I just found out extrusion of a loop using hull. It's very cool. Openscad is
so awesome, that 3 lines can litteraly make a polygon extrusion code which
took me 2 days to code in triangles arrays.
So, the hull can't handle 2d polygons. Damn, it processes twice as many
vertices, yes it's kindof slow.
So the solution would be to take the polygons, and generate a new set of
quads joining every 2 points in the polygon. perhaps is possible. will see.
it's the best solution currently.
View this message in context: http://forum.openscad.org/3d-hull-with-2d-primitives-needed-tp5845p14235.html
Ok, so some digging around has revealed a gem called runsun's faces.scad
toolkit with chain polygons module...
Chain takes a set of polygons and chains them togeter same as extrude. it's
exactly what we need.
I'm checking out how easy it is to take an array of matrix positions of
cubes, and use squares instead to extrude that. Not that trivial, however
someone with a less zombie brain than me can probably figure out the handles
to change the array of polygons into an array of multimatrix rotations. hm.
cool code. it's here:
https://raw.githubusercontent.com/runsun/faces.scad/master/faces.scad
View this message in context: http://forum.openscad.org/3d-hull-with-2d-primitives-needed-tp5845p14237.html
I check the code and currently, only 2d vector is used for hull if the first
children is a 2D primitive, even if the 2D primitive is transform and not
more in XY plane.
For example:
The second circle is no more in XY plane.
It has 3D coordinates (display is fine) but only [x,y] is used, like a
projection, in hull.
Why ?
A 2D primitive that is no more in XY plane should be used as a 3D in hull or
other built-in modules.
You could also use linerar_extrude(0.1) <2D primitive>(...) to get a thin 3D
object from 2D primitive.
Rq: projection(cut = false) rotate([45,0,0]) circle2(5); do nothing
a+
Vicnet
View this message in context: http://forum.openscad.org/3d-hull-with-2d-primitives-needed-tp5845p14276.html
This code creates an ellipsoid out of individual triangles - not those 2D
primitives you find described in the manual, as these are not compatible
with CGAL in a 3D environment. Rather, my 2D primitives use an undocumented
property of polyhedron().
I'll leave the comments in, this is experimental and unfinished code . . .
http://forum.openscad.org/file/n14292/Ellipsoid.ellipsoid When finished,
I intend to submit the code to the team to be implemented as a variant of
surface(). That should improve rendering speed, which is rather slow
currently.
Wolf
a=30; b=20; c=10; //half-axes of ellipse
Step=10;
StartVal_u=0; EndVal_u=360; // 10 seconds, 1224 facets, 614 vertices, 2
volumes
StartVal_v=0; EndVal_v=180;
//StartVal_u=10; EndVal_u=360; // 10 seconds, 1190 facets, 614
vertices, 1 volumes
//StartVal_v=0; EndVal_v=180;
//scale([a,b,c]) sphere(1,$fn=51); // used in debugging
for (v=[StartVal_v+Step/2:Step:EndVal_v]) for
(u=[StartVal_u+Step/2:Step:EndVal_u]) SurfaceElement(u,v);
module SurfaceElement(u,v)
{ Center=P(u,v); // centre vector for SurfaceElement()
P0=P(u-Step/2,v-Step/2); // corner vector for SurfaceElement()
P1=P(u+Step/2,v-Step/2); // corner vector for SurfaceElement()
P2=P(u+Step/2,v+Step/2); // corner vector for SurfaceElement()
P3=P(u-Step/2,v+Step/2); // corner vector for SurfaceElement()
// translate(Center) color("magenta") cube([.3,.3,.3], center=true);
// translate(P0) color("red") cube([.3,.3,.03],
center=true); // used in debugging
// translate(P1) color("white") cube([.3,.3,.03],
// translate(P2) color("green") cube([.3,.3,.03],
// translate(P3) color("yellow") cube([.3,.3,.03],
// polygon(P0,P1,P2); // accepts only 2-vectors
// polygon(P0,P2,P3); // accepts only 2-vectors
if(P0 != P1 && P1 != P2) color("red") polyhedron
(points=[P0,P1,P2], faces=[[0,1,2]]);
if(P0 != P2 && P2 != P3) color("yellow") polyhedron
(points=[P0,P2,P3], faces=[[0,1,2]]);
// CGAL does'nt like degenerate faces!
// polyhedron (points=[P0,P1,P2,P3], faces=[[0,1,2,3]]); // non-planar
face, CGAl complains
// echo(u-Step/2,u+Step/2,v-Step/2,v+Step/2,P0,P1,P2,P3,Center);
function P(u,v)=[a*cos(u)sin(v),bsin(u)sin(v),ccos(v)]; //point on
the surface of an ellipsoid
View this message in context: http://forum.openscad.org/3d-hull-with-2d-primitives-needed-tp5845p14292.html
Hi Wolf: nice work. If I remember correctly this was not allowed in older
versions.
Why dont you remove the debugging and and post your code into a new thread?
2015-11-06 20:56 GMT+01:00 wolf wv99999@gmail.com:
finished,
currently.
Wolf
Step=10;
2
volumes
vertices, 1 volumes
center=true);
I tried Wolf's ellipsoid in OpenSCAD 2014.03, and got a lot of CGAL
assertion errors.
Those error messages went away in OpenSCAD 2015.03. However, when I tried
to intersect the ellipsoid with a cylinder, I got garbage results, and a
message indicating that my object is non-manifold.
Wolf's program is not a valid OpenSCAD program, and does not construct a
valid 3D shape. I consider it a bug that there are no error messages in
OpenSCAD 2015.03 until you try to apply a geometric operation to the
ellipsoid.
finished,
currently.
Wolf
Step=10;
2
volumes
vertices, 1 volumes
center=true);
From a constracten point of view, it would be nice if OpneSCAD would allow
the piecewise construction of polyhedron.
When you do e.g. a extrusion along a path, it would be easier to have 3 for
loop: for the top, the side, and the button.
Mybe with a syntax like:
polyhedron(...);
continue_polyhedron(...);
2015-11-08 17:00 GMT+01:00 doug moen doug@moens.org:
assertion errors.
ellipsoid.
undocumented
finished,
currently.
Wolf
Step=10;
vertices, 2
volumes
vertices, 1 volumes
SurfaceElement()
SurfaceElement()
SurfaceElement()
SurfaceElement()
SurfaceElement()
center=true);
Polyhedron takes lists and lists can be created with for loops in recent
versions of OpenScad, so you can do exactly that without new syntax.
On 8 November 2015 at 19:03, Peter Falke <
for loop: for the top, the side, and the button.
polyhedron(...);
assertion errors.
ellipsoid.
undocumented
finished,
currently.
Wolf
Step=10;
vertices, 2
volumes
vertices, 1 volumes
SurfaceElement()
SurfaceElement()
SurfaceElement()
SurfaceElement()
SurfaceElement()
center=true);
non-planar
