Difference of valid objects not valid. Why?
Thu, May 14, 2020 2:45 PM
I wrote a routine to make round-edged holes in cylindrical shells.  For
example:
http://forum.openscad.org/file/t2477/ehole.png
It seems to work a lot of the time.  The above example renders without a
hitch.  But I have a mystery that sometimes I get a CGAL error.  What I
don't understand is that if I render the mask (the thing that I cut away to
make the hole) then CGAL issues no error and everything appears OK.  (The
mask is a union of two objects and I have also got a cube in there for good
measure, so CGAL is activated.)  The case I was really interested in was to
create a slot in a cylinder, so here is the mask, which renders OK:
http://forum.openscad.org/file/t2477/hmask.png
No CGAL error yet.  But when I difference it from the cylindrical shell as
follows, I get a CGAL error below.  I wonder about the "non coplanar faces".
I didn't think my model had any such thing.
PolySet has nonplanar faces. Attempting alternate construction
ERROR: CGAL error in CGALUtils::applyBinaryOperator difference: CGAL ERROR:
assertion violation! Expr: itl != it->second.end() File:
/mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_3/SNC_external_structure.h
Line: 1152
Geometries in cache: 19
Geometry cache size in bytes: 2719400
CGAL Polyhedrons in cache: 3
CGAL cache size in bytes: 43133288
Total rendering time: 0 hours, 1 minutes, 52 seconds
Simple: yes
Vertices: 264
Halfedges: 792
Edges: 396
Halffacets: 272
Facets: 136
Volumes: 3
Rendering finished.
Preview looks like this:
http://forum.openscad.org/file/t2477/cslot.png
So why can I take two valid objects, take their difference and the result is
invalid?  Under what circumstances can this occur?
Code that produces the examples:
include<BOSL2/std.scad>
include<BOSL2/skin.scad>
$fn=64;//4;//128;
function cylhole(r, path, offset=0) =
[for(point=path)
cylindrical_to_xyz(concat([r+offset],xscale(360/(2PIr),p=point)))];
// r is center radius of cylindrical shell, thickness is shell thickness,
path is path for hole to cut (2d)
module cylholemask(r,thickness,path)
cutout = cylhole(r,path);
cutout_tangent = path_tangents(cutout);
cutout_normal = [for(i=idx(cutout)) cross(cutout_tangent[i], [cutout[i].x,
cutout[i].y,0])];
minangle = min(subindex(path,0))360/(2PIr);
maxangle = max(subindex(path,0))360/(2PI
r);
innerplane1 = plane_from_points(
[(r-thickness/2)[cos(minangle), sin(minangle),0],
(r-thickness/2)
[cos(minangle), sin(minangle),1],
(r-thickness/2)*[cos(maxangle), sin(maxangle),0]]);
outerplane = concat(select(innerplane1,0,2), [r+thickness]);
innerplane = concat(select(innerplane1,0,2), [innerplane1[3]-thickness]);
farpts = scale([1.1,1.1,1],p=cutout);
inner = [for(i=idx(cutout)) plane_line_intersection(innerplane,
[farpts[i],cutout[i]])];
outer = [for(i=idx(cutout)) plane_line_intersection(outerplane,
skin([inner, outer], slices=0,convexity=10);
path_sweep((cmask(thickness/2)), cutout, closed=true, method="manual",
normal=cutout_normal);
function cmask(r) =
let(eps=0.1)
fwd(r+.01,p=
[r+eps,0],
each arc(r=r, angle=[0, 180]),
[-r-eps,0],
[-r-eps, r+eps],
[r+eps, r+eps]
slot=reverse(turtle(["move",4,"arcleft", .5, "move", 5, "arcright", 1,
"arcleft", .5,180, "move", 3+4,
"arcleft", .5, 180, "arcright", 1, "move", 5,
"arcleft",.5]));
up(1.25)cyl(r=10.5, h=10);
up(1.25)cyl(r=9.5, h=11);
cylholemask(10,1.05, subdivide_path(simplify_path(slot),475,exact=false));
// This fails
//  cylholemask(10, 1.05, apply(xscale(3),circle(r=3, $fn=128)));    // This
works
right(75)cube([1,1,1]);
