LG
Laurence Gonsalves
Thu, Jul 9, 2015 6:11 PM
I'm trying to construct a model where I have a set of 3D points, and I want
to create "rods" connecting certain pairs of these points, where a "rod" is
cylinder connecting the points, capped with hemispheres.
This brute force solution works:
module rod(a, b, r) {
hull() {
translate(a) sphere(r);
translate(b) sphere(r);
but it's really slow for high values of $fn if I have a bunch of these
rods.
I was thinking that I could do something like this instead:
rotate([?,?,?]) translate(a) union() {
sphere(r);
cylinder(r=thickness, h=h);
translate([0,0,h]) sphere(r);
h = norm(a-b);
which should be much faster, but before I try to work out the trig for that
rotation, I'm wondering if there's an existing solution to "generate a rod
between two points" or to "create a rotation that points z in the direction
of a vector".
hull() {
but it's *really* slow for high values of $fn if I have a bunch of these
rods.
sphere(r);
h = norm(a-b);
of a vector".
LG
Laurence Gonsalves
Thu, Jul 9, 2015 6:36 PM
Oops! This should be:
translate(a) rotate([?,?,?]) union() {
On Thu, Jul 9, 2015 at 11:11 AM, Laurence Gonsalves
RK
Roland Koebler
Thu, Jul 9, 2015 9:10 PM
rotation, I'm wondering if there's an existing solution to [...]
of a vector".
yes, there is: multmatrix().
With multmatrix(), you can use a 4x4 transformation-matrix, and don't
need to play with rotate and angles. It takes some time to understand
transformation-matrices, but it's a lot easier afterwards.
In more detail:
multmatrix() uses a matrix-vector-multiplication for
coordinate-transformation, so:
[new_x] [u0 v2 w0 t0] [x]
[new_y] = [u1 v1 w1 t1] * [y]
[new_z] [u2 v0 w2 t2] [z]
[1] [0 0 0 1] [1]
All this does is:
- translate by t
- transform (rotate, stretch, shear, mirror), so that
- the new x-axis points to u (so, [1,0,0] is transformed to [u0,u1,u2])
- the new y-axis points to v (so, [0,1,0] is transformed to [v0,v1,v2])
- the new z-axis points to w (so, [0,0,1] is transformed to [w0,w1,w2])
So, you need to determine u,v and w:
w / z-axis:
In OpenSCAD, a cylinder is created in z-direction, so it goes from [0,0,0]
to [0,0,h]. But you want it to go from [0,0,0] to (b-a). So, you already
know the new z-axis:
w = (b-a) / norm(b-a).
So, if you use:
[new_x] [1 0 (b-a)[0] a0] [x]
[new_y] = [0 1 (b-a)[1] a1] * [y]
[new_z] [0 0 (b-a)[2] a2] [z]
[1] [0 0 0 1] [1]
your cylinder would already point into the correct direction
(but wouldn't be a real cylinder anymore).
u / x-axis: The new x-axis must be perpendicular to the new z-axis;
otherwise the cylinder wouldn't look like a cylinder. For simplicity,
we chose that it should also be perpendicular to the old z-axis.
So, we need the cross-product of the old and the new z-axis:
u = cross(w, [0,0,1]) / norm(w, [0,0,1])
v / y-axis: The new y-axis must be perpendicular to the new x- and
the new z-axis. So, we can again use the cross-product:
v = cross(w, u) / norm(w, u)
That's it.
So, in OpenSCAD:
translate(a) sphere(r=r);
translate(b) sphere(r=r);
dir = b-a;
h = norm(dir);
if(dir[0] == 0 && dir[1] == 0) {
// no transformation necessary
cylinder(r=r, h=h);
else {
w = dir / h;
u0 = cross(w, [0,0,1]);
u = u0 / norm(u0);
v0 = cross(w, u);
v = v0 / norm(v0);
multmatrix(m=[[u[0], v[0], w[0], a[0]],
[u[1], v[1], w[1], a[1]],
[u[2], v[2], w[2], a[2]],
[0, 0, 0, 1]])
cylinder(r=r, h=h);
enjoy,
Roland
> of a vector".
