL. There is a
manifoldness check prior to STL export which should report this problem
(issue #1215). Exporting the same object to AMF can be supported, because
we can put each convex polyhedron into a separate volume.
In summary, OpenSCAD should support models that contain disjoint
subvolumes with shared faces. There are features we need to add and
bugs/design flaws we need to fix before this support is complete.
On 4 February 2016 at 02:13, arnholm@arnholm.org wrote:
On 2016-02-04 06:54, Triffid Hunter wrote:
non-manifold means that the topology is somehow ambiguous.
No, it does not.
An example of non-manifold topology is where a topological edge is
shared by more than 2 faces.
http://docs.mcneel.com/rhino/5/help/en-us/popup_moreinformation/non-manifold_edges.htm
It is not ambiguous, and in many cases a desired feature. This kind of
non-manifold topology is much used in ship design when designing FEM models
with shell elements. Often, non-manifold topology is perfectly acceptable
and is not ambiguous in any way. CAD systems like e.g. ACIS (
https://en.wikipedia.org/wiki/ACIS ) have no issues representing
non-manifold topology.
In the special case of 3d solid topological models, a non-manifold face
is a face internal to the body, it has material on both sides and does not
describe the external surface of the solid body. That does not mean it is
topologically ambiguous. Such faces may be and are used for subdivision,
for example to guide 3d solid meshing (solid FEM models). Whether such
non-manifold topological entities are  desirable or not depends on the
application area, but it is not topologically ambiguous.
It is only when the topological description is non-existent things like
this become a problem.
Ronaldo said: "Best than just eliminating the top level implicit union would be to have another operator: the set (or aggregate) operator. The set operator would collect a set of bodies preserving each one as a separated entity. If you union the set, then they become one (possibly manifold) body only but before that the set may not represent a manifold. Its bodies may not even be disjoint." We already have a "set (or aggregate)" operator. It is called "group". The explicit syntax is 'group() { shape1; shape2; ... }'. You can see this operator if you display the CSG tree. Nobody types it explicitly, because groups are generated implicitly for every module call (the 'children()' of a module call is represented by a group, and the output is always a group). There is a design flaw in how groups currently work. In short, too many groups are being implicitly generated. If the tail argument to a module call is a single (non-compound) statement, like a for loop or a module call, then the results returned by that statement (which may be a group) are wrapped in another group with a single element. This prevents you from feeding multiple outputs from one module call into another module as its children(). This is why intersection_for() exists. There is a plan to fix this problem, but it is called "lazy union", because the same feature also eliminates the implicit top level union. https://github.com/openscad/openscad/issues/350 OpenSCAD2 fixes the problem by adopting so-called "lazy union" semantics for module calls, and also by reinterpreting the "{ ... }" syntax as the group constructor. In OpenSCAD2, groups are always constructed explicitly using {...} syntax, except for at the top level, where all top level objects are implicitly collected into a group. Even in OpenSCAD2, there is a requirement that each element of a group be either another group, or a manifold shape. The CGAL union operator requires that its arguments be manifold; that's where the restriction comes from. Doug Moen. On 4 February 2016 at 11:13, Ronaldo Persiano <rcmpersiano@gmail.com> wrote: > doug moen brings another important aspect to this discussion: " the top > level implicit union that occurs before exporting an STL file". STL is > intended to represent one object only presumably a 2-manifold and this is > a serious limitation of STL format. I agree that, excluding numerical > approximation issues, STL allows the recovering of the missing topological > information if and only if the geometrical embedding of it is a manifold. > As I showed before by examples, we can represent several non-disjoint > manifolds in STL as far as they do not have common vertices. But that is > very restrictive. > > I would like to represent not only one body in OSCAD. I would like to > represent a set of distinct (not necessarily disjoint) objects. One simple > application of that, besides the ones Arholm brought, is an animation of, > say, a ball bouncing in a billiard table. If I define a fixed table and a > ball on it, as their union is not a 2-manifold, I may have problems. Two > gears may have contact. In the real world, objects have contact. > > Best than just eliminating the top level implicit union would be to have > another operator: the set (or aggregate) operator. The set operator would > collect a set of bodies preserving each one as a separated entity. If you > union the set, then they become one (possibly manifold) body only but > before that the set may not represent a manifold. Its bodies may not even > be disjoint. May be, I don't know, there is no non-manifold objects in the > world but the world itself is not a manifold. > > If we go in that way, STL should be abandoned. > > 2016-02-04 13:17 GMT-02:00 doug moen <doug@moens.org>: > >> "a non-manifold face is a face internal to the body, it has material on >> both sides and does not describe the external surface of the solid body." >> >> The ability to partition a solid into a collection of disjoint subvolumes >> with shared faces is also useful in OpenSCAD; it's not just a ship >> design/ACIS thing. >> >> One obvious example is 3D printing of multi-material/multi-colour >> objects. There have been a number of discussions about how to support this >> in OpenSCAD. Internally, the volumes for each colour/material need to be >> kept separate and labeled. To export such a model, you either need to >> export multiple STL files (one per material/colour), or you need to export >> an AMF file with distinct volume elements for each colour/material. In no >> case should any of the individual volumes that we track internally or >> export contain non-manifold faces. >> >> This situation can arise in feature request #1562, which requests a >> convex_decomposition() operator. The result of this operator is a group of >> solids which share faces between them. Each group element is a convex >> polyhedron, which is manifold. This feature isn't useful unless we get rid >> of the implicit union that would otherwise occur when passing the results >> of convex_decomposition() to another module: see issue #350. But, issue >> #350 also eliminates the top level implicit union that occurs before >> exporting an STL file. If we get rid of top level implicit union, and the >> top level element in a script is a call to convex_decomposition() on >> non-convex input, then we can't meaningfully export to STL. There is a >> manifoldness check prior to STL export which *should* report this problem >> (issue #1215). Exporting the same object to AMF can be supported, because >> we can put each convex polyhedron into a separate volume. >> >> In summary, OpenSCAD should support models that contain disjoint >> subvolumes with shared faces. There are features we need to add and >> bugs/design flaws we need to fix before this support is complete. >> >> On 4 February 2016 at 02:13, <arnholm@arnholm.org> wrote: >> >>> On 2016-02-04 06:54, Triffid Hunter wrote: >>> >>>> non-manifold means that the topology is somehow ambiguous. >>>> >>> >>> No, it does not. >>> >>> An example of non-manifold topology is where a topological edge is >>> shared by more than 2 faces. >>> >>> http://docs.mcneel.com/rhino/5/help/en-us/popup_moreinformation/non-manifold_edges.htm >>> >>> It is not ambiguous, and in many cases a desired feature. This kind of >>> non-manifold topology is much used in ship design when designing FEM models >>> with shell elements. Often, non-manifold topology is perfectly acceptable >>> and is not ambiguous in any way. CAD systems like e.g. ACIS ( >>> https://en.wikipedia.org/wiki/ACIS ) have no issues representing >>> non-manifold topology. >>> >>> In the special case of 3d solid topological models, a non-manifold face >>> is a face internal to the body, it has material on both sides and does not >>> describe the external surface of the solid body. That does not mean it is >>> topologically ambiguous. Such faces may be and are used for subdivision, >>> for example to guide 3d solid meshing (solid FEM models). Whether such >>> non-manifold topological entities are desirable or not depends on the >>> application area, but it is not topologically ambiguous. >>> >>> It is only when the topological description is non-existent things like >>> this become a problem. >>> >>> >>> Carsten Arnholm >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Thu, Feb 4, 2016 6:38 PM
I have used group() explicitly to make a bunch of children into a first
child.
Doug Moen.
is a serious limitation of STL format. I agree that, excluding numerical
very restrictive.
subvolumes with shared faces is also useful in OpenSCAD; it's not just a
ship design/ACIS thing.
No, it does not.
I have used group() explicitly to make a bunch of children into a first child. On 4 February 2016 at 18:04, doug moen <doug@moens.org> wrote: > Ronaldo said: "Best than just eliminating the top level implicit union > would be to have another operator: the set (or aggregate) operator. The set > operator would collect a set of bodies preserving each one as a separated > entity. If you union the set, then they become one (possibly manifold) body > only but before that the set may not represent a manifold. Its bodies may > not even be disjoint." > > We already have a "set (or aggregate)" operator. It is called "group". The > explicit syntax is 'group() { shape1; shape2; ... }'. You can see this > operator if you display the CSG tree. Nobody types it explicitly, because > groups are generated implicitly for every module call (the 'children()' of > a module call is represented by a group, and the output is always a group). > > There is a design flaw in how groups currently work. In short, too many > groups are being implicitly generated. If the tail argument to a module > call is a single (non-compound) statement, like a for loop or a module > call, then the results returned by that statement (which may be a group) > are wrapped in another group with a single element. This prevents you from > feeding multiple outputs from one module call into another module as its > children(). This is why intersection_for() exists. > > There is a plan to fix this problem, but it is called "lazy union", > because the same feature also eliminates the implicit top level union. > https://github.com/openscad/openscad/issues/350 > > OpenSCAD2 fixes the problem by adopting so-called "lazy union" semantics > for module calls, and also by reinterpreting the "{ ... }" syntax as the > group constructor. In OpenSCAD2, groups are always constructed explicitly > using {...} syntax, except for at the top level, where all top level > objects are implicitly collected into a group. > > Even in OpenSCAD2, there is a requirement that each element of a group be > either another group, or a manifold shape. The CGAL union operator requires > that its arguments be manifold; that's where the restriction comes from. > > Doug Moen. > > On 4 February 2016 at 11:13, Ronaldo Persiano <rcmpersiano@gmail.com> > wrote: > >> doug moen brings another important aspect to this discussion: " the top >> level implicit union that occurs before exporting an STL file". STL is >> intended to represent one object only presumably a 2-manifold and this >> is a serious limitation of STL format. I agree that, excluding numerical >> approximation issues, STL allows the recovering of the missing topological >> information if and only if the geometrical embedding of it is a manifold. >> As I showed before by examples, we can represent several non-disjoint >> manifolds in STL as far as they do not have common vertices. But that is >> very restrictive. >> >> I would like to represent not only one body in OSCAD. I would like to >> represent a set of distinct (not necessarily disjoint) objects. One simple >> application of that, besides the ones Arholm brought, is an animation of, >> say, a ball bouncing in a billiard table. If I define a fixed table and a >> ball on it, as their union is not a 2-manifold, I may have problems. Two >> gears may have contact. In the real world, objects have contact. >> >> Best than just eliminating the top level implicit union would be to have >> another operator: the set (or aggregate) operator. The set operator would >> collect a set of bodies preserving each one as a separated entity. If you >> union the set, then they become one (possibly manifold) body only but >> before that the set may not represent a manifold. Its bodies may not even >> be disjoint. May be, I don't know, there is no non-manifold objects in the >> world but the world itself is not a manifold. >> >> If we go in that way, STL should be abandoned. >> >> 2016-02-04 13:17 GMT-02:00 doug moen <doug@moens.org>: >> >>> "a non-manifold face is a face internal to the body, it has material on >>> both sides and does not describe the external surface of the solid body." >>> >>> The ability to partition a solid into a collection of disjoint >>> subvolumes with shared faces is also useful in OpenSCAD; it's not just a >>> ship design/ACIS thing. >>> >>> One obvious example is 3D printing of multi-material/multi-colour >>> objects. There have been a number of discussions about how to support this >>> in OpenSCAD. Internally, the volumes for each colour/material need to be >>> kept separate and labeled. To export such a model, you either need to >>> export multiple STL files (one per material/colour), or you need to export >>> an AMF file with distinct volume elements for each colour/material. In no >>> case should any of the individual volumes that we track internally or >>> export contain non-manifold faces. >>> >>> This situation can arise in feature request #1562, which requests a >>> convex_decomposition() operator. The result of this operator is a group of >>> solids which share faces between them. Each group element is a convex >>> polyhedron, which is manifold. This feature isn't useful unless we get rid >>> of the implicit union that would otherwise occur when passing the results >>> of convex_decomposition() to another module: see issue #350. But, issue >>> #350 also eliminates the top level implicit union that occurs before >>> exporting an STL file. If we get rid of top level implicit union, and the >>> top level element in a script is a call to convex_decomposition() on >>> non-convex input, then we can't meaningfully export to STL. There is a >>> manifoldness check prior to STL export which *should* report this problem >>> (issue #1215). Exporting the same object to AMF can be supported, because >>> we can put each convex polyhedron into a separate volume. >>> >>> In summary, OpenSCAD should support models that contain disjoint >>> subvolumes with shared faces. There are features we need to add and >>> bugs/design flaws we need to fix before this support is complete. >>> >>> On 4 February 2016 at 02:13, <arnholm@arnholm.org> wrote: >>> >>>> On 2016-02-04 06:54, Triffid Hunter wrote: >>>> >>>>> non-manifold means that the topology is somehow ambiguous. >>>>> >>>> >>>> No, it does not. >>>> >>>> An example of non-manifold topology is where a topological edge is >>>> shared by more than 2 faces. >>>> >>>> http://docs.mcneel.com/rhino/5/help/en-us/popup_moreinformation/non-manifold_edges.htm >>>> >>>> It is not ambiguous, and in many cases a desired feature. This kind of >>>> non-manifold topology is much used in ship design when designing FEM models >>>> with shell elements. Often, non-manifold topology is perfectly acceptable >>>> and is not ambiguous in any way. CAD systems like e.g. ACIS ( >>>> https://en.wikipedia.org/wiki/ACIS ) have no issues representing >>>> non-manifold topology. >>>> >>>> In the special case of 3d solid topological models, a non-manifold face >>>> is a face internal to the body, it has material on both sides and does not >>>> describe the external surface of the solid body. That does not mean it is >>>> topologically ambiguous. Such faces may be and are used for subdivision, >>>> for example to guide 3d solid meshing (solid FEM models). Whether such >>>> non-manifold topological entities are desirable or not depends on the >>>> application area, but it is not topologically ambiguous. >>>> >>>> It is only when the topological description is non-existent things like >>>> this become a problem. >>>> >>>> >>>> Carsten Arnholm >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>>> >>>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Thu, Feb 4, 2016 6:49 PM
Okay, cool. That probably means we should document the group() operator.
