Re: [OpenSCAD] New site for "omdl" (A Mechanical Design Library)
royasutton
Wed, Apr 12, 2017 12:46 PM
There were many name changes between the time of the above example and
v0.6.1. I try to be responsible in the commit descriptions to warn of such
changes. The commit logs can be reviewed at the development repository (
here https://github.com/royasutton/omdl/commits/master  ).
For v0.6.1 the following should get you going.
More Info: A distinction was made between vectors and lists. This change
effects several functions and parameter names. A set of assumptions and
conventions have been added to v0.6.1. They can be found in the "Related
Pages" tab of the documentation under "Data types."
Roy
View this message in context: http://forum.openscad.org/New-site-for-omdl-A-Mechanical-Design-Library-tp20312p21208.html
There were many name changes between the time of the above example and v0.6.1. I try to be responsible in the commit descriptions to warn of such changes. The commit logs can be reviewed at the development repository ( here <https://github.com/royasutton/omdl/commits/master> ). For v0.6.1 the following should get you going. *More Info:* A distinction was made between vectors and lists. This change effects several functions and parameter names. A set of assumptions and conventions have been added to v0.6.1. They can be found in the "Related Pages" tab of the documentation under "Data types." Roy -- View this message in context: http://forum.openscad.org/New-site-for-omdl-A-Mechanical-Design-Library-tp20312p21208.html Sent from the OpenSCAD mailing list archive at Nabble.com.
