JL
Jamie Larkby-Lahet
Thu, Feb 20, 2025 3:32 PM
Thanks! i hadn't seen that. turns out there is a pull request for adding
an LSP implementation to openscad itself:
https://github.com/openscad/openscad/pull/3635
which is the 'real' real fix :P
looks like the is neovim support for the LSP I'm using if that appeals to
you at all.
On Thu, Feb 20, 2025, 03:24 Roel Vanhout roel.vanhout@gmail.com wrote:
Thanks all. I guess going the proper LSP based way is the 'real' fix after
all. But after spending almost the entire day yesterday getting the lsp vim
plugin to work with the openscad-lsp server, to the point where I installed
a Rust toolchain and the dev versions of all tools involved just so I could
add trace statements to understand what was going on and still coming up
short, I was reminded of those times the past where I tried to make vim do
things beyond what can be reasonably expected from it. Installing VS Code
and installing the vim mode and openscad LSP extensions took less than 10
minutes and worked out of the box (including library completions), so I
guess switching editors is the pragmatic solution.
James: I assume you're using openscad-lsp as the server from Emacs? Maybe
you already know, but you can pass --ignore-default to it to not auto
complete default arguments. Of course then you lose all arguments with
default values, i.e. you'll hardly get any arguments suggested any more.
regards
On Tue, Feb 18, 2025 at 8:51 PM James Larkby-Lahet jamesbuyacar@gmail.com
no, although the original poster is using vim. for the openscad editor i
think adding LSP support could be a reasonable way to get support for
arbitrary included files, not just BOSL.
although, I'm not a fan of the way emacs autopopulates parameter names
(with their default arguments) since it is common to ignore arguments in
scad. but I don't think that is inherent to the Language Server Protocol.
On Tue, Feb 18, 2025, 13:35 jon jonbondy.com jon@jonbondy.com wrote:
James:
Does this really apply to the editor that is built into OpenSCAD?
Thanks!
On 2/18/2025 11:19 AM, James Larkby-Lahet wrote:
I think all you need is an openscad LSP (language server) and an editor
with LSP support.
I use https://github.com/Leathong/openscad-LSP with emacs.
On Tue, Feb 18, 2025, 06:43 Jon Bondy via Discuss <
I use the built-in OpenSCAD editor, which has a kind of auto-complete.
Would it be possible to add BOSL2 features to that?
On 2/18/2025 5:00 AM, Roel Vanhout via Discuss wrote:
Hello all,
I was fed up yesterday with having to look up module signatures
names of arguments etc) so often, so I looked into setting up auto
complete (or at least completion suggestions and inline
inside Vim. This turned out to be quite a rabbit hole and a reminder
of why I no longer like to mess with convoluted setups, but after
reminding myself a few times to just get back to the basics and look
for a MVP only I now have a way where completion suggestions are read
from a simple text file (using vim-complete). So now all I need is a
list of openscad and BOSL2 modules and functions with their arguments
in a flat text file.
For openscad itself I can get away with just copy/pasting the
cheatsheet and fixing up manually as that pretty much covers my needs
for this specific use case, and that's a 10 minute job. For BOSL2
is obviously not an option because of the sheer amount of
functionality. So now my question is whether there is someone who's
already done something similar that I can leverage. BOSL2 seems to be
documented very cleanly and using a very strict format, so I could
just make a simple program to search for all lines that start with
'Usage:' and then read the next indented lines. Even if there would
some issues in the formatting here or there, a 90% solution would be
fine with me. But still, maybe there are already more robust and
elaborate solutions to this issue that I could either use, re-use or
contribute to? Thanks.
(I seem to remember this topic having come up on this list some years
ago but I can't seem to find it? Maybe I'm just not remembering right)
regards
Roel
you at all.
> regards
> On Tue, Feb 18, 2025 at 8:51 PM James Larkby-Lahet <jamesbuyacar@gmail.com>
>> On Tue, Feb 18, 2025, 13:35 jon jonbondy.com <jon@jonbondy.com> wrote:
>>> James:
>>> Thanks!
>>> Jon
>>> with LSP support.
>>>> Jon
>>>> > Hello all,
>>>> (exact
>>>> documentation)
>>>> this
>>>> be
>>>> > regards
>>>> > Roel
>>>> > _______________________________________________
>>>> > OpenSCAD mailing list
>>>> > To unsubscribe send an email to discuss-leave@lists.openscad.org
>>>> This email has been checked for viruses by AVG antivirus software.
>>>> www.avg.com