And you had to do that because {...} standing alone (not as a module
argument) doesn't create a group. This is unfortunately another
incompatibility with OpenSCAD2.
Doug.
child.
Doug Moen.
numerical approximation issues, STL allows the recovering of the missing
topological information if and only if the geometrical embedding of it is a
manifold. As I showed before by examples, we can represent several
non-disjoint manifolds in STL as far as they do not have common vertices.
But that is very restrictive.
javascript:_e(%7B%7D,'cvml','doug@moens.org');>:
on both sides and does not describe the external surface of the solid body."
No, it does not.
face is a face internal to the body, it has material on both sides and does
not describe the external surface of the solid body. That does not mean it
is topologically ambiguous. Such faces may be and are used for subdivision,
like this become a problem.
javascript:_e(%7B%7D,'cvml','Discuss@lists.openscad.org');
Okay, cool. That probably means we should document the group() operator. And you had to do that because {...} standing alone (not as a module argument) doesn't create a group. This is unfortunately another incompatibility with OpenSCAD2. Doug. On Thursday, 4 February 2016, nop head <nop.head@gmail.com> wrote: > I have used group() explicitly to make a bunch of children into a first > child. > > On 4 February 2016 at 18:04, doug moen <doug@moens.org > <javascript:_e(%7B%7D,'cvml','doug@moens.org');>> wrote: > >> Ronaldo said: "Best than just eliminating the top level implicit union >> would be to have another operator: the set (or aggregate) operator. The set >> operator would collect a set of bodies preserving each one as a separated >> entity. If you union the set, then they become one (possibly manifold) body >> only but before that the set may not represent a manifold. Its bodies may >> not even be disjoint." >> >> We already have a "set (or aggregate)" operator. It is called "group". >> The explicit syntax is 'group() { shape1; shape2; ... }'. You can see this >> operator if you display the CSG tree. Nobody types it explicitly, because >> groups are generated implicitly for every module call (the 'children()' of >> a module call is represented by a group, and the output is always a group). >> >> There is a design flaw in how groups currently work. In short, too many >> groups are being implicitly generated. If the tail argument to a module >> call is a single (non-compound) statement, like a for loop or a module >> call, then the results returned by that statement (which may be a group) >> are wrapped in another group with a single element. This prevents you from >> feeding multiple outputs from one module call into another module as its >> children(). This is why intersection_for() exists. >> >> There is a plan to fix this problem, but it is called "lazy union", >> because the same feature also eliminates the implicit top level union. >> https://github.com/openscad/openscad/issues/350 >> >> OpenSCAD2 fixes the problem by adopting so-called "lazy union" semantics >> for module calls, and also by reinterpreting the "{ ... }" syntax as the >> group constructor. In OpenSCAD2, groups are always constructed explicitly >> using {...} syntax, except for at the top level, where all top level >> objects are implicitly collected into a group. >> >> Even in OpenSCAD2, there is a requirement that each element of a group be >> either another group, or a manifold shape. The CGAL union operator requires >> that its arguments be manifold; that's where the restriction comes from. >> >> Doug Moen. >> >> On 4 February 2016 at 11:13, Ronaldo Persiano <rcmpersiano@gmail.com >> <javascript:_e(%7B%7D,'cvml','rcmpersiano@gmail.com');>> wrote: >> >>> doug moen brings another important aspect to this discussion: " the top >>> level implicit union that occurs before exporting an STL file". STL is >>> intended to represent one object only presumably a 2-manifold and this >>> is a serious limitation of STL format. I agree that, excluding >>> numerical approximation issues, STL allows the recovering of the missing >>> topological information if and only if the geometrical embedding of it is a >>> manifold. As I showed before by examples, we can represent several >>> non-disjoint manifolds in STL as far as they do not have common vertices. >>> But that is very restrictive. >>> >>> I would like to represent not only one body in OSCAD. I would like to >>> represent a set of distinct (not necessarily disjoint) objects. One simple >>> application of that, besides the ones Arholm brought, is an animation of, >>> say, a ball bouncing in a billiard table. If I define a fixed table and a >>> ball on it, as their union is not a 2-manifold, I may have problems. Two >>> gears may have contact. In the real world, objects have contact. >>> >>> Best than just eliminating the top level implicit union would be to >>> have another operator: the set (or aggregate) operator. The set operator >>> would collect a set of bodies preserving each one as a separated entity. If >>> you union the set, then they become one (possibly manifold) body only but >>> before that the set may not represent a manifold. Its bodies may not even >>> be disjoint. May be, I don't know, there is no non-manifold objects in the >>> world but the world itself is not a manifold. >>> >>> If we go in that way, STL should be abandoned. >>> >>> 2016-02-04 13:17 GMT-02:00 doug moen <doug@moens.org >>> <javascript:_e(%7B%7D,'cvml','doug@moens.org');>>: >>> >>>> "a non-manifold face is a face internal to the body, it has material >>>> on both sides and does not describe the external surface of the solid body." >>>> >>>> The ability to partition a solid into a collection of disjoint >>>> subvolumes with shared faces is also useful in OpenSCAD; it's not just a >>>> ship design/ACIS thing. >>>> >>>> One obvious example is 3D printing of multi-material/multi-colour >>>> objects. There have been a number of discussions about how to support this >>>> in OpenSCAD. Internally, the volumes for each colour/material need to be >>>> kept separate and labeled. To export such a model, you either need to >>>> export multiple STL files (one per material/colour), or you need to export >>>> an AMF file with distinct volume elements for each colour/material. In no >>>> case should any of the individual volumes that we track internally or >>>> export contain non-manifold faces. >>>> >>>> This situation can arise in feature request #1562, which requests a >>>> convex_decomposition() operator. The result of this operator is a group of >>>> solids which share faces between them. Each group element is a convex >>>> polyhedron, which is manifold. This feature isn't useful unless we get rid >>>> of the implicit union that would otherwise occur when passing the results >>>> of convex_decomposition() to another module: see issue #350. But, issue >>>> #350 also eliminates the top level implicit union that occurs before >>>> exporting an STL file. If we get rid of top level implicit union, and the >>>> top level element in a script is a call to convex_decomposition() on >>>> non-convex input, then we can't meaningfully export to STL. There is a >>>> manifoldness check prior to STL export which *should* report this problem >>>> (issue #1215). Exporting the same object to AMF can be supported, because >>>> we can put each convex polyhedron into a separate volume. >>>> >>>> In summary, OpenSCAD should support models that contain disjoint >>>> subvolumes with shared faces. There are features we need to add and >>>> bugs/design flaws we need to fix before this support is complete. >>>> >>>> On 4 February 2016 at 02:13, <arnholm@arnholm.org >>>> <javascript:_e(%7B%7D,'cvml','arnholm@arnholm.org');>> wrote: >>>> >>>>> On 2016-02-04 06:54, Triffid Hunter wrote: >>>>> >>>>>> non-manifold means that the topology is somehow ambiguous. >>>>>> >>>>> >>>>> No, it does not. >>>>> >>>>> An example of non-manifold topology is where a topological edge is >>>>> shared by more than 2 faces. >>>>> >>>>> http://docs.mcneel.com/rhino/5/help/en-us/popup_moreinformation/non-manifold_edges.htm >>>>> >>>>> It is not ambiguous, and in many cases a desired feature. This kind of >>>>> non-manifold topology is much used in ship design when designing FEM models >>>>> with shell elements. Often, non-manifold topology is perfectly acceptable >>>>> and is not ambiguous in any way. CAD systems like e.g. ACIS ( >>>>> https://en.wikipedia.org/wiki/ACIS ) have no issues representing >>>>> non-manifold topology. >>>>> >>>>> In the special case of 3d solid topological models, a non-manifold >>>>> face is a face internal to the body, it has material on both sides and does >>>>> not describe the external surface of the solid body. That does not mean it >>>>> is topologically ambiguous. Such faces may be and are used for subdivision, >>>>> for example to guide 3d solid meshing (solid FEM models). Whether such >>>>> non-manifold topological entities are desirable or not depends on the >>>>> application area, but it is not topologically ambiguous. >>>>> >>>>> It is only when the topological description is non-existent things >>>>> like this become a problem. >>>>> >>>>> >>>>> Carsten Arnholm >>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> <javascript:_e(%7B%7D,'cvml','Discuss@lists.openscad.org');> >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>>> >>>>> >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> <javascript:_e(%7B%7D,'cvml','Discuss@lists.openscad.org');> >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> <javascript:_e(%7B%7D,'cvml','Discuss@lists.openscad.org');> >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> <javascript:_e(%7B%7D,'cvml','Discuss@lists.openscad.org');> >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> >
Thu, Feb 4, 2016 7:00 PM
Yes but if {...} made a group, how would you pass multiple children as
separate children?
Doug.
child.
from.
Doug Moen.
top level implicit union that occurs before exporting an STL file". STL is
No, it does not.