In more detail:
[1] [0 0 0 1] [1]
All this does is:
- translate by t
- w / z-axis:
So, if you use:
[1] [0 0 0 1] [1]
- u / x-axis: The new x-axis must be perpendicular to the new z-axis;
- v / y-axis: The new y-axis must be perpendicular to the new x- and
That's it.
So, in OpenSCAD:
dir = b-a;
h = norm(dir);
cylinder(r=r, h=h);
else {
w = dir / h;
u = u0 / norm(u0);
v0 = cross(w, u);
v = v0 / norm(v0);
[0, 0, 0, 1]])
cylinder(r=r, h=h);
enjoy,
Roland
Thu, Jul 9, 2015 11:01 PM
Thank you Roland, for that clear and concise explanation.
I think I even remember some of my pure math from Uni 30-odd years ago...
View this message in context: http://forum.openscad.org/Rods-between-3D-points-tp13104p13111.html
The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/
Thu, Jul 9, 2015 11:03 PM
The cylinders should be transformed too, they look odd.
View this message in context: http://forum.openscad.org/Rods-between-3D-points-tp13104p13112.html
strike cylinder, insert sphere.
View this message in context: http://forum.openscad.org/Rods-between-3D-points-tp13104p13113.html
LG
Laurence Gonsalves
Mon, Jul 13, 2015 11:27 PM
Thank you! That's a great explanation.
I just tried your code out, and it worked perfectly, though I was surprised
to find that it turns out to actually be slower than using hull() when
rendering. This was a complete surprise to me. Creating a single rod with
$fn=72 took 20 seconds to render! This is no fault of your code -- even
rendering a cylinder and two spheres without the multmatrix takes longer to
render than the hull of two spheres. (I guess I really should have tested
that before I asked my original question.)
In any case, I'll definitely remember to consider using multmatrix when
working out the transformation I need as individual rotations turns out to
be too hairy.
Thanks again.
On Thu, Jul 9, 2015 at 2:10 PM, Roland Koebler <rk-list@simple-is-better.org>
be too hairy.
Thanks again.
runsun
Tue, Jul 14, 2015 4:46 AM
surprised
to
I recalled reading somewhere that multimatrix is a 4x4 matrix and
is slow in nature, so many game programmers separate the rotation
part (3x3) and the translation part (3x1) to speed it up. Not sure if it
that's the case though.
It will be much faster if you can generate points on both end points
and use polyhedron. Steps :
Let P,Q are the two points where the rod links.
- Generate points around P ==> P_pts = [p0,p1,p2.....]
- Generate points around Q ==> Q_pts= [q0,q1,q2 ...]
they are points of a circle at P,Q, resp:
then pts = concat( P_pts, Q_pts) = [ p0,p1.... q0,q1 ...]
Use the faces() (see here
http://forum.openscad.org/A-faces-function-for-simple-polyhedrons-td12809.html
) to generate faces:
faces = faces(shape="rod", nside= len(P_pts), nseg=1)
Make a polyhedron:
polyhedron( point= pts, faces=faces )
In cases of 72 sides, this takes about 1~2 sec or less .
$ Runsun Pan, PhD
$ -- OpenScad_DocTest ( Thingiverse ), faces , Offliner
View this message in context: http://forum.openscad.org/Rods-between-3D-points-tp13104p13138.html
> surprised
> to
1) Generate points around P ==> P_pts = [p0,p1,p2.....]
2) Generate points around Q ==> Q_pts= [q0,q1,q2 ...]
3) then pts = concat( P_pts, Q_pts) = [ p0,p1.... q0,q1 ...]
4) Use the faces() (see here
<http://forum.openscad.org/A-faces-function-for-simple-polyhedrons-td12809.html>
5) Make a polyhedron:
$ Runsun Pan, PhD
