I work with an integrated CAD/CAM program a lot, Carbide Create (ob. discl., I work for the company).
It uses JSON for its native file format, .c2d
Would it be possible to add sufficiently flexible support for writing out JSON files that it would then be feasible to work on writing out a .c2d file from OpenSCAD which would cut out the design in question?
Currently, when a design is worked up, I'm finding it necessary to output multiple views of it in a DXF or SVG --- this file is then opened in Carbide Create, each view for each tool/depth is then dragged into register, and appropriate Toolpaths are assigned:
https://willadams.gitbook.io/design-into-3d/full-blind-box-joints
which is kind of tedious.