of non-manifold topology is much used in ship design when designing FEM
models with shell elements. Often, non-manifold topology is perfectly
acceptable and is not ambiguous in any way. CAD systems like e.g. ACIS (
Yes but if {...} made a group, how would you pass multiple children as separate children? On 4 February 2016 at 18:49, doug moen <doug@moens.org> wrote: > Okay, cool. That probably means we should document the group() operator. > > And you had to do that because {...} standing alone (not as a module > argument) doesn't create a group. This is unfortunately another > incompatibility with OpenSCAD2. > > Doug. > > > On Thursday, 4 February 2016, nop head <nop.head@gmail.com> wrote: > >> I have used group() explicitly to make a bunch of children into a first >> child. >> >> On 4 February 2016 at 18:04, doug moen <doug@moens.org> wrote: >> >>> Ronaldo said: "Best than just eliminating the top level implicit union >>> would be to have another operator: the set (or aggregate) operator. The set >>> operator would collect a set of bodies preserving each one as a separated >>> entity. If you union the set, then they become one (possibly manifold) body >>> only but before that the set may not represent a manifold. Its bodies may >>> not even be disjoint." >>> >>> We already have a "set (or aggregate)" operator. It is called "group". >>> The explicit syntax is 'group() { shape1; shape2; ... }'. You can see this >>> operator if you display the CSG tree. Nobody types it explicitly, because >>> groups are generated implicitly for every module call (the 'children()' of >>> a module call is represented by a group, and the output is always a group). >>> >>> There is a design flaw in how groups currently work. In short, too many >>> groups are being implicitly generated. If the tail argument to a module >>> call is a single (non-compound) statement, like a for loop or a module >>> call, then the results returned by that statement (which may be a group) >>> are wrapped in another group with a single element. This prevents you from >>> feeding multiple outputs from one module call into another module as its >>> children(). This is why intersection_for() exists. >>> >>> There is a plan to fix this problem, but it is called "lazy union", >>> because the same feature also eliminates the implicit top level union. >>> https://github.com/openscad/openscad/issues/350 >>> >>> OpenSCAD2 fixes the problem by adopting so-called "lazy union" semantics >>> for module calls, and also by reinterpreting the "{ ... }" syntax as the >>> group constructor. In OpenSCAD2, groups are always constructed explicitly >>> using {...} syntax, except for at the top level, where all top level >>> objects are implicitly collected into a group. >>> >>> Even in OpenSCAD2, there is a requirement that each element of a group >>> be either another group, or a manifold shape. The CGAL union operator >>> requires that its arguments be manifold; that's where the restriction comes >>> from. >>> >>> Doug Moen. >>> >>> On 4 February 2016 at 11:13, Ronaldo Persiano <rcmpersiano@gmail.com> >>> wrote: >>> >>>> doug moen brings another important aspect to this discussion: " the >>>> top level implicit union that occurs before exporting an STL file". STL is >>>> intended to represent one object only presumably a 2-manifold and this >>>> is a serious limitation of STL format. I agree that, excluding >>>> numerical approximation issues, STL allows the recovering of the missing >>>> topological information if and only if the geometrical embedding of it is a >>>> manifold. As I showed before by examples, we can represent several >>>> non-disjoint manifolds in STL as far as they do not have common vertices. >>>> But that is very restrictive. >>>> >>>> I would like to represent not only one body in OSCAD. I would like to >>>> represent a set of distinct (not necessarily disjoint) objects. One simple >>>> application of that, besides the ones Arholm brought, is an animation of, >>>> say, a ball bouncing in a billiard table. If I define a fixed table and a >>>> ball on it, as their union is not a 2-manifold, I may have problems. Two >>>> gears may have contact. In the real world, objects have contact. >>>> >>>> Best than just eliminating the top level implicit union would be to >>>> have another operator: the set (or aggregate) operator. The set operator >>>> would collect a set of bodies preserving each one as a separated entity. If >>>> you union the set, then they become one (possibly manifold) body only but >>>> before that the set may not represent a manifold. Its bodies may not even >>>> be disjoint. May be, I don't know, there is no non-manifold objects in the >>>> world but the world itself is not a manifold. >>>> >>>> If we go in that way, STL should be abandoned. >>>> >>>> 2016-02-04 13:17 GMT-02:00 doug moen <doug@moens.org>: >>>> >>>>> "a non-manifold face is a face internal to the body, it has material >>>>> on both sides and does not describe the external surface of the solid body." >>>>> >>>>> The ability to partition a solid into a collection of disjoint >>>>> subvolumes with shared faces is also useful in OpenSCAD; it's not just a >>>>> ship design/ACIS thing. >>>>> >>>>> One obvious example is 3D printing of multi-material/multi-colour >>>>> objects. There have been a number of discussions about how to support this >>>>> in OpenSCAD. Internally, the volumes for each colour/material need to be >>>>> kept separate and labeled. To export such a model, you either need to >>>>> export multiple STL files (one per material/colour), or you need to export >>>>> an AMF file with distinct volume elements for each colour/material. In no >>>>> case should any of the individual volumes that we track internally or >>>>> export contain non-manifold faces. >>>>> >>>>> This situation can arise in feature request #1562, which requests a >>>>> convex_decomposition() operator. The result of this operator is a group of >>>>> solids which share faces between them. Each group element is a convex >>>>> polyhedron, which is manifold. This feature isn't useful unless we get rid >>>>> of the implicit union that would otherwise occur when passing the results >>>>> of convex_decomposition() to another module: see issue #350. But, issue >>>>> #350 also eliminates the top level implicit union that occurs before >>>>> exporting an STL file. If we get rid of top level implicit union, and the >>>>> top level element in a script is a call to convex_decomposition() on >>>>> non-convex input, then we can't meaningfully export to STL. There is a >>>>> manifoldness check prior to STL export which *should* report this problem >>>>> (issue #1215). Exporting the same object to AMF can be supported, because >>>>> we can put each convex polyhedron into a separate volume. >>>>> >>>>> In summary, OpenSCAD should support models that contain disjoint >>>>> subvolumes with shared faces. There are features we need to add and >>>>> bugs/design flaws we need to fix before this support is complete. >>>>> >>>>> On 4 February 2016 at 02:13, <arnholm@arnholm.org> wrote: >>>>> >>>>>> On 2016-02-04 06:54, Triffid Hunter wrote: >>>>>> >>>>>>> non-manifold means that the topology is somehow ambiguous. >>>>>>> >>>>>> >>>>>> No, it does not. >>>>>> >>>>>> An example of non-manifold topology is where a topological edge is >>>>>> shared by more than 2 faces. >>>>>> >>>>>> http://docs.mcneel.com/rhino/5/help/en-us/popup_moreinformation/non-manifold_edges.htm >>>>>> >>>>>> It is not ambiguous, and in many cases a desired feature. This kind >>>>>> of non-manifold topology is much used in ship design when designing FEM >>>>>> models with shell elements. Often, non-manifold topology is perfectly >>>>>> acceptable and is not ambiguous in any way. CAD systems like e.g. ACIS ( >>>>>> https://en.wikipedia.org/wiki/ACIS ) have no issues representing >>>>>> non-manifold topology. >>>>>> >>>>>> In the special case of 3d solid topological models, a non-manifold >>>>>> face is a face internal to the body, it has material on both sides and does >>>>>> not describe the external surface of the solid body. That does not mean it >>>>>> is topologically ambiguous. Such faces may be and are used for subdivision, >>>>>> for example to guide 3d solid meshing (solid FEM models). Whether such >>>>>> non-manifold topological entities are desirable or not depends on the >>>>>> application area, but it is not topologically ambiguous. >>>>>> >>>>>> It is only when the topological description is non-existent things >>>>>> like this become a problem. >>>>>> >>>>>> >>>>>> Carsten Arnholm >>>>>> >>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> Discuss@lists.openscad.org >>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>> >>>>>> >>>>>> >>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>>> >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Thu, Feb 4, 2016 7:02 PM
Or do you mean that children are module arguments?
separate children?
Doug.
child.
from.
Doug Moen.
No, it does not.
Or do you mean that children are module arguments? On 4 February 2016 at 19:00, nop head <nop.head@gmail.com> wrote: > Yes but if {...} made a group, how would you pass multiple children as > separate children? > > On 4 February 2016 at 18:49, doug moen <doug@moens.org> wrote: > >> Okay, cool. That probably means we should document the group() operator. >> >> And you had to do that because {...} standing alone (not as a module >> argument) doesn't create a group. This is unfortunately another >> incompatibility with OpenSCAD2. >> >> Doug. >> >> >> On Thursday, 4 February 2016, nop head <nop.head@gmail.com> wrote: >> >>> I have used group() explicitly to make a bunch of children into a first >>> child. >>> >>> On 4 February 2016 at 18:04, doug moen <doug@moens.org> wrote: >>> >>>> Ronaldo said: "Best than just eliminating the top level implicit union >>>> would be to have another operator: the set (or aggregate) operator. The set >>>> operator would collect a set of bodies preserving each one as a separated >>>> entity. If you union the set, then they become one (possibly manifold) body >>>> only but before that the set may not represent a manifold. Its bodies may >>>> not even be disjoint." >>>> >>>> We already have a "set (or aggregate)" operator. It is called "group". >>>> The explicit syntax is 'group() { shape1; shape2; ... }'. You can see this >>>> operator if you display the CSG tree. Nobody types it explicitly, because >>>> groups are generated implicitly for every module call (the 'children()' of >>>> a module call is represented by a group, and the output is always a group). >>>> >>>> There is a design flaw in how groups currently work. In short, too many >>>> groups are being implicitly generated. If the tail argument to a module >>>> call is a single (non-compound) statement, like a for loop or a module >>>> call, then the results returned by that statement (which may be a group) >>>> are wrapped in another group with a single element. This prevents you from >>>> feeding multiple outputs from one module call into another module as its >>>> children(). This is why intersection_for() exists. >>>> >>>> There is a plan to fix this problem, but it is called "lazy union", >>>> because the same feature also eliminates the implicit top level union. >>>> https://github.com/openscad/openscad/issues/350 >>>> >>>> OpenSCAD2 fixes the problem by adopting so-called "lazy union" >>>> semantics for module calls, and also by reinterpreting the "{ ... }" syntax >>>> as the group constructor. In OpenSCAD2, groups are always constructed >>>> explicitly using {...} syntax, except for at the top level, where all top >>>> level objects are implicitly collected into a group. >>>> >>>> Even in OpenSCAD2, there is a requirement that each element of a group >>>> be either another group, or a manifold shape. The CGAL union operator >>>> requires that its arguments be manifold; that's where the restriction comes >>>> from. >>>> >>>> Doug Moen. >>>> >>>> On 4 February 2016 at 11:13, Ronaldo Persiano <rcmpersiano@gmail.com> >>>> wrote: >>>> >>>>> doug moen brings another important aspect to this discussion: " the >>>>> top level implicit union that occurs before exporting an STL file". STL is >>>>> intended to represent one object only presumably a 2-manifold and this >>>>> is a serious limitation of STL format. I agree that, excluding >>>>> numerical approximation issues, STL allows the recovering of the missing >>>>> topological information if and only if the geometrical embedding of it is a >>>>> manifold. As I showed before by examples, we can represent several >>>>> non-disjoint manifolds in STL as far as they do not have common vertices. >>>>> But that is very restrictive. >>>>> >>>>> I would like to represent not only one body in OSCAD. I would like to >>>>> represent a set of distinct (not necessarily disjoint) objects. One simple >>>>> application of that, besides the ones Arholm brought, is an animation of, >>>>> say, a ball bouncing in a billiard table. If I define a fixed table and a >>>>> ball on it, as their union is not a 2-manifold, I may have problems. Two >>>>> gears may have contact. In the real world, objects have contact. >>>>> >>>>> Best than just eliminating the top level implicit union would be to >>>>> have another operator: the set (or aggregate) operator. The set operator >>>>> would collect a set of bodies preserving each one as a separated entity. If >>>>> you union the set, then they become one (possibly manifold) body only but >>>>> before that the set may not represent a manifold. Its bodies may not even >>>>> be disjoint. May be, I don't know, there is no non-manifold objects in the >>>>> world but the world itself is not a manifold. >>>>> >>>>> If we go in that way, STL should be abandoned. >>>>> >>>>> 2016-02-04 13:17 GMT-02:00 doug moen <doug@moens.org>: >>>>> >>>>>> "a non-manifold face is a face internal to the body, it has material >>>>>> on both sides and does not describe the external surface of the solid body." >>>>>> >>>>>> The ability to partition a solid into a collection of disjoint >>>>>> subvolumes with shared faces is also useful in OpenSCAD; it's not just a >>>>>> ship design/ACIS thing. >>>>>> >>>>>> One obvious example is 3D printing of multi-material/multi-colour >>>>>> objects. There have been a number of discussions about how to support this >>>>>> in OpenSCAD. Internally, the volumes for each colour/material need to be >>>>>> kept separate and labeled. To export such a model, you either need to >>>>>> export multiple STL files (one per material/colour), or you need to export >>>>>> an AMF file with distinct volume elements for each colour/material. In no >>>>>> case should any of the individual volumes that we track internally or >>>>>> export contain non-manifold faces. >>>>>> >>>>>> This situation can arise in feature request #1562, which requests a >>>>>> convex_decomposition() operator. The result of this operator is a group of >>>>>> solids which share faces between them. Each group element is a convex >>>>>> polyhedron, which is manifold. This feature isn't useful unless we get rid >>>>>> of the implicit union that would otherwise occur when passing the results >>>>>> of convex_decomposition() to another module: see issue #350. But, issue >>>>>> #350 also eliminates the top level implicit union that occurs before >>>>>> exporting an STL file. If we get rid of top level implicit union, and the >>>>>> top level element in a script is a call to convex_decomposition() on >>>>>> non-convex input, then we can't meaningfully export to STL. There is a >>>>>> manifoldness check prior to STL export which *should* report this problem >>>>>> (issue #1215). Exporting the same object to AMF can be supported, because >>>>>> we can put each convex polyhedron into a separate volume. >>>>>> >>>>>> In summary, OpenSCAD should support models that contain disjoint >>>>>> subvolumes with shared faces. There are features we need to add and >>>>>> bugs/design flaws we need to fix before this support is complete. >>>>>> >>>>>> On 4 February 2016 at 02:13, <arnholm@arnholm.org> wrote: >>>>>> >>>>>>> On 2016-02-04 06:54, Triffid Hunter wrote: >>>>>>> >>>>>>>> non-manifold means that the topology is somehow ambiguous. >>>>>>>> >>>>>>> >>>>>>> No, it does not. >>>>>>> >>>>>>> An example of non-manifold topology is where a topological edge is >>>>>>> shared by more than 2 faces. >>>>>>> >>>>>>> http://docs.mcneel.com/rhino/5/help/en-us/popup_moreinformation/non-manifold_edges.htm >>>>>>> >>>>>>> It is not ambiguous, and in many cases a desired feature. This kind >>>>>>> of non-manifold topology is much used in ship design when designing FEM >>>>>>> models with shell elements. Often, non-manifold topology is perfectly >>>>>>> acceptable and is not ambiguous in any way. CAD systems like e.g. ACIS ( >>>>>>> https://en.wikipedia.org/wiki/ACIS ) have no issues representing >>>>>>> non-manifold topology. >>>>>>> >>>>>>> In the special case of 3d solid topological models, a non-manifold >>>>>>> face is a face internal to the body, it has material on both sides and does >>>>>>> not describe the external surface of the solid body. That does not mean it >>>>>>> is topologically ambiguous. Such faces may be and are used for subdivision, >>>>>>> for example to guide 3d solid meshing (solid FEM models). Whether such >>>>>>> non-manifold topological entities are desirable or not depends on the >>>>>>> application area, but it is not topologically ambiguous. >>>>>>> >>>>>>> It is only when the topological description is non-existent things >>>>>>> like this become a problem. >>>>>>> >>>>>>> >>>>>>> Carsten Arnholm >>>>>>> >>>>>>> _______________________________________________ >>>>>>> OpenSCAD mailing list >>>>>>> Discuss@lists.openscad.org >>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>> >>>>>>> >>>>>>> >>>>>> >>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> Discuss@lists.openscad.org >>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>> >>>>>> >>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>>> >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>>> >>> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> >
Thu, Feb 4, 2016 8:21 PM
Consider this code:
module m()
cube(10,center=true);
sphere(6,center=true);
m() returns a group containing two children, a cube and a sphere. The use
of '{...}' is necessary here to construct a group containing more than one
child.
