I am toying around with modeling an electric guitar body in OpenSCAD.
Google "Gibson SG" for an idea about the body shape. In order to create
the shape, I need between 10 and 20 control points (for one side of the
guitar body: the other side is [fortunately] a mirror image). I found
some code that will handle 4 control points, and some that will handle
8, but nothing that will handle "n" points. I suppose I could try to do
this with a series of 4-point or 8 point curves, but would prefer to do
it with one curve.
Any insights into this? My quick perusal of the existing code implies
that one needs "n" hand-coded functions when handling "n" points, which
is why the previous authors went with fixed numbers of 4 and 8.
Sent from my desktop computer.
I do not receive emails while away from my desk,
nor do I receive texts on my main phone number
(which is a land line).
If you know that I am on the road, please text me.
If you know that I am home, please email me.
try dotscad, https://github.com/JustinSDK/dotSCAD
its a really good library, with lots of useful modules. the bezier_curve
(https://openhome.cc/eGossip/OpenSCAD/lib-bezier_curve.html) can probably do
what you want, although you might find it easier to use a few sets of curves
as the curves are a bit harder to control with more than 4 points.
I don't believe you could get the shape of Gibson SG with one or two Bezier
curves, even with 20 control points. One alternative is to use
interpolation splines instead of Bezier. See for instance, the library
http://www.thingiverse.com/thing:1208001. However, you may find difficult
to position the input points to interpolate in order to get the curve you
have in mind. A better approach is to use B-splines or even NURBS but I
don't know any published OpenSCAD library with them.
I would suggest loading an image into InkScape and using as many Bezier segments (ie one line as you wish) to map it. Then import that into OpenSCAD and either use extrusions of 2D shape to "build" the body or at least use it as a visual check on what choose to do instead of extrusion. Some compromise will be required in this as the guitar body is not a standard OpenSCAD geometric shape, the smooth curves will be reduced to planar segments at some stage. However understanding the resolution of your printer will help you achieve a workable compromise when the spline curves are quantised into segments (ie in Inkscape or OpenSCAD import).
Rob
I.e. https://www.thingiverse.com/thing:1065500
Rob
Does it really have to be bezier curves?
I would recommend trying to use cubic natural splines instead, Parkinbot has
a great nSpline function/library that allows you to do what you want.
I often feel like a child among graduate students with you guys. I
thought what I was trying to do was simple (create a smooth exterior
curve for the guitar body) and all I needed was a "smoothing function"
of some sort. I do not understand the difference between Bezier and
splines: they both are magic to me. But Bezier appears to work to smooth
a curved line on a plane, while Parkinbot's splines appear to work on a
3D surface. Is there a way to use Parkinbot's splines for the simpler
line-on-a-plane case?
Sorry for being so clueless.
If all your "control points" are in a plane, Bezier and splines will be in
their plane. I am quite sure (but haven't check it) that Parkinbot's spline
library will work with with 2D control points as well.
Em 24 de out de 2017 09:45, "jon" jon@jonbondy.com escreveu:
I often feel like a child among graduate students with you guys. I thought
what I was trying to do was simple (create a smooth exterior curve for the
guitar body) and all I needed was a "smoothing function" of some sort. I
do not understand the difference between Bezier and splines: they both are
magic to me. But Bezier appears to work to smooth a curved line on a plane,
while Parkinbot's splines appear to work on a 3D surface. Is there a way
to use Parkinbot's splines for the simpler line-on-a-plane case?
has
I would use a 2D CAD program to import a foto or drawing and draw the shape
on top of that. LibreCAD could probably do that. Or Inkscape, as was already
suggested. Then, you can export the (closed!) shape as DXF and import it
into OpenSCAD to extrude it.
Those 2D programs also allow you to draw an inner offset, so you can use a
Minkowski sum to add rounded corners to the body. Off course, the part where
the neck is attached should be taken care of separately.
On 2017-10-24 13:03, Ronaldo Persiano wrote:
I am quite sure (but haven't check it) that Parkinbot's spline library
I often used with 2D data, and sometimes with 4/5/6 D data!
This is done when I want to move a (say) circle along a path. I have X/Y
data, and also size of disc and its angle, etc. as control points.
NSpline then smooths this data and I can use transformations on circle
points returned from a function to get all the required points to use
finally use skin ().
Most of these teapots that I recently designed and printed for a charity
use this approach in various (slightly hacky!) ways.