I wrote a routine to make round-edged holes in cylindrical shells. For example: <http://forum.openscad.org/file/t2477/ehole.png> It seems to work a lot of the time. The above example renders without a hitch. But I have a mystery that sometimes I get a CGAL error. What I don't understand is that if I render the mask (the thing that I cut away to make the hole) then CGAL issues no error and everything appears OK. (The mask is a union of two objects and I have also got a cube in there for good measure, so CGAL is activated.) The case I was really interested in was to create a slot in a cylinder, so here is the mask, which renders OK: <http://forum.openscad.org/file/t2477/hmask.png> No CGAL error yet. But when I difference it from the cylindrical shell as follows, I get a CGAL error below. I wonder about the "non coplanar faces". I didn't think my model had any such thing. Rendering Polygon Mesh using CGAL... PolySet has nonplanar faces. Attempting alternate construction ERROR: CGAL error in CGALUtils::applyBinaryOperator difference: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: /mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_3/SNC_external_structure.h Line: 1152 Geometries in cache: 19 Geometry cache size in bytes: 2719400 CGAL Polyhedrons in cache: 3 CGAL cache size in bytes: 43133288 Total rendering time: 0 hours, 1 minutes, 52 seconds Top level object is a 3D object: Simple: yes Vertices: 264 Halfedges: 792 Edges: 396 Halffacets: 272 Facets: 136 Volumes: 3 Rendering finished. Preview looks like this: <http://forum.openscad.org/file/t2477/cslot.png> So why can I take two valid objects, take their difference and the result is invalid? Under what circumstances can this occur? Code that produces the examples: include<BOSL2/std.scad> include<BOSL2/skin.scad> $fn=64;//4;//128; function cylhole(r, path, offset=0) = [for(point=path) cylindrical_to_xyz(concat([r+offset],xscale(360/(2*PI*r),p=point)))]; // r is center radius of cylindrical shell, thickness is shell thickness, path is path for hole to cut (2d) module cylholemask(r,thickness,path) { cutout = cylhole(r,path); cutout_tangent = path_tangents(cutout); cutout_normal = [for(i=idx(cutout)) cross(cutout_tangent[i], [cutout[i].x, cutout[i].y,0])]; minangle = min(subindex(path,0))*360/(2*PI*r); maxangle = max(subindex(path,0))*360/(2*PI*r); innerplane1 = plane_from_points( [(r-thickness/2)*[cos(minangle), sin(minangle),0], (r-thickness/2)*[cos(minangle), sin(minangle),1], (r-thickness/2)*[cos(maxangle), sin(maxangle),0]]); outerplane = concat(select(innerplane1,0,2), [r+thickness]); innerplane = concat(select(innerplane1,0,2), [innerplane1[3]-thickness]); farpts = scale([1.1,1.1,1],p=cutout); inner = [for(i=idx(cutout)) plane_line_intersection(innerplane, [farpts[i],cutout[i]])]; outer = [for(i=idx(cutout)) plane_line_intersection(outerplane, [farpts[i],cutout[i]])]; skin([inner, outer], slices=0,convexity=10); path_sweep((cmask(thickness/2)), cutout, closed=true, method="manual", normal=cutout_normal); } function cmask(r) = let(eps=0.1) fwd(r+.01,p= [ [r+eps,0], each arc(r=r, angle=[0, 180]), [-r-eps,0], [-r-eps, r+eps], [r+eps, r+eps] ]); slot=reverse(turtle(["move",4,"arcleft", .5, "move", 5, "arcright", 1, "arcleft", .5,180, "move", 3+4, "arcleft", .5, 180, "arcright", 1, "move", 5, "arcleft",.5])); difference(){ up(1.25)cyl(r=10.5, h=10); up(1.25)cyl(r=9.5, h=11); cylholemask(10,1.05, subdivide_path(simplify_path(slot),475,exact=false)); // This fails // cylholemask(10, 1.05, apply(xscale(3),circle(r=3, $fn=128))); // This works } right(75)cube([1,1,1]); -- Sent from: http://forum.openscad.org/
arnholm@arnholm.org
Thu, May 14, 2020 3:16 PM
ERROR:
Looks like you have non-triangular faces, since it is impossible to have
nonplanar triangles. Try exporting the parts to e.g. STL or other format
that requires triangles.
On 2020-05-14 16:45, adrianv wrote: > Rendering Polygon Mesh using CGAL... > PolySet has nonplanar faces. Attempting alternate construction > ERROR: CGAL error in CGALUtils::applyBinaryOperator difference: CGAL > ERROR: Looks like you have non-triangular faces, since it is impossible to have nonplanar triangles. Try exporting the parts to e.g. STL or other format that requires triangles. Carsten Arnholm
Thu, May 14, 2020 4:18 PM
The fact it converts to PolySet and back can corrupt valid CGAL
geometry because it goes from CGAL rationals to double with a snap to a
grid. You simply can't have vertices that are so close they merge when
snapped.