Now consider this:
module m2()
cylinder(r=1,h=20,center=true);
I would like m2() to return a group with 2 children; the first child is a
group of a cube and sphere, the second child is the cylinder.
What actually happens is that the inner {....} brackets are ignored, and a
group of 3 shapes is returned.
This, I think, is the situation where the group(){...} syntax must be used
explicitly. If {...} worked the way I think it should work, then you
wouldn't need to call group() explicitly. We wouldn't need group() at all,
and we could just use {...} in the CSG tree.
In a related matter, I also think that variables defined within {...}
should be local to the {...} in all cases, but that doesn't happen either,
in the same case where {...} fails to form a group.
Doug.
separate children?
Doug.
child.
from.
Doug Moen.
No, it does not.
Consider this code: module m() { cube(10,center=true); sphere(6,center=true); }; m() returns a group containing two children, a cube and a sphere. The use of '{...}' is necessary here to construct a group containing more than one child. Now consider this: module m2() { { cube(10,center=true); sphere(6,center=true); } cylinder(r=1,h=20,center=true); } I would like m2() to return a group with 2 children; the first child is a group of a cube and sphere, the second child is the cylinder. What actually happens is that the inner {....} brackets are ignored, and a group of 3 shapes is returned. This, I think, is the situation where the group(){...} syntax must be used explicitly. If {...} worked the way I think it should work, then you wouldn't need to call group() explicitly. We wouldn't need group() at all, and we could just use {...} in the CSG tree. In a related matter, I also think that variables defined within {...} should be local to the {...} in all cases, but that doesn't happen either, in the same case where {...} fails to form a group. Doug. On 4 February 2016 at 14:00, nop head <nop.head@gmail.com> wrote: > Yes but if {...} made a group, how would you pass multiple children as > separate children? > > On 4 February 2016 at 18:49, doug moen <doug@moens.org> wrote: > >> Okay, cool. That probably means we should document the group() operator. >> >> And you had to do that because {...} standing alone (not as a module >> argument) doesn't create a group. This is unfortunately another >> incompatibility with OpenSCAD2. >> >> Doug. >> >> >> On Thursday, 4 February 2016, nop head <nop.head@gmail.com> wrote: >> >>> I have used group() explicitly to make a bunch of children into a first >>> child. >>> >>> On 4 February 2016 at 18:04, doug moen <doug@moens.org> wrote: >>> >>>> Ronaldo said: "Best than just eliminating the top level implicit union >>>> would be to have another operator: the set (or aggregate) operator. The set >>>> operator would collect a set of bodies preserving each one as a separated >>>> entity. If you union the set, then they become one (possibly manifold) body >>>> only but before that the set may not represent a manifold. Its bodies may >>>> not even be disjoint." >>>> >>>> We already have a "set (or aggregate)" operator. It is called "group". >>>> The explicit syntax is 'group() { shape1; shape2; ... }'. You can see this >>>> operator if you display the CSG tree. Nobody types it explicitly, because >>>> groups are generated implicitly for every module call (the 'children()' of >>>> a module call is represented by a group, and the output is always a group). >>>> >>>> There is a design flaw in how groups currently work. In short, too many >>>> groups are being implicitly generated. If the tail argument to a module >>>> call is a single (non-compound) statement, like a for loop or a module >>>> call, then the results returned by that statement (which may be a group) >>>> are wrapped in another group with a single element. This prevents you from >>>> feeding multiple outputs from one module call into another module as its >>>> children(). This is why intersection_for() exists. >>>> >>>> There is a plan to fix this problem, but it is called "lazy union", >>>> because the same feature also eliminates the implicit top level union. >>>> https://github.com/openscad/openscad/issues/350 >>>> >>>> OpenSCAD2 fixes the problem by adopting so-called "lazy union" >>>> semantics for module calls, and also by reinterpreting the "{ ... }" syntax >>>> as the group constructor. In OpenSCAD2, groups are always constructed >>>> explicitly using {...} syntax, except for at the top level, where all top >>>> level objects are implicitly collected into a group. >>>> >>>> Even in OpenSCAD2, there is a requirement that each element of a group >>>> be either another group, or a manifold shape. The CGAL union operator >>>> requires that its arguments be manifold; that's where the restriction comes >>>> from. >>>> >>>> Doug Moen. >>>> >>>> On 4 February 2016 at 11:13, Ronaldo Persiano <rcmpersiano@gmail.com> >>>> wrote: >>>> >>>>> doug moen brings another important aspect to this discussion: " the >>>>> top level implicit union that occurs before exporting an STL file". STL is >>>>> intended to represent one object only presumably a 2-manifold and this >>>>> is a serious limitation of STL format. I agree that, excluding >>>>> numerical approximation issues, STL allows the recovering of the missing >>>>> topological information if and only if the geometrical embedding of it is a >>>>> manifold. As I showed before by examples, we can represent several >>>>> non-disjoint manifolds in STL as far as they do not have common vertices. >>>>> But that is very restrictive. >>>>> >>>>> I would like to represent not only one body in OSCAD. I would like to >>>>> represent a set of distinct (not necessarily disjoint) objects. One simple >>>>> application of that, besides the ones Arholm brought, is an animation of, >>>>> say, a ball bouncing in a billiard table. If I define a fixed table and a >>>>> ball on it, as their union is not a 2-manifold, I may have problems. Two >>>>> gears may have contact. In the real world, objects have contact. >>>>> >>>>> Best than just eliminating the top level implicit union would be to >>>>> have another operator: the set (or aggregate) operator. The set operator >>>>> would collect a set of bodies preserving each one as a separated entity. If >>>>> you union the set, then they become one (possibly manifold) body only but >>>>> before that the set may not represent a manifold. Its bodies may not even >>>>> be disjoint. May be, I don't know, there is no non-manifold objects in the >>>>> world but the world itself is not a manifold. >>>>> >>>>> If we go in that way, STL should be abandoned. >>>>> >>>>> 2016-02-04 13:17 GMT-02:00 doug moen <doug@moens.org>: >>>>> >>>>>> "a non-manifold face is a face internal to the body, it has material >>>>>> on both sides and does not describe the external surface of the solid body." >>>>>> >>>>>> The ability to partition a solid into a collection of disjoint >>>>>> subvolumes with shared faces is also useful in OpenSCAD; it's not just a >>>>>> ship design/ACIS thing. >>>>>> >>>>>> One obvious example is 3D printing of multi-material/multi-colour >>>>>> objects. There have been a number of discussions about how to support this >>>>>> in OpenSCAD. Internally, the volumes for each colour/material need to be >>>>>> kept separate and labeled. To export such a model, you either need to >>>>>> export multiple STL files (one per material/colour), or you need to export >>>>>> an AMF file with distinct volume elements for each colour/material. In no >>>>>> case should any of the individual volumes that we track internally or >>>>>> export contain non-manifold faces. >>>>>> >>>>>> This situation can arise in feature request #1562, which requests a >>>>>> convex_decomposition() operator. The result of this operator is a group of >>>>>> solids which share faces between them. Each group element is a convex >>>>>> polyhedron, which is manifold. This feature isn't useful unless we get rid >>>>>> of the implicit union that would otherwise occur when passing the results >>>>>> of convex_decomposition() to another module: see issue #350. But, issue >>>>>> #350 also eliminates the top level implicit union that occurs before >>>>>> exporting an STL file. If we get rid of top level implicit union, and the >>>>>> top level element in a script is a call to convex_decomposition() on >>>>>> non-convex input, then we can't meaningfully export to STL. There is a >>>>>> manifoldness check prior to STL export which *should* report this problem >>>>>> (issue #1215). Exporting the same object to AMF can be supported, because >>>>>> we can put each convex polyhedron into a separate volume. >>>>>> >>>>>> In summary, OpenSCAD should support models that contain disjoint >>>>>> subvolumes with shared faces. There are features we need to add and >>>>>> bugs/design flaws we need to fix before this support is complete. >>>>>> >>>>>> On 4 February 2016 at 02:13, <arnholm@arnholm.org> wrote: >>>>>> >>>>>>> On 2016-02-04 06:54, Triffid Hunter wrote: >>>>>>> >>>>>>>> non-manifold means that the topology is somehow ambiguous. >>>>>>>> >>>>>>> >>>>>>> No, it does not. >>>>>>> >>>>>>> An example of non-manifold topology is where a topological edge is >>>>>>> shared by more than 2 faces. >>>>>>> >>>>>>> http://docs.mcneel.com/rhino/5/help/en-us/popup_moreinformation/non-manifold_edges.htm >>>>>>> >>>>>>> It is not ambiguous, and in many cases a desired feature. This kind >>>>>>> of non-manifold topology is much used in ship design when designing FEM >>>>>>> models with shell elements. Often, non-manifold topology is perfectly >>>>>>> acceptable and is not ambiguous in any way. CAD systems like e.g. ACIS ( >>>>>>> https://en.wikipedia.org/wiki/ACIS ) have no issues representing >>>>>>> non-manifold topology. >>>>>>> >>>>>>> In the special case of 3d solid topological models, a non-manifold >>>>>>> face is a face internal to the body, it has material on both sides and does >>>>>>> not describe the external surface of the solid body. That does not mean it >>>>>>> is topologically ambiguous. Such faces may be and are used for subdivision, >>>>>>> for example to guide 3d solid meshing (solid FEM models). Whether such >>>>>>> non-manifold topological entities are desirable or not depends on the >>>>>>> application area, but it is not topologically ambiguous. >>>>>>> >>>>>>> It is only when the topological description is non-existent things >>>>>>> like this become a problem. >>>>>>> >>>>>>> >>>>>>> Carsten Arnholm >>>>>>> >>>>>>> _______________________________________________ >>>>>>> OpenSCAD mailing list >>>>>>> Discuss@lists.openscad.org >>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>> >>>>>>> >>>>>>> >>>>>> >>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> Discuss@lists.openscad.org >>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>> >>>>>> >>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>>> >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>>> >>> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Thu, Feb 4, 2016 8:34 PM
Well, this open a new world I have never been aware of. But I don't
understand what a group is. In a few tests I have just built, two
overlapping cubes in a group is previewed as two cubes (I see 24 edges) and
rendered as their union (with 12 edges). After all, what is a group?
2016-02-04 18:21 GMT-02:00 doug moen doug@moens.org:
Consider this code:
module m()
child.
Now consider this:
module m2()
Doug.
separate children?
Doug.
child.
from.
Doug Moen.
On 4 February 2016 at 11:13, Ronaldo Persiano rcmpersiano@gmail.com
2016-02-04 13:17 GMT-02:00 doug moen doug@moens.org:
material on both sides and does not describe the external surface of the
solid body."
manifoldness check prior to STL export which should report this problem
No, it does not.
