Thanks everybody!
I had success compiling with MSYS in quite a short time.
Jordan, your scripts were OK, I only had to resolve a conflict that did not
allow the .cmk to complete by manually installing mingw-w64-x86_64-pkgconf
Then I also manually installed mingw-w64-x86_64-cmake since the default
cmake was giving me errors.
Should I need the static version, would it be sufficient to add
the MI_BUILD_STATIC define to the cmake invocation?
Excellent.
did not allow the .cmk to complete by manually
installing mingw-w64-x86_64-pkgconf.
I dimly remember something about that. I'm working on wiping one of my
build environments so as to rebuild it and note all of the steps required.
default cmake was giving me errors.
I'll look into that as I build my environment.
Sorry, can't help you with that. Torsten?
add the MI_BUILD_STATIC define to the cmake invocation?
I don't know if and how well it works on MSYS2, there's still
some discussion underway to get things sorted for the MXE
builds.
My suggestions would be to start with just disabling this via
-DUSE_MIMALLOC=OFF