ERROR:
The fact it converts to PolySet and back can corrupt valid CGAL geometry because it goes from CGAL rationals to double with a snap to a grid. You simply can't have vertices that are so close they merge when snapped. On Thu, 14 May 2020 at 16:17, <arnholm@arnholm.org> wrote: > On 2020-05-14 16:45, adrianv wrote: > > Rendering Polygon Mesh using CGAL... > > PolySet has nonplanar faces. Attempting alternate construction > > ERROR: CGAL error in CGALUtils::applyBinaryOperator difference: CGAL > > ERROR: > > Looks like you have non-triangular faces, since it is impossible to have > nonplanar triangles. Try exporting the parts to e.g. STL or other format > that requires triangles. > > Carsten Arnholm > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Thu, May 14, 2020 9:55 PM
Some non-manifold objects boolean operated with a cube may render without
any issue depending where the cube is:
v = [ [0,0, 0], [10,0, 0], [10,10, 0], [0,10, 0],
[0,0,10], [10,0,10], [10,10,10], [0,10,10],
[5,11,10] ];
f = [ [0,1,2,3], [1,0,4,5], [2,1,5,6], [3,2,6,7], [0,3,7,4],
[7,8,6,5,4], [6,8,7]  ];
union(){
polyhedron(v, f);
//translate([5,11,10])
cube(3,center=true);
That will render fine although the polyhedron is not a manifold. Add the
translation and CGAL complains.
In a boolean operation, CGAL only needs to make local changes. If
everything is nice there, it concludes its task without looking elsewhere.
But I have a mystery that sometimes I get a CGAL error. What I > don't understand is that if I render the mask (the thing that I cut away to > make the hole) then CGAL issues no error and everything appears OK. (The > mask is a union of two objects and I have also got a cube in there for good > measure, so CGAL is activated.) > Some non-manifold objects boolean operated with a cube may render without any issue depending where the cube is: v = [ [0,0, 0], [10,0, 0], [10,10, 0], [0,10, 0], [0,0,10], [10,0,10], [10,10,10], [0,10,10], [5,11,10] ]; f = [ [0,1,2,3], [1,0,4,5], [2,1,5,6], [3,2,6,7], [0,3,7,4], [7,8,6,5,4], [6,8,7] ]; union(){ polyhedron(v, f); //translate([5,11,10]) cube(3,center=true); } That will render fine although the polyhedron is not a manifold. Add the translation and CGAL complains. In a boolean operation, CGAL only needs to make local changes. If everything is nice there, it concludes its task without looking elsewhere.
Fri, May 15, 2020 12:38 AM
The problem of CGAL objecting to my model doesn't seem to be specifically
correlated to the non-coplanar faces that it notes.  I changed the model a
bit and that went away.  I also tried explicitly triangulating the only
faces that aren't triangles.  (Note that these faces were constructed by
intersecting lines with a plane, so they can't be non-coplanar.)  None of
this fixed anything.
It seems like the issue of rounding gets raised repeatedly as an explanation
for CGAL errors, generally in situations where it is not relevant.  I did
finally encounter this, so it does actually happen.  It happens in one of
my models when points are closer together in my model than 1.3e-6.  The
model above has a modest spacing of facets and shouldn't have any points so
close together.  (And yes, if I increase the points to larger than 1.3e-6,
like say 1.4e-6 then the CGAL error in that case vanishes.)
I'm kind of puzzled about when/how CGAL decides to examine my shape, though.
I tried unioning my mask shape with a cube and got the CGAL error.  But my
mask shape is already the union of two shapes that overlap each other.  Why
doesn't this trigger a CGAL evaluation and the error?  Why do I have to
separately union with a cube to get the error?  In any case, this produces a
better explanation of what is going wrong: something is somehow amiss with
the polyhedron that defines my roundover.  The other shape (which cuts the
hole) doesn't seem to produce the error when unioned with a cube.
The problem of CGAL objecting to my model doesn't seem to be specifically correlated to the non-coplanar faces that it notes. I changed the model a bit and that went away. I also tried explicitly triangulating the only faces that aren't triangles. (Note that these faces were constructed by intersecting lines with a plane, so they can't be non-coplanar.) None of this fixed anything. It seems like the issue of rounding gets raised repeatedly as an explanation for CGAL errors, generally in situations where it is not relevant. I did finally encounter this, so it does actually happen. It happens in one of my models when points are closer together in my model than 1.3e-6. The model above has a modest spacing of facets and shouldn't have any points so close together. (And yes, if I increase the points to larger than 1.3e-6, like say 1.4e-6 then the CGAL error in that case vanishes.) I'm kind of puzzled about when/how CGAL decides to examine my shape, though. I tried unioning my mask shape with a cube and got the CGAL error. But my mask shape is already the union of two shapes that overlap each other. Why doesn't this trigger a CGAL evaluation and the error? Why do I have to separately union with a cube to get the error? In any case, this produces a better explanation of what is going wrong: something is somehow amiss with the polyhedron that defines my roundover. The other shape (which cuts the hole) doesn't seem to produce the error when unioned with a cube. -- Sent from: http://forum.openscad.org/
Fri, May 15, 2020 8:44 AM
CGAL works fine with close vertices, so if the result of a union or
difference yields close vertices it will give a correct result in its nef
polyhedron form. OpenSCAD then converts it to is own PolySet format which
is a polygon soup, like STL is a triangle soup. It also truncates to
doubles and snaps to a grid, so it breaks the topology. If it then converts
it back to a nef polyhedron and passes it back to CGAL which will throw an
exception.