Well, this open a new world I have never been aware of. But I don't understand what a group is. In a few tests I have just built, two overlapping cubes in a group is previewed as two cubes (I see 24 edges) and rendered as their union (with 12 edges). After all, what is a group? 2016-02-04 18:21 GMT-02:00 doug moen <doug@moens.org>: > Consider this code: > > module m() > { > cube(10,center=true); > sphere(6,center=true); > }; > > m() returns a group containing two children, a cube and a sphere. The use > of '{...}' is necessary here to construct a group containing more than one > child. > > Now consider this: > > module m2() > { > { > cube(10,center=true); > sphere(6,center=true); > } > cylinder(r=1,h=20,center=true); > } > > I would like m2() to return a group with 2 children; the first child is a > group of a cube and sphere, the second child is the cylinder. > > What actually happens is that the inner {....} brackets are ignored, and a > group of 3 shapes is returned. > > This, I think, is the situation where the group(){...} syntax must be used > explicitly. If {...} worked the way I think it should work, then you > wouldn't need to call group() explicitly. We wouldn't need group() at all, > and we could just use {...} in the CSG tree. > > In a related matter, I also think that variables defined within {...} > should be local to the {...} in all cases, but that doesn't happen either, > in the same case where {...} fails to form a group. > > Doug. > > On 4 February 2016 at 14:00, nop head <nop.head@gmail.com> wrote: > >> Yes but if {...} made a group, how would you pass multiple children as >> separate children? >> >> On 4 February 2016 at 18:49, doug moen <doug@moens.org> wrote: >> >>> Okay, cool. That probably means we should document the group() operator. >>> >>> And you had to do that because {...} standing alone (not as a module >>> argument) doesn't create a group. This is unfortunately another >>> incompatibility with OpenSCAD2. >>> >>> Doug. >>> >>> >>> On Thursday, 4 February 2016, nop head <nop.head@gmail.com> wrote: >>> >>>> I have used group() explicitly to make a bunch of children into a first >>>> child. >>>> >>>> On 4 February 2016 at 18:04, doug moen <doug@moens.org> wrote: >>>> >>>>> Ronaldo said: "Best than just eliminating the top level implicit >>>>> union would be to have another operator: the set (or aggregate) operator. >>>>> The set operator would collect a set of bodies preserving each one as a >>>>> separated entity. If you union the set, then they become one (possibly >>>>> manifold) body only but before that the set may not represent a manifold. >>>>> Its bodies may not even be disjoint." >>>>> >>>>> We already have a "set (or aggregate)" operator. It is called "group". >>>>> The explicit syntax is 'group() { shape1; shape2; ... }'. You can see this >>>>> operator if you display the CSG tree. Nobody types it explicitly, because >>>>> groups are generated implicitly for every module call (the 'children()' of >>>>> a module call is represented by a group, and the output is always a group). >>>>> >>>>> There is a design flaw in how groups currently work. In short, too >>>>> many groups are being implicitly generated. If the tail argument to a >>>>> module call is a single (non-compound) statement, like a for loop or a >>>>> module call, then the results returned by that statement (which may be a >>>>> group) are wrapped in another group with a single element. This prevents >>>>> you from feeding multiple outputs from one module call into another module >>>>> as its children(). This is why intersection_for() exists. >>>>> >>>>> There is a plan to fix this problem, but it is called "lazy union", >>>>> because the same feature also eliminates the implicit top level union. >>>>> https://github.com/openscad/openscad/issues/350 >>>>> >>>>> OpenSCAD2 fixes the problem by adopting so-called "lazy union" >>>>> semantics for module calls, and also by reinterpreting the "{ ... }" syntax >>>>> as the group constructor. In OpenSCAD2, groups are always constructed >>>>> explicitly using {...} syntax, except for at the top level, where all top >>>>> level objects are implicitly collected into a group. >>>>> >>>>> Even in OpenSCAD2, there is a requirement that each element of a group >>>>> be either another group, or a manifold shape. The CGAL union operator >>>>> requires that its arguments be manifold; that's where the restriction comes >>>>> from. >>>>> >>>>> Doug Moen. >>>>> >>>>> On 4 February 2016 at 11:13, Ronaldo Persiano <rcmpersiano@gmail.com> >>>>> wrote: >>>>> >>>>>> doug moen brings another important aspect to this discussion: " the >>>>>> top level implicit union that occurs before exporting an STL file". STL is >>>>>> intended to represent one object only presumably a 2-manifold and this >>>>>> is a serious limitation of STL format. I agree that, excluding >>>>>> numerical approximation issues, STL allows the recovering of the missing >>>>>> topological information if and only if the geometrical embedding of it is a >>>>>> manifold. As I showed before by examples, we can represent several >>>>>> non-disjoint manifolds in STL as far as they do not have common vertices. >>>>>> But that is very restrictive. >>>>>> >>>>>> I would like to represent not only one body in OSCAD. I would like to >>>>>> represent a set of distinct (not necessarily disjoint) objects. One simple >>>>>> application of that, besides the ones Arholm brought, is an animation of, >>>>>> say, a ball bouncing in a billiard table. If I define a fixed table and a >>>>>> ball on it, as their union is not a 2-manifold, I may have problems. Two >>>>>> gears may have contact. In the real world, objects have contact. >>>>>> >>>>>> Best than just eliminating the top level implicit union would be to >>>>>> have another operator: the set (or aggregate) operator. The set operator >>>>>> would collect a set of bodies preserving each one as a separated entity. If >>>>>> you union the set, then they become one (possibly manifold) body only but >>>>>> before that the set may not represent a manifold. Its bodies may not even >>>>>> be disjoint. May be, I don't know, there is no non-manifold objects in the >>>>>> world but the world itself is not a manifold. >>>>>> >>>>>> If we go in that way, STL should be abandoned. >>>>>> >>>>>> 2016-02-04 13:17 GMT-02:00 doug moen <doug@moens.org>: >>>>>> >>>>>>> "a non-manifold face is a face internal to the body, it has >>>>>>> material on both sides and does not describe the external surface of the >>>>>>> solid body." >>>>>>> >>>>>>> The ability to partition a solid into a collection of disjoint >>>>>>> subvolumes with shared faces is also useful in OpenSCAD; it's not just a >>>>>>> ship design/ACIS thing. >>>>>>> >>>>>>> One obvious example is 3D printing of multi-material/multi-colour >>>>>>> objects. There have been a number of discussions about how to support this >>>>>>> in OpenSCAD. Internally, the volumes for each colour/material need to be >>>>>>> kept separate and labeled. To export such a model, you either need to >>>>>>> export multiple STL files (one per material/colour), or you need to export >>>>>>> an AMF file with distinct volume elements for each colour/material. In no >>>>>>> case should any of the individual volumes that we track internally or >>>>>>> export contain non-manifold faces. >>>>>>> >>>>>>> This situation can arise in feature request #1562, which requests a >>>>>>> convex_decomposition() operator. The result of this operator is a group of >>>>>>> solids which share faces between them. Each group element is a convex >>>>>>> polyhedron, which is manifold. This feature isn't useful unless we get rid >>>>>>> of the implicit union that would otherwise occur when passing the results >>>>>>> of convex_decomposition() to another module: see issue #350. But, issue >>>>>>> #350 also eliminates the top level implicit union that occurs before >>>>>>> exporting an STL file. If we get rid of top level implicit union, and the >>>>>>> top level element in a script is a call to convex_decomposition() on >>>>>>> non-convex input, then we can't meaningfully export to STL. There is a >>>>>>> manifoldness check prior to STL export which *should* report this problem >>>>>>> (issue #1215). Exporting the same object to AMF can be supported, because >>>>>>> we can put each convex polyhedron into a separate volume. >>>>>>> >>>>>>> In summary, OpenSCAD should support models that contain disjoint >>>>>>> subvolumes with shared faces. There are features we need to add and >>>>>>> bugs/design flaws we need to fix before this support is complete. >>>>>>> >>>>>>> On 4 February 2016 at 02:13, <arnholm@arnholm.org> wrote: >>>>>>> >>>>>>>> On 2016-02-04 06:54, Triffid Hunter wrote: >>>>>>>> >>>>>>>>> non-manifold means that the topology is somehow ambiguous. >>>>>>>>> >>>>>>>> >>>>>>>> No, it does not. >>>>>>>> >>>>>>>> An example of non-manifold topology is where a topological edge is >>>>>>>> shared by more than 2 faces. >>>>>>>> >>>>>>>> http://docs.mcneel.com/rhino/5/help/en-us/popup_moreinformation/non-manifold_edges.htm >>>>>>>> >>>>>>>> It is not ambiguous, and in many cases a desired feature. This kind >>>>>>>> of non-manifold topology is much used in ship design when designing FEM >>>>>>>> models with shell elements. Often, non-manifold topology is perfectly >>>>>>>> acceptable and is not ambiguous in any way. CAD systems like e.g. ACIS ( >>>>>>>> https://en.wikipedia.org/wiki/ACIS ) have no issues representing >>>>>>>> non-manifold topology. >>>>>>>> >>>>>>>> In the special case of 3d solid topological models, a non-manifold >>>>>>>> face is a face internal to the body, it has material on both sides and does >>>>>>>> not describe the external surface of the solid body. That does not mean it >>>>>>>> is topologically ambiguous. Such faces may be and are used for subdivision, >>>>>>>> for example to guide 3d solid meshing (solid FEM models). Whether such >>>>>>>> non-manifold topological entities are desirable or not depends on the >>>>>>>> application area, but it is not topologically ambiguous. >>>>>>>> >>>>>>>> It is only when the topological description is non-existent things >>>>>>>> like this become a problem. >>>>>>>> >>>>>>>> >>>>>>>> Carsten Arnholm >>>>>>>> >>>>>>>> _______________________________________________ >>>>>>>> OpenSCAD mailing list >>>>>>>> Discuss@lists.openscad.org >>>>>>>> >>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>> >>>>>>>> >>>>>>>> >>>>>>> >>>>>>> _______________________________________________ >>>>>>> OpenSCAD mailing list >>>>>>> Discuss@lists.openscad.org >>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>> >>>>>>> >>>>>> >>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> Discuss@lists.openscad.org >>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>> >>>>>> >>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>>> >>>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Thu, Feb 4, 2016 8:47 PM
Ronaldo,
With implicit union, a group currently acts like union.
Doug,
If we have:
my_module() {
cube();
cylinder();
Then cube() should be children(0) in my_module and cylinder() children(1).
If { ...} makes a group then they would both be children(0);
Consider this code:
module m()
child.
Now consider this:
module m2()
Doug.
separate children?
Doug.
first child.
"group". The explicit syntax is 'group() { shape1; shape2; ... }'. You can
see this operator if you display the CSG tree. Nobody types it explicitly,
because groups are generated implicitly for every module call (the
'children()' of a module call is represented by a group, and the output is
always a group).
group be either another group, or a manifold shape. The CGAL union operator
from.
Doug Moen.
to represent a set of distinct (not necessarily disjoint) objects. One
simple application of that, besides the ones Arholm brought, is an
animation of, say, a ball bouncing in a billiard table. If I define a fixed
table and a ball on it, as their union is not a 2-manifold, I may have
problems. Two gears may have contact. In the real world, objects have
contact.
solid body."
