I Have now managed to get some actual openscad output using the first class feature into the CSG tree and am sure now this would be a very useful feature.
The example demonstrates putting modules in an array and returning from function.(Full code available to view here https://github.com/kwikius/openscad/blob/WIP-first-class-module/tests/data/scad/experimental/first_class_module/module_array.scad) ( pic of output attached)
// Example put modules in array and return modules from function
geometry = [
// [rotation , translation , module name ]
[[0,0,0], [0,0,0], module my_sphere],
[[0,45,0],[0,2.5 * rscale,0], module my_cylinder],
[[45,45,0],[0,-2.5 * rscale,0], module my_cube]
instantiate the modules defined in the geometry array
for ( i = [0 :1: 2]){
translate(get_translation(geometry,i)){
rotate(get_rotation(geometry,i)){
modalias = get_module(geometry,i); // module return from function
modalias(); // instantiate the module
The source code for the executable is on the WIP-first-class-module branch if you want to try it:w
https://github.com/kwikius/openscad/tree/WIP-first-class-module
though it won’t use arguments yet, apart from in the way described belo
I found the following syntax useful
my_cube = module cube; // alias the builtin cube
Where there are no arguments, the arguments in the instantiation call are simply passed through to the module.
my_cube([1,2,3],center = true);
looking to implement parameters and arguments next.
geometry = [
[https://github.com/kwikius/openscad/tree/WIP-first-class-module](https://github.com/kwikius/openscad/tree/WIP-first-class-module "WIP-first-class-module")
