This time I have an interesting syntax question. I'm building a small library
of bits I find useful and in the manner of such libraries more complex parts
build on simpler parts.
Even the simple part may have a good few parameters. For example:
module simple_thing(p1, p2, p3, p4, p5, p6) { }
Now I want to build on that, create a richer model of something bigger and
more complicated and I want to bundle these parameters into a vector
something like this:
module bigger_thing(simple_thing_ps, pp11, pp2) { }
where:
simple_thing_ps = [p1, p2, p3, p4, p5, p6]
that is, the simple thing parameters bundled up. In this bigger module now I
can include a simple thing like so quite easily:
simple_thing(simple_thing_ps[0],
simple_thing_ps[1],simple_thing_ps[2],
simple_thing_ps[3],simple_thing_ps[4], simple_thing_ps[5]);
// do more stuff
But wow that is clumsy. Now I'm familiar with Python and it has a beautiful
syntax for unpacking lists like this, so that I could write something like:
simple_thing(unpack(simple_thing_ps));
// do more stuff
Not only terser and nicer, the new module no longer needs to know how long
simple_thing_ps is. In Python that unpack operarator is just *, such that
the if the v = [p1, p2, p3], then *v = p1, p2, p3 and I'd call
simple_thing(*v) to have the list unpacked into individual parameters that
simple thing sees.
Of course one solution is to write simple_thing so it takes a single vector
parameter which it unpacks internally into parameters. But that too is
clumsy, as it means anyone using simple_thing has an odd syntax to contend
with.
I've had a look at "each" which tantalisingly close and may even be able to
do this, I just haven't figured outhow yet.
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/List_Comprehensions#each
All the examples are generating lists, rather than unpacking them. There's a
solid chance that unpack simply isn't possible.
Perhaps one smart flexible way to write it is to have simple_thing check if
it has only one vector as a parameter, and if so unpack it internally else
use the parameters themselves.
module simple_thing(p, p2, p3, p4, p5, p6) {
if (is_list(p) && is_undef(p2)
&& is_undef(p3)
&& is_undef(p4)
&& is_undef(p5)
&& is_undef(p6) ) {
p1 = p[0];
p2 = p[1];
p3 = p[2];
p4 = p[3];
p5 = p[4];
p6 = p[5];
} else {
p1 = p
While a little wordy it's contain in simple_thing and allows using it
normally and tersely in bigger things. It just gets a little hairier if some
or all of the parameters have default values and if p is expected to be a
list anyhow etc.
Wonder if there's a more elegant solution?
Regards,
Bernd.
I'd make a
module simple_thing_v (pv) // simple thing with a vector for the parameters.
simple_thing (pv[1], pv[2], pv[3], pv[4], pv[5]);
Functions with alternative parameter sets are harder to write and clumsy to
read. When possible, avoid it. If needed, define clear precedence rules.
What would be the result of your last code for a call like:
simple_thing([1, 2], 3) ;
to
Harder to write, absolutely. Careful parameter checking is necessary. In
the posted example I would check that either all five parameters are defined
or only the first one is defined. Otherwise, issue an error. And then if
you have one parameter, split it with a recursive call.
But clumsy to read? I disagree. What's clumsy to read (and write in my
code) are a bunch of calls where you have to use double delimiters so you
have
foobar([v1,v2,v3]);
baz([v2,v3]);
instead of simply
foobar(v1,v2,v3);
baz(v2,v3);
have
I understand your point but I was referring to the function code reading
not its call.
I prefer to represent objects by named lists of properties and pass that as
the first parameter to all functions and module that operate on them. That
keeps the code clean and backwards compatible. I.e. I can add more
properties to the list and it does not affect clients of the library as
they still pass the same named object, with no care of what it is.
The only advantage of using module parameters is they can be set by name
and have defaults, whereas my lists are all initialised by position. That
could be solved by having a separate constructor function with an argument
per property to make the lists. However since the lists are hidden away in
the library, each in their own file, there would be little benefit.
There are a few objects that are defined in the client code. Mainly
customisable printed objects like cases. This discussion has prompted me to
think they should have constructor functions to better isolate the client
code from changes to the library.
On Wed, 29 Apr 2020 at 12:26, Ronaldo Persiano rcmpersiano@gmail.com
have
not its call.