No, it does not.
kind of non-manifold topology is much used in ship design when designing
FEM models with shell elements. Often, non-manifold topology is perfectly
Ronaldo, With implicit union, a group currently acts like union. Doug, If we have: my_module() { cube(); cylinder(); } Then cube() should be children(0) in my_module and cylinder() children(1). If { ...} makes a group then they would both be children(0); On 4 February 2016 at 20:34, Ronaldo Persiano <rcmpersiano@gmail.com> wrote: > Well, this open a new world I have never been aware of. But I don't > understand what a group is. In a few tests I have just built, two > overlapping cubes in a group is previewed as two cubes (I see 24 edges) and > rendered as their union (with 12 edges). After all, what is a group? > > 2016-02-04 18:21 GMT-02:00 doug moen <doug@moens.org>: > >> Consider this code: >> >> module m() >> { >> cube(10,center=true); >> sphere(6,center=true); >> }; >> >> m() returns a group containing two children, a cube and a sphere. The use >> of '{...}' is necessary here to construct a group containing more than one >> child. >> >> Now consider this: >> >> module m2() >> { >> { >> cube(10,center=true); >> sphere(6,center=true); >> } >> cylinder(r=1,h=20,center=true); >> } >> >> I would like m2() to return a group with 2 children; the first child is a >> group of a cube and sphere, the second child is the cylinder. >> >> What actually happens is that the inner {....} brackets are ignored, and >> a group of 3 shapes is returned. >> >> This, I think, is the situation where the group(){...} syntax must be >> used explicitly. If {...} worked the way I think it should work, then you >> wouldn't need to call group() explicitly. We wouldn't need group() at all, >> and we could just use {...} in the CSG tree. >> >> In a related matter, I also think that variables defined within {...} >> should be local to the {...} in all cases, but that doesn't happen either, >> in the same case where {...} fails to form a group. >> >> Doug. >> >> On 4 February 2016 at 14:00, nop head <nop.head@gmail.com> wrote: >> >>> Yes but if {...} made a group, how would you pass multiple children as >>> separate children? >>> >>> On 4 February 2016 at 18:49, doug moen <doug@moens.org> wrote: >>> >>>> Okay, cool. That probably means we should document the group() operator. >>>> >>>> And you had to do that because {...} standing alone (not as a module >>>> argument) doesn't create a group. This is unfortunately another >>>> incompatibility with OpenSCAD2. >>>> >>>> Doug. >>>> >>>> >>>> On Thursday, 4 February 2016, nop head <nop.head@gmail.com> wrote: >>>> >>>>> I have used group() explicitly to make a bunch of children into a >>>>> first child. >>>>> >>>>> On 4 February 2016 at 18:04, doug moen <doug@moens.org> wrote: >>>>> >>>>>> Ronaldo said: "Best than just eliminating the top level implicit >>>>>> union would be to have another operator: the set (or aggregate) operator. >>>>>> The set operator would collect a set of bodies preserving each one as a >>>>>> separated entity. If you union the set, then they become one (possibly >>>>>> manifold) body only but before that the set may not represent a manifold. >>>>>> Its bodies may not even be disjoint." >>>>>> >>>>>> We already have a "set (or aggregate)" operator. It is called >>>>>> "group". The explicit syntax is 'group() { shape1; shape2; ... }'. You can >>>>>> see this operator if you display the CSG tree. Nobody types it explicitly, >>>>>> because groups are generated implicitly for every module call (the >>>>>> 'children()' of a module call is represented by a group, and the output is >>>>>> always a group). >>>>>> >>>>>> There is a design flaw in how groups currently work. In short, too >>>>>> many groups are being implicitly generated. If the tail argument to a >>>>>> module call is a single (non-compound) statement, like a for loop or a >>>>>> module call, then the results returned by that statement (which may be a >>>>>> group) are wrapped in another group with a single element. This prevents >>>>>> you from feeding multiple outputs from one module call into another module >>>>>> as its children(). This is why intersection_for() exists. >>>>>> >>>>>> There is a plan to fix this problem, but it is called "lazy union", >>>>>> because the same feature also eliminates the implicit top level union. >>>>>> https://github.com/openscad/openscad/issues/350 >>>>>> >>>>>> OpenSCAD2 fixes the problem by adopting so-called "lazy union" >>>>>> semantics for module calls, and also by reinterpreting the "{ ... }" syntax >>>>>> as the group constructor. In OpenSCAD2, groups are always constructed >>>>>> explicitly using {...} syntax, except for at the top level, where all top >>>>>> level objects are implicitly collected into a group. >>>>>> >>>>>> Even in OpenSCAD2, there is a requirement that each element of a >>>>>> group be either another group, or a manifold shape. The CGAL union operator >>>>>> requires that its arguments be manifold; that's where the restriction comes >>>>>> from. >>>>>> >>>>>> Doug Moen. >>>>>> >>>>>> On 4 February 2016 at 11:13, Ronaldo Persiano <rcmpersiano@gmail.com> >>>>>> wrote: >>>>>> >>>>>>> doug moen brings another important aspect to this discussion: " the >>>>>>> top level implicit union that occurs before exporting an STL file". STL is >>>>>>> intended to represent one object only presumably a 2-manifold and this >>>>>>> is a serious limitation of STL format. I agree that, excluding >>>>>>> numerical approximation issues, STL allows the recovering of the missing >>>>>>> topological information if and only if the geometrical embedding of it is a >>>>>>> manifold. As I showed before by examples, we can represent several >>>>>>> non-disjoint manifolds in STL as far as they do not have common vertices. >>>>>>> But that is very restrictive. >>>>>>> >>>>>>> I would like to represent not only one body in OSCAD. I would like >>>>>>> to represent a set of distinct (not necessarily disjoint) objects. One >>>>>>> simple application of that, besides the ones Arholm brought, is an >>>>>>> animation of, say, a ball bouncing in a billiard table. If I define a fixed >>>>>>> table and a ball on it, as their union is not a 2-manifold, I may have >>>>>>> problems. Two gears may have contact. In the real world, objects have >>>>>>> contact. >>>>>>> >>>>>>> Best than just eliminating the top level implicit union would be to >>>>>>> have another operator: the set (or aggregate) operator. The set operator >>>>>>> would collect a set of bodies preserving each one as a separated entity. If >>>>>>> you union the set, then they become one (possibly manifold) body only but >>>>>>> before that the set may not represent a manifold. Its bodies may not even >>>>>>> be disjoint. May be, I don't know, there is no non-manifold objects in the >>>>>>> world but the world itself is not a manifold. >>>>>>> >>>>>>> If we go in that way, STL should be abandoned. >>>>>>> >>>>>>> 2016-02-04 13:17 GMT-02:00 doug moen <doug@moens.org>: >>>>>>> >>>>>>>> "a non-manifold face is a face internal to the body, it has >>>>>>>> material on both sides and does not describe the external surface of the >>>>>>>> solid body." >>>>>>>> >>>>>>>> The ability to partition a solid into a collection of disjoint >>>>>>>> subvolumes with shared faces is also useful in OpenSCAD; it's not just a >>>>>>>> ship design/ACIS thing. >>>>>>>> >>>>>>>> One obvious example is 3D printing of multi-material/multi-colour >>>>>>>> objects. There have been a number of discussions about how to support this >>>>>>>> in OpenSCAD. Internally, the volumes for each colour/material need to be >>>>>>>> kept separate and labeled. To export such a model, you either need to >>>>>>>> export multiple STL files (one per material/colour), or you need to export >>>>>>>> an AMF file with distinct volume elements for each colour/material. In no >>>>>>>> case should any of the individual volumes that we track internally or >>>>>>>> export contain non-manifold faces. >>>>>>>> >>>>>>>> This situation can arise in feature request #1562, which requests a >>>>>>>> convex_decomposition() operator. The result of this operator is a group of >>>>>>>> solids which share faces between them. Each group element is a convex >>>>>>>> polyhedron, which is manifold. This feature isn't useful unless we get rid >>>>>>>> of the implicit union that would otherwise occur when passing the results >>>>>>>> of convex_decomposition() to another module: see issue #350. But, issue >>>>>>>> #350 also eliminates the top level implicit union that occurs before >>>>>>>> exporting an STL file. If we get rid of top level implicit union, and the >>>>>>>> top level element in a script is a call to convex_decomposition() on >>>>>>>> non-convex input, then we can't meaningfully export to STL. There is a >>>>>>>> manifoldness check prior to STL export which *should* report this problem >>>>>>>> (issue #1215). Exporting the same object to AMF can be supported, because >>>>>>>> we can put each convex polyhedron into a separate volume. >>>>>>>> >>>>>>>> In summary, OpenSCAD should support models that contain disjoint >>>>>>>> subvolumes with shared faces. There are features we need to add and >>>>>>>> bugs/design flaws we need to fix before this support is complete. >>>>>>>> >>>>>>>> On 4 February 2016 at 02:13, <arnholm@arnholm.org> wrote: >>>>>>>> >>>>>>>>> On 2016-02-04 06:54, Triffid Hunter wrote: >>>>>>>>> >>>>>>>>>> non-manifold means that the topology is somehow ambiguous. >>>>>>>>>> >>>>>>>>> >>>>>>>>> No, it does not. >>>>>>>>> >>>>>>>>> An example of non-manifold topology is where a topological edge is >>>>>>>>> shared by more than 2 faces. >>>>>>>>> >>>>>>>>> http://docs.mcneel.com/rhino/5/help/en-us/popup_moreinformation/non-manifold_edges.htm >>>>>>>>> >>>>>>>>> It is not ambiguous, and in many cases a desired feature. This >>>>>>>>> kind of non-manifold topology is much used in ship design when designing >>>>>>>>> FEM models with shell elements. Often, non-manifold topology is perfectly >>>>>>>>> acceptable and is not ambiguous in any way. CAD systems like e.g. ACIS ( >>>>>>>>> https://en.wikipedia.org/wiki/ACIS ) have no issues representing >>>>>>>>> non-manifold topology. >>>>>>>>> >>>>>>>>> In the special case of 3d solid topological models, a non-manifold >>>>>>>>> face is a face internal to the body, it has material on both sides and does >>>>>>>>> not describe the external surface of the solid body. That does not mean it >>>>>>>>> is topologically ambiguous. Such faces may be and are used for subdivision, >>>>>>>>> for example to guide 3d solid meshing (solid FEM models). Whether such >>>>>>>>> non-manifold topological entities are desirable or not depends on the >>>>>>>>> application area, but it is not topologically ambiguous. >>>>>>>>> >>>>>>>>> It is only when the topological description is non-existent things >>>>>>>>> like this become a problem. >>>>>>>>> >>>>>>>>> >>>>>>>>> Carsten Arnholm >>>>>>>>> >>>>>>>>> _______________________________________________ >>>>>>>>> OpenSCAD mailing list >>>>>>>>> Discuss@lists.openscad.org >>>>>>>>> >>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>> >>>>>>>>> >>>>>>>>> >>>>>>>> >>>>>>>> _______________________________________________ >>>>>>>> OpenSCAD mailing list >>>>>>>> Discuss@lists.openscad.org >>>>>>>> >>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>> >>>>>>>> >>>>>>> >>>>>>> _______________________________________________ >>>>>>> OpenSCAD mailing list >>>>>>> Discuss@lists.openscad.org >>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>> >>>>>>> >>>>>> >>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> Discuss@lists.openscad.org >>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>> >>>>>> >>>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Thu, Feb 4, 2016 8:58 PM
Nop head, If we have:
my_module() {
cube();
cylinder();
then my_module is called with two children, a cube and a cylinder. The
children() are a group. The only way to pass two children to a module is to
use the {...} syntax, so of course {...} makes a group.
This is the way I've always understood OpenSCAD to work. Apparently you
have a different way of thinking about it?
On 4 February 2016 at 15:47, nop head nop.head@gmail.com wrote:
Ronaldo,
Doug,
If we have:
my_module() {
cube();
cylinder();
Consider this code:
module m()
one child.
Now consider this:
module m2()
Doug.
separate children?
operator.
Doug.
first child.
always a group).
from.
Doug Moen.
the top level implicit union that occurs before exporting an STL file". STL
is intended to represent one object only presumably a 2-manifold and this
contact.
to have another operator: the set (or aggregate) operator. The set operator
solid body."
a convex_decomposition() operator. The result of this operator is a group
of solids which share faces between them. Each group element is a convex
No, it does not.
is shared by more than 2 faces.
non-manifold face is a face internal to the body, it has material on both
sides and does not describe the external surface of the solid body. That
does not mean it is topologically ambiguous. Such faces may be and are used
for subdivision, for example to guide 3d solid meshing (solid FEM models).
Whether such non-manifold topological entities are  desirable or not
depends on the application area, but it is not topologically ambiguous.
things like this become a problem.
