Tue, Mar 14, 2023 7:42 PM
Greatings all;
Possible buglet advisory...
Trying to make a loom clamp to anchor a hot end umbilical cable, seems
like it s/b easy, define a cube and a recipe of differences.
The code:
module loom_clamp()
$fn=24; // to be reasonably round
ln=30;// length of block
sh=26/2;// separation of bolt holes
bl=sh3;// width of block
ld=16;// diameter of loom
translate([0,0,12])difference()
cube([ln,bl,ld1.5],center=true);
translate([0,0,4])rotate([90,0,0])cylinder(h=sh3+1,d=ld,center=true);
translate([0,0,8.01])cube([ld,sh3.1,ld/2+.1],center=true);
loom_clamp();
F5 works in a few milliseconds, F6 reports:
[fast-csg] corefinement mesh difference #469: 12 facets vs. 92 facets
[fast-csg-remesh] Remeshed from 214 to 12 faces (94 % improvement)
WARNING: [fast-csg] Corefinement corefinement mesh difference #469 failed
Rendering cancelled on first warning.
I still need to add a couple bolt holes to attach it to the printer. So
I've turned off fast-cgi, and F6 now works.
Cheers, Gene Heskett.
Greatings all;
The code:
module loom_clamp()
bl=sh*3;// width of block
cube([ln,bl,ld*1.5],center=true);
translate([0,0,4])rotate([90,0,0])cylinder(h=sh*3+1,d=ld,center=true);
translate([0,0,8.01])cube([ld,sh*3.1,ld/2+.1],center=true);
loom_clamp();
- Louis D. Brandeis
Genes Web page <http://geneslinuxbox.net:6309/>
Tue, Mar 14, 2023 10:44 PM
On Tue, 2023-03-14 at 15:42 -0400, gene heskett wrote:
Greatings all;
seems
The code:
module loom_clamp()
er=true);
loom_clamp();
No idea why, but reversing the order to the two objects being
subtracted from the main cube fixes it.
module loom_clamp()
loom_clamp();
failed
So
> Greatings all;
> seems
> The code:
> module loom_clamp()
> er=true);
> loom_clamp();
module loom_clamp()
loom_clamp();
> failed
> WARNING: No top level geometry to render
> So
Wed, Mar 15, 2023 12:22 AM
Greatings all;
seems
The code:
module loom_clamp()
er=true);
loom_clamp();
Odd, I don't recall encountering that effect before. With a new bed
plate, new heat break, a direct drive conversion and a carbide nozzle, I
had to turn the bed plate over to the smooth side, run the temps up
another 15C each, and it it doesn't finish coming loose from warpage
I'll have a usable part. Finger and other appendages crossed.
module loom_clamp()
loom_clamp();
failed
So
>> Greatings all;
>> seems
>> The code:
>> module loom_clamp()
>> er=true);
>> loom_clamp();
Thanks Larry.
> module loom_clamp()
> loom_clamp();
>> failed
>> So
- Louis D. Brandeis
Wed, Mar 15, 2023 5:02 PM
Greatings all;
seems
The code:
module loom_clamp()
er=true);
loom_clamp();
Dumbass at work, me. I didn't realize the glossy surface was because
there was a sheet of clear, stick-on protective plastic on the satin
side. Moved it to the recycle bag, lowered all the temps 10C and its
working great.
And changing the $fn to 47 let me turn fast-cgi back on.
Happy camper I am!
module loom_clamp()
loom_clamp();
failed
So
>>> Greatings all;
>>> seems
>>> The code:
>>> module loom_clamp()
>>> er=true);
>>> loom_clamp();
> Thanks Larry.
working great.
Happy camper I am!
>> module loom_clamp()
>> loom_clamp();
>>> failed
>>> So
- Louis D. Brandeis