explanation
though.
a
CGAL works fine with close vertices, so if the result of a union or difference yields close vertices it will give a correct result in its nef polyhedron form. OpenSCAD then converts it to is own PolySet format which is a polygon soup, like STL is a triangle soup. It also truncates to doubles and snaps to a grid, so it breaks the topology. If it then converts it back to a nef polyhedron and passes it back to CGAL which will throw an exception. On Fri, 15 May 2020 at 01:39, adrianv <avm4@cornell.edu> wrote: > The problem of CGAL objecting to my model doesn't seem to be specifically > correlated to the non-coplanar faces that it notes. I changed the model a > bit and that went away. I also tried explicitly triangulating the only > faces that aren't triangles. (Note that these faces were constructed by > intersecting lines with a plane, so they can't be non-coplanar.) None of > this fixed anything. > > It seems like the issue of rounding gets raised repeatedly as an > explanation > for CGAL errors, generally in situations where it is not relevant. I did > finally encounter this, so it does actually happen. It happens in one of > my models when points are closer together in my model than 1.3e-6. The > model above has a modest spacing of facets and shouldn't have any points so > close together. (And yes, if I increase the points to larger than 1.3e-6, > like say 1.4e-6 then the CGAL error in that case vanishes.) > > I'm kind of puzzled about when/how CGAL decides to examine my shape, > though. > I tried unioning my mask shape with a cube and got the CGAL error. But my > mask shape is already the union of two shapes that overlap each other. Why > doesn't this trigger a CGAL evaluation and the error? Why do I have to > separately union with a cube to get the error? In any case, this produces > a > better explanation of what is going wrong: something is somehow amiss with > the polyhedron that defines my roundover. The other shape (which cuts the > hole) doesn't seem to produce the error when unioned with a cube. > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Rob Ward
Fri, May 15, 2020 11:43 AM
So what I think is happening here is that if the CGAL can produce pixels, just like .STL produces filament, then job done?
Cheers, RobW
nef
which
converts
an
exception.
specifically
model a
only
constructed by
None of
explanation
did
one of
The
points so
1.3e-6,
though.
But my
other.  Why
to
produces
a
with
cuts the
So what I think is happening here is that if the CGAL can produce pixels, just like .STL produces filament, then job done? Cheers, RobW On 15 May 2020 6:44:34 pm AEST, nop head <nop.head@gmail.com> wrote: >CGAL works fine with close vertices, so if the result of a union or >difference yields close vertices it will give a correct result in its >nef >polyhedron form. OpenSCAD then converts it to is own PolySet format >which >is a polygon soup, like STL is a triangle soup. It also truncates to >doubles and snaps to a grid, so it breaks the topology. If it then >converts >it back to a nef polyhedron and passes it back to CGAL which will throw >an >exception. > >On Fri, 15 May 2020 at 01:39, adrianv <avm4@cornell.edu> wrote: > >> The problem of CGAL objecting to my model doesn't seem to be >specifically >> correlated to the non-coplanar faces that it notes. I changed the >model a >> bit and that went away. I also tried explicitly triangulating the >only >> faces that aren't triangles. (Note that these faces were >constructed by >> intersecting lines with a plane, so they can't be non-coplanar.) >None of >> this fixed anything. >> >> It seems like the issue of rounding gets raised repeatedly as an >> explanation >> for CGAL errors, generally in situations where it is not relevant. I >did >> finally encounter this, so it does actually happen. It happens in >one of >> my models when points are closer together in my model than 1.3e-6. >The >> model above has a modest spacing of facets and shouldn't have any >points so >> close together. (And yes, if I increase the points to larger than >1.3e-6, >> like say 1.4e-6 then the CGAL error in that case vanishes.) >> >> I'm kind of puzzled about when/how CGAL decides to examine my shape, >> though. >> I tried unioning my mask shape with a cube and got the CGAL error. >But my >> mask shape is already the union of two shapes that overlap each >other. Why >> doesn't this trigger a CGAL evaluation and the error? Why do I have >to >> separately union with a cube to get the error? In any case, this >produces >> a >> better explanation of what is going wrong: something is somehow amiss >with >> the polyhedron that defines my roundover. The other shape (which >cuts the >> hole) doesn't seem to produce the error when unioned with a cube. >> >> >> >> -- >> Sent from: http://forum.openscad.org/ >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>