Nop head, If we have: my_module() { cube(); cylinder(); } then my_module is called with two children, a cube and a cylinder. The children() are a group. The only way to pass two children to a module is to use the {...} syntax, so of course {...} makes a group. This is the way I've always understood OpenSCAD to work. Apparently you have a different way of thinking about it? On 4 February 2016 at 15:47, nop head <nop.head@gmail.com> wrote: > Ronaldo, > > With implicit union, a group currently acts like union. > > Doug, > > If we have: > > my_module() { > cube(); > cylinder(); > } > > Then cube() should be children(0) in my_module and cylinder() children(1). > If { ...} makes a group then they would both be children(0); > > > On 4 February 2016 at 20:34, Ronaldo Persiano <rcmpersiano@gmail.com> > wrote: > >> Well, this open a new world I have never been aware of. But I don't >> understand what a group is. In a few tests I have just built, two >> overlapping cubes in a group is previewed as two cubes (I see 24 edges) and >> rendered as their union (with 12 edges). After all, what is a group? >> >> 2016-02-04 18:21 GMT-02:00 doug moen <doug@moens.org>: >> >>> Consider this code: >>> >>> module m() >>> { >>> cube(10,center=true); >>> sphere(6,center=true); >>> }; >>> >>> m() returns a group containing two children, a cube and a sphere. The >>> use of '{...}' is necessary here to construct a group containing more than >>> one child. >>> >>> Now consider this: >>> >>> module m2() >>> { >>> { >>> cube(10,center=true); >>> sphere(6,center=true); >>> } >>> cylinder(r=1,h=20,center=true); >>> } >>> >>> I would like m2() to return a group with 2 children; the first child is >>> a group of a cube and sphere, the second child is the cylinder. >>> >>> What actually happens is that the inner {....} brackets are ignored, and >>> a group of 3 shapes is returned. >>> >>> This, I think, is the situation where the group(){...} syntax must be >>> used explicitly. If {...} worked the way I think it should work, then you >>> wouldn't need to call group() explicitly. We wouldn't need group() at all, >>> and we could just use {...} in the CSG tree. >>> >>> In a related matter, I also think that variables defined within {...} >>> should be local to the {...} in all cases, but that doesn't happen either, >>> in the same case where {...} fails to form a group. >>> >>> Doug. >>> >>> On 4 February 2016 at 14:00, nop head <nop.head@gmail.com> wrote: >>> >>>> Yes but if {...} made a group, how would you pass multiple children as >>>> separate children? >>>> >>>> On 4 February 2016 at 18:49, doug moen <doug@moens.org> wrote: >>>> >>>>> Okay, cool. That probably means we should document the group() >>>>> operator. >>>>> >>>>> And you had to do that because {...} standing alone (not as a module >>>>> argument) doesn't create a group. This is unfortunately another >>>>> incompatibility with OpenSCAD2. >>>>> >>>>> Doug. >>>>> >>>>> >>>>> On Thursday, 4 February 2016, nop head <nop.head@gmail.com> wrote: >>>>> >>>>>> I have used group() explicitly to make a bunch of children into a >>>>>> first child. >>>>>> >>>>>> On 4 February 2016 at 18:04, doug moen <doug@moens.org> wrote: >>>>>> >>>>>>> Ronaldo said: "Best than just eliminating the top level implicit >>>>>>> union would be to have another operator: the set (or aggregate) operator. >>>>>>> The set operator would collect a set of bodies preserving each one as a >>>>>>> separated entity. If you union the set, then they become one (possibly >>>>>>> manifold) body only but before that the set may not represent a manifold. >>>>>>> Its bodies may not even be disjoint." >>>>>>> >>>>>>> We already have a "set (or aggregate)" operator. It is called >>>>>>> "group". The explicit syntax is 'group() { shape1; shape2; ... }'. You can >>>>>>> see this operator if you display the CSG tree. Nobody types it explicitly, >>>>>>> because groups are generated implicitly for every module call (the >>>>>>> 'children()' of a module call is represented by a group, and the output is >>>>>>> always a group). >>>>>>> >>>>>>> There is a design flaw in how groups currently work. In short, too >>>>>>> many groups are being implicitly generated. If the tail argument to a >>>>>>> module call is a single (non-compound) statement, like a for loop or a >>>>>>> module call, then the results returned by that statement (which may be a >>>>>>> group) are wrapped in another group with a single element. This prevents >>>>>>> you from feeding multiple outputs from one module call into another module >>>>>>> as its children(). This is why intersection_for() exists. >>>>>>> >>>>>>> There is a plan to fix this problem, but it is called "lazy union", >>>>>>> because the same feature also eliminates the implicit top level union. >>>>>>> https://github.com/openscad/openscad/issues/350 >>>>>>> >>>>>>> OpenSCAD2 fixes the problem by adopting so-called "lazy union" >>>>>>> semantics for module calls, and also by reinterpreting the "{ ... }" syntax >>>>>>> as the group constructor. In OpenSCAD2, groups are always constructed >>>>>>> explicitly using {...} syntax, except for at the top level, where all top >>>>>>> level objects are implicitly collected into a group. >>>>>>> >>>>>>> Even in OpenSCAD2, there is a requirement that each element of a >>>>>>> group be either another group, or a manifold shape. The CGAL union operator >>>>>>> requires that its arguments be manifold; that's where the restriction comes >>>>>>> from. >>>>>>> >>>>>>> Doug Moen. >>>>>>> >>>>>>> On 4 February 2016 at 11:13, Ronaldo Persiano <rcmpersiano@gmail.com >>>>>>> > wrote: >>>>>>> >>>>>>>> doug moen brings another important aspect to this discussion: " >>>>>>>> the top level implicit union that occurs before exporting an STL file". STL >>>>>>>> is intended to represent one object only presumably a 2-manifold and this >>>>>>>> is a serious limitation of STL format. I agree that, excluding >>>>>>>> numerical approximation issues, STL allows the recovering of the missing >>>>>>>> topological information if and only if the geometrical embedding of it is a >>>>>>>> manifold. As I showed before by examples, we can represent several >>>>>>>> non-disjoint manifolds in STL as far as they do not have common vertices. >>>>>>>> But that is very restrictive. >>>>>>>> >>>>>>>> I would like to represent not only one body in OSCAD. I would like >>>>>>>> to represent a set of distinct (not necessarily disjoint) objects. One >>>>>>>> simple application of that, besides the ones Arholm brought, is an >>>>>>>> animation of, say, a ball bouncing in a billiard table. If I define a fixed >>>>>>>> table and a ball on it, as their union is not a 2-manifold, I may have >>>>>>>> problems. Two gears may have contact. In the real world, objects have >>>>>>>> contact. >>>>>>>> >>>>>>>> Best than just eliminating the top level implicit union would be >>>>>>>> to have another operator: the set (or aggregate) operator. The set operator >>>>>>>> would collect a set of bodies preserving each one as a separated entity. If >>>>>>>> you union the set, then they become one (possibly manifold) body only but >>>>>>>> before that the set may not represent a manifold. Its bodies may not even >>>>>>>> be disjoint. May be, I don't know, there is no non-manifold objects in the >>>>>>>> world but the world itself is not a manifold. >>>>>>>> >>>>>>>> If we go in that way, STL should be abandoned. >>>>>>>> >>>>>>>> 2016-02-04 13:17 GMT-02:00 doug moen <doug@moens.org>: >>>>>>>> >>>>>>>>> "a non-manifold face is a face internal to the body, it has >>>>>>>>> material on both sides and does not describe the external surface of the >>>>>>>>> solid body." >>>>>>>>> >>>>>>>>> The ability to partition a solid into a collection of disjoint >>>>>>>>> subvolumes with shared faces is also useful in OpenSCAD; it's not just a >>>>>>>>> ship design/ACIS thing. >>>>>>>>> >>>>>>>>> One obvious example is 3D printing of multi-material/multi-colour >>>>>>>>> objects. There have been a number of discussions about how to support this >>>>>>>>> in OpenSCAD. Internally, the volumes for each colour/material need to be >>>>>>>>> kept separate and labeled. To export such a model, you either need to >>>>>>>>> export multiple STL files (one per material/colour), or you need to export >>>>>>>>> an AMF file with distinct volume elements for each colour/material. In no >>>>>>>>> case should any of the individual volumes that we track internally or >>>>>>>>> export contain non-manifold faces. >>>>>>>>> >>>>>>>>> This situation can arise in feature request #1562, which requests >>>>>>>>> a convex_decomposition() operator. The result of this operator is a group >>>>>>>>> of solids which share faces between them. Each group element is a convex >>>>>>>>> polyhedron, which is manifold. This feature isn't useful unless we get rid >>>>>>>>> of the implicit union that would otherwise occur when passing the results >>>>>>>>> of convex_decomposition() to another module: see issue #350. But, issue >>>>>>>>> #350 also eliminates the top level implicit union that occurs before >>>>>>>>> exporting an STL file. If we get rid of top level implicit union, and the >>>>>>>>> top level element in a script is a call to convex_decomposition() on >>>>>>>>> non-convex input, then we can't meaningfully export to STL. There is a >>>>>>>>> manifoldness check prior to STL export which *should* report this problem >>>>>>>>> (issue #1215). Exporting the same object to AMF can be supported, because >>>>>>>>> we can put each convex polyhedron into a separate volume. >>>>>>>>> >>>>>>>>> In summary, OpenSCAD should support models that contain disjoint >>>>>>>>> subvolumes with shared faces. There are features we need to add and >>>>>>>>> bugs/design flaws we need to fix before this support is complete. >>>>>>>>> >>>>>>>>> On 4 February 2016 at 02:13, <arnholm@arnholm.org> wrote: >>>>>>>>> >>>>>>>>>> On 2016-02-04 06:54, Triffid Hunter wrote: >>>>>>>>>> >>>>>>>>>>> non-manifold means that the topology is somehow ambiguous. >>>>>>>>>>> >>>>>>>>>> >>>>>>>>>> No, it does not. >>>>>>>>>> >>>>>>>>>> An example of non-manifold topology is where a topological edge >>>>>>>>>> is shared by more than 2 faces. >>>>>>>>>> >>>>>>>>>> http://docs.mcneel.com/rhino/5/help/en-us/popup_moreinformation/non-manifold_edges.htm >>>>>>>>>> >>>>>>>>>> It is not ambiguous, and in many cases a desired feature. This >>>>>>>>>> kind of non-manifold topology is much used in ship design when designing >>>>>>>>>> FEM models with shell elements. Often, non-manifold topology is perfectly >>>>>>>>>> acceptable and is not ambiguous in any way. CAD systems like e.g. ACIS ( >>>>>>>>>> https://en.wikipedia.org/wiki/ACIS ) have no issues representing >>>>>>>>>> non-manifold topology. >>>>>>>>>> >>>>>>>>>> In the special case of 3d solid topological models, a >>>>>>>>>> non-manifold face is a face internal to the body, it has material on both >>>>>>>>>> sides and does not describe the external surface of the solid body. That >>>>>>>>>> does not mean it is topologically ambiguous. Such faces may be and are used >>>>>>>>>> for subdivision, for example to guide 3d solid meshing (solid FEM models). >>>>>>>>>> Whether such non-manifold topological entities are desirable or not >>>>>>>>>> depends on the application area, but it is not topologically ambiguous. >>>>>>>>>> >>>>>>>>>> It is only when the topological description is non-existent >>>>>>>>>> things like this become a problem. >>>>>>>>>> >>>>>>>>>> >>>>>>>>>> Carsten Arnholm >>>>>>>>>> >>>>>>>>>> _______________________________________________ >>>>>>>>>> OpenSCAD mailing list >>>>>>>>>> Discuss@lists.openscad.org >>>>>>>>>> >>>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>>> >>>>>>>>>> >>>>>>>>>> >>>>>>>>> >>>>>>>>> _______________________________________________ >>>>>>>>> OpenSCAD mailing list >>>>>>>>> Discuss@lists.openscad.org >>>>>>>>> >>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>> >>>>>>>>> >>>>>>>> >>>>>>>> _______________________________________________ >>>>>>>> OpenSCAD mailing list >>>>>>>> Discuss@lists.openscad.org >>>>>>>> >>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>> >>>>>>>> >>>>>>> >>>>>>> _______________________________________________ >>>>>>> OpenSCAD mailing list >>>>>>> Discuss@lists.openscad.org >>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>> >>>>>>> >>>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>>> >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Thu, Feb 4, 2016 9:36 PM
nop head said:
<quote>
Ronaldo,
</quote>
I didn't use implicit group but:
group(){
cube(50);
translate([0,0,30]) cube(50);
which is previewed as two cubes and rendered as their union.
2016-02-04 18:58 GMT-02:00 doug moen doug@moens.org:
my_module() {
cube();
cylinder();
Ronaldo,
Doug,
If we have:
my_module() {
cube();
cylinder();
Consider this code:
module m()
one child.
Now consider this:
module m2()
Doug.
separate children?
operator.
Doug.
first child.
always a group).
from.
Doug Moen.
contact.
solid body."
No, it does not.
representing non-manifold topology.
nop head said: <quote> Ronaldo, With implicit union, a group currently acts like union. </quote> I didn't use implicit group but: group(){ cube(50); translate([0,0,30]) cube(50); } which is previewed as two cubes and rendered as their union. 2016-02-04 18:58 GMT-02:00 doug moen <doug@moens.org>: > Nop head, If we have: > > my_module() { > cube(); > cylinder(); > } > > then my_module is called with two children, a cube and a cylinder. The > children() are a group. The only way to pass two children to a module is to > use the {...} syntax, so of course {...} makes a group. > > This is the way I've always understood OpenSCAD to work. Apparently you > have a different way of thinking about it? > > > On 4 February 2016 at 15:47, nop head <nop.head@gmail.com> wrote: > >> Ronaldo, >> >> With implicit union, a group currently acts like union. >> >> Doug, >> >> If we have: >> >> my_module() { >> cube(); >> cylinder(); >> } >> >> Then cube() should be children(0) in my_module and cylinder() >> children(1). If { ...} makes a group then they would both be children(0); >> >> >> On 4 February 2016 at 20:34, Ronaldo Persiano <rcmpersiano@gmail.com> >> wrote: >> >>> Well, this open a new world I have never been aware of. But I don't >>> understand what a group is. In a few tests I have just built, two >>> overlapping cubes in a group is previewed as two cubes (I see 24 edges) and >>> rendered as their union (with 12 edges). After all, what is a group? >>> >>> 2016-02-04 18:21 GMT-02:00 doug moen <doug@moens.org>: >>> >>>> Consider this code: >>>> >>>> module m() >>>> { >>>> cube(10,center=true); >>>> sphere(6,center=true); >>>> }; >>>> >>>> m() returns a group containing two children, a cube and a sphere. The >>>> use of '{...}' is necessary here to construct a group containing more than >>>> one child. >>>> >>>> Now consider this: >>>> >>>> module m2() >>>> { >>>> { >>>> cube(10,center=true); >>>> sphere(6,center=true); >>>> } >>>> cylinder(r=1,h=20,center=true); >>>> } >>>> >>>> I would like m2() to return a group with 2 children; the first child is >>>> a group of a cube and sphere, the second child is the cylinder. >>>> >>>> What actually happens is that the inner {....} brackets are ignored, >>>> and a group of 3 shapes is returned. >>>> >>>> This, I think, is the situation where the group(){...} syntax must be >>>> used explicitly. If {...} worked the way I think it should work, then you >>>> wouldn't need to call group() explicitly. We wouldn't need group() at all, >>>> and we could just use {...} in the CSG tree. >>>> >>>> In a related matter, I also think that variables defined within {...} >>>> should be local to the {...} in all cases, but that doesn't happen either, >>>> in the same case where {...} fails to form a group. >>>> >>>> Doug. >>>> >>>> On 4 February 2016 at 14:00, nop head <nop.head@gmail.com> wrote: >>>> >>>>> Yes but if {...} made a group, how would you pass multiple children as >>>>> separate children? >>>>> >>>>> On 4 February 2016 at 18:49, doug moen <doug@moens.org> wrote: >>>>> >>>>>> Okay, cool. That probably means we should document the group() >>>>>> operator. >>>>>> >>>>>> And you had to do that because {...} standing alone (not as a module >>>>>> argument) doesn't create a group. This is unfortunately another >>>>>> incompatibility with OpenSCAD2. >>>>>> >>>>>> Doug. >>>>>> >>>>>> >>>>>> On Thursday, 4 February 2016, nop head <nop.head@gmail.com> wrote: >>>>>> >>>>>>> I have used group() explicitly to make a bunch of children into a >>>>>>> first child. >>>>>>> >>>>>>> On 4 February 2016 at 18:04, doug moen <doug@moens.org> wrote: >>>>>>> >>>>>>>> Ronaldo said: "Best than just eliminating the top level implicit >>>>>>>> union would be to have another operator: the set (or aggregate) operator. >>>>>>>> The set operator would collect a set of bodies preserving each one as a >>>>>>>> separated entity. If you union the set, then they become one (possibly >>>>>>>> manifold) body only but before that the set may not represent a manifold. >>>>>>>> Its bodies may not even be disjoint." >>>>>>>> >>>>>>>> We already have a "set (or aggregate)" operator. It is called >>>>>>>> "group". The explicit syntax is 'group() { shape1; shape2; ... }'. You can >>>>>>>> see this operator if you display the CSG tree. Nobody types it explicitly, >>>>>>>> because groups are generated implicitly for every module call (the >>>>>>>> 'children()' of a module call is represented by a group, and the output is >>>>>>>> always a group). >>>>>>>> >>>>>>>> There is a design flaw in how groups currently work. In short, too >>>>>>>> many groups are being implicitly generated. If the tail argument to a >>>>>>>> module call is a single (non-compound) statement, like a for loop or a >>>>>>>> module call, then the results returned by that statement (which may be a >>>>>>>> group) are wrapped in another group with a single element. This prevents >>>>>>>> you from feeding multiple outputs from one module call into another module >>>>>>>> as its children(). This is why intersection_for() exists. >>>>>>>> >>>>>>>> There is a plan to fix this problem, but it is called "lazy union", >>>>>>>> because the same feature also eliminates the implicit top level union. >>>>>>>> https://github.com/openscad/openscad/issues/350 >>>>>>>> >>>>>>>> OpenSCAD2 fixes the problem by adopting so-called "lazy union" >>>>>>>> semantics for module calls, and also by reinterpreting the "{ ... }" syntax >>>>>>>> as the group constructor. In OpenSCAD2, groups are always constructed >>>>>>>> explicitly using {...} syntax, except for at the top level, where all top >>>>>>>> level objects are implicitly collected into a group. >>>>>>>> >>>>>>>> Even in OpenSCAD2, there is a requirement that each element of a >>>>>>>> group be either another group, or a manifold shape. The CGAL union operator >>>>>>>> requires that its arguments be manifold; that's where the restriction comes >>>>>>>> from. >>>>>>>> >>>>>>>> Doug Moen. >>>>>>>> >>>>>>>> On 4 February 2016 at 11:13, Ronaldo Persiano < >>>>>>>> rcmpersiano@gmail.com> wrote: >>>>>>>> >>>>>>>>> doug moen brings another important aspect to this discussion: " >>>>>>>>> the top level implicit union that occurs before exporting an STL file". STL >>>>>>>>> is intended to represent one object only presumably a 2-manifold and this >>>>>>>>> is a serious limitation of STL format. I agree that, excluding >>>>>>>>> numerical approximation issues, STL allows the recovering of the missing >>>>>>>>> topological information if and only if the geometrical embedding of it is a >>>>>>>>> manifold. As I showed before by examples, we can represent several >>>>>>>>> non-disjoint manifolds in STL as far as they do not have common vertices. >>>>>>>>> But that is very restrictive. >>>>>>>>> >>>>>>>>> I would like to represent not only one body in OSCAD. I would like >>>>>>>>> to represent a set of distinct (not necessarily disjoint) objects. One >>>>>>>>> simple application of that, besides the ones Arholm brought, is an >>>>>>>>> animation of, say, a ball bouncing in a billiard table. If I define a fixed >>>>>>>>> table and a ball on it, as their union is not a 2-manifold, I may have >>>>>>>>> problems. Two gears may have contact. In the real world, objects have >>>>>>>>> contact. >>>>>>>>> >>>>>>>>> Best than just eliminating the top level implicit union would be >>>>>>>>> to have another operator: the set (or aggregate) operator. The set operator >>>>>>>>> would collect a set of bodies preserving each one as a separated entity. If >>>>>>>>> you union the set, then they become one (possibly manifold) body only but >>>>>>>>> before that the set may not represent a manifold. Its bodies may not even >>>>>>>>> be disjoint. May be, I don't know, there is no non-manifold objects in the >>>>>>>>> world but the world itself is not a manifold. >>>>>>>>> >>>>>>>>> If we go in that way, STL should be abandoned. >>>>>>>>> >>>>>>>>> 2016-02-04 13:17 GMT-02:00 doug moen <doug@moens.org>: >>>>>>>>> >>>>>>>>>> "a non-manifold face is a face internal to the body, it has >>>>>>>>>> material on both sides and does not describe the external surface of the >>>>>>>>>> solid body." >>>>>>>>>> >>>>>>>>>> The ability to partition a solid into a collection of disjoint >>>>>>>>>> subvolumes with shared faces is also useful in OpenSCAD; it's not just a >>>>>>>>>> ship design/ACIS thing. >>>>>>>>>> >>>>>>>>>> One obvious example is 3D printing of multi-material/multi-colour >>>>>>>>>> objects. There have been a number of discussions about how to support this >>>>>>>>>> in OpenSCAD. Internally, the volumes for each colour/material need to be >>>>>>>>>> kept separate and labeled. To export such a model, you either need to >>>>>>>>>> export multiple STL files (one per material/colour), or you need to export >>>>>>>>>> an AMF file with distinct volume elements for each colour/material. In no >>>>>>>>>> case should any of the individual volumes that we track internally or >>>>>>>>>> export contain non-manifold faces. >>>>>>>>>> >>>>>>>>>> This situation can arise in feature request #1562, which requests >>>>>>>>>> a convex_decomposition() operator. The result of this operator is a group >>>>>>>>>> of solids which share faces between them. Each group element is a convex >>>>>>>>>> polyhedron, which is manifold. This feature isn't useful unless we get rid >>>>>>>>>> of the implicit union that would otherwise occur when passing the results >>>>>>>>>> of convex_decomposition() to another module: see issue #350. But, issue >>>>>>>>>> #350 also eliminates the top level implicit union that occurs before >>>>>>>>>> exporting an STL file. If we get rid of top level implicit union, and the >>>>>>>>>> top level element in a script is a call to convex_decomposition() on >>>>>>>>>> non-convex input, then we can't meaningfully export to STL. There is a >>>>>>>>>> manifoldness check prior to STL export which *should* report this problem >>>>>>>>>> (issue #1215). Exporting the same object to AMF can be supported, because >>>>>>>>>> we can put each convex polyhedron into a separate volume. >>>>>>>>>> >>>>>>>>>> In summary, OpenSCAD should support models that contain disjoint >>>>>>>>>> subvolumes with shared faces. There are features we need to add and >>>>>>>>>> bugs/design flaws we need to fix before this support is complete. >>>>>>>>>> >>>>>>>>>> On 4 February 2016 at 02:13, <arnholm@arnholm.org> wrote: >>>>>>>>>> >>>>>>>>>>> On 2016-02-04 06:54, Triffid Hunter wrote: >>>>>>>>>>> >>>>>>>>>>>> non-manifold means that the topology is somehow ambiguous. >>>>>>>>>>>> >>>>>>>>>>> >>>>>>>>>>> No, it does not. >>>>>>>>>>> >>>>>>>>>>> An example of non-manifold topology is where a topological edge >>>>>>>>>>> is shared by more than 2 faces. >>>>>>>>>>> >>>>>>>>>>> http://docs.mcneel.com/rhino/5/help/en-us/popup_moreinformation/non-manifold_edges.htm >>>>>>>>>>> >>>>>>>>>>> It is not ambiguous, and in many cases a desired feature. This >>>>>>>>>>> kind of non-manifold topology is much used in ship design when designing >>>>>>>>>>> FEM models with shell elements. Often, non-manifold topology is perfectly >>>>>>>>>>> acceptable and is not ambiguous in any way. CAD systems like e.g. ACIS ( >>>>>>>>>>> https://en.wikipedia.org/wiki/ACIS ) have no issues >>>>>>>>>>> representing non-manifold topology. >>>>>>>>>>> >>>>>>>>>>> In the special case of 3d solid topological models, a >>>>>>>>>>> non-manifold face is a face internal to the body, it has material on both >>>>>>>>>>> sides and does not describe the external surface of the solid body. That >>>>>>>>>>> does not mean it is topologically ambiguous. Such faces may be and are used >>>>>>>>>>> for subdivision, for example to guide 3d solid meshing (solid FEM models). >>>>>>>>>>> Whether such non-manifold topological entities are desirable or not >>>>>>>>>>> depends on the application area, but it is not topologically ambiguous. >>>>>>>>>>> >>>>>>>>>>> It is only when the topological description is non-existent >>>>>>>>>>> things like this become a problem. >>>>>>>>>>> >>>>>>>>>>> >>>>>>>>>>> Carsten Arnholm >>>>>>>>>>> >>>>>>>>>>> _______________________________________________ >>>>>>>>>>> OpenSCAD mailing list >>>>>>>>>>> Discuss@lists.openscad.org >>>>>>>>>>> >>>>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>>>> >>>>>>>>>>> >>>>>>>>>>> >>>>>>>>>> >>>>>>>>>> _______________________________________________ >>>>>>>>>> OpenSCAD mailing list >>>>>>>>>> Discuss@lists.openscad.org >>>>>>>>>> >>>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>>> >>>>>>>>>> >>>>>>>>> >>>>>>>>> _______________________________________________ >>>>>>>>> OpenSCAD mailing list >>>>>>>>> Discuss@lists.openscad.org >>>>>>>>> >>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>> >>>>>>>>> >>>>>>>> >>>>>>>> _______________________________________________ >>>>>>>> OpenSCAD mailing list >>>>>>>> Discuss@lists.openscad.org >>>>>>>> >>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>> >>>>>>>> >>>>>>> >>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> Discuss@lists.openscad.org >>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>> >>>>>> >>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>>> >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
