Has scientific notation being change from e+0n to e+00n ?
runsun
Fri, Nov 4, 2016 3:25 AM
I start using the snapshot version 2016.10.04 (git 7e0935d) on windows 64 and
found one of my tests about scientific notation failed:
str(1234560) want: "1.23456e+06" got: "1.23456e+006"
i.e., e+06 now becomes e+006
Is this an intended outcome, or something else happened ?
$  Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), synwrite ( 2 );   $ tips: hash ( 2 ), matrix ( 2 , 3 ), sweep ( 2 , 3 ), var ( 2 ), lerp , animation ( gif , prodVid , animlib ), precision ( 2 ), xl-control , type , rounded polygon , chfont , tailRecur ( 2, 3 ), isosphere ( 2 ), area , vol/center , RGB , CurvedImg , tests ( 2 ); $ Apps: rollApp , blockscad , openjscad , on AWS ( pdf )
View this message in context: http://forum.openscad.org/Has-scientific-notation-being-change-from-e-0n-to-e-00n-tp18928.html
I start using the snapshot version 2016.10.04 (git 7e0935d) on windows 64 and found one of my tests about scientific notation failed: str(1234560) want: "1.23456e+06" got: "1.23456e+006" i.e., e+06 now becomes e+006 Is this an intended outcome, or something else happened ? ----- $ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), synwrite ( 2 );   $ tips: hash ( 2 ), matrix ( 2 , 3 ), sweep ( 2 , 3 ), var ( 2 ), lerp , animation ( gif , prodVid , animlib ), precision ( 2 ), xl-control , type , rounded polygon , chfont , tailRecur ( 2, 3 ), isosphere ( 2 ), area , vol/center , RGB , CurvedImg , tests ( 2 ); $ Apps: rollApp , blockscad , openjscad , on AWS ( pdf ) -- View this message in context: http://forum.openscad.org/Has-scientific-notation-being-change-from-e-0n-to-e-00n-tp18928.html Sent from the OpenSCAD mailing list archive at Nabble.com.
RU
Richard Urwin
Fri, Nov 4, 2016 9:54 AM
While changing stuff isn't optimal, I would note that the maximum exponent
representable in 64-bit floating point is E+307. Three digits therefore
appears necessary. Personally, I'd ditch the leading zeros.
and
While changing stuff isn't optimal, I would note that the maximum exponent representable in 64-bit floating point is E+307. Three digits therefore appears necessary. Personally, I'd ditch the leading zeros. On Fri, Nov 4, 2016 at 3:25 AM, runsun <runsun@gmail.com> wrote: > I start using the snapshot version 2016.10.04 (git 7e0935d) on windows 64 > and > found one of my tests about scientific notation failed: > > str(1234560) want: "1.23456e+06" got: "1.23456e+006" > > i.e., e+06 now becomes e+006 > > Is this an intended outcome, or something else happened ? > > > > ----- > > $ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), > runscad.py ( 2 , git ), synwrite ( 2 ); &nbsp; $ tips: hash ( 2 ), matrix ( > 2 , 3 ), sweep ( 2 , 3 ), var ( 2 ), lerp , animation ( gif , prodVid , > animlib ), precision ( 2 ), xl-control , type , rounded polygon , chfont , > tailRecur ( 2, 3 ), isosphere ( 2 ), area , vol/center , RGB , CurvedImg , > tests ( 2 ); $ Apps: rollApp , blockscad , openjscad , on AWS ( pdf ) > -- > View this message in context: http://forum.openscad.org/Has- > scientific-notation-being-change-from-e-0n-to-e-00n-tp18928.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Fri, Nov 4, 2016 11:45 AM
Von: runsun runsun@gmail.com
I'm not aware of any changes, this might be a platform issue.
Von: runsun <runsun@gmail.com> > i.e., e+06 now becomes e+006 > Is this an intended outcome, or something else happened ? > I'm not aware of any changes, this might be a platform issue. ciao, Torsten.
Fri, Nov 4, 2016 11:58 AM
2015.03-2/64 on W7/64 does ECHO: "1.23456e+006"
As does 2016.10.05
View this message in context: http://forum.openscad.org/Has-scientific-notation-being-change-from-e-0n-to-e-00n-tp18928p18934.html
2015.03-2/64 on W7/64 does ECHO: "1.23456e+006" As does 2016.10.05 ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Has-scientific-notation-being-change-from-e-0n-to-e-00n-tp18928p18934.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Fri, Nov 4, 2016 2:41 PM
It’s not intended, but it’s also not a format we’re trying to control.
FYI: The test suite will detect such changes and there hasn’t been any changes on Linux or Mac. Alas, we don’t have a setup for running automated tests on Windows, and I don’t think there are any devs who do that manually either (mostly because we don’t have any devs which are using Windows as a primary OS).
> On Nov 3, 2016, at 23:25, runsun <runsun@gmail.com> wrote: > > Is this an intended outcome, or something else happened ? > It’s not intended, but it’s also not a format we’re trying to control. FYI: The test suite will detect such changes and there hasn’t been any changes on Linux or Mac. Alas, we don’t have a setup for running automated tests on Windows, and I don’t think there are any devs who do that manually either (mostly because we don’t have any devs which are using Windows as a primary OS). -Marius
runsun
Fri, Nov 4, 2016 4:18 PM
Most likely a platform thing (my previous tests were carried out in Linux
64bit). Thx guys.
View this message in context: http://forum.openscad.org/Has-scientific-notation-being-change-from-e-0n-to-e-00n-tp18928p18936.html
Most likely a platform thing (my previous tests were carried out in Linux 64bit). Thx guys. ----- $ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), synwrite ( 2 ); &nbsp; $ tips: hash ( 2 ), matrix ( 2 , 3 ), sweep ( 2 , 3 ), var ( 2 ), lerp , animation ( gif , prodVid , animlib ), precision ( 2 ), xl-control , type , rounded polygon , chfont , tailRecur ( 2, 3 ), isosphere ( 2 ), area , vol/center , RGB , CurvedImg , tests ( 2 ); $ Apps: rollApp , blockscad , openjscad , on AWS ( pdf ) -- View this message in context: http://forum.openscad.org/Has-scientific-notation-being-change-from-e-0n-to-e-00n-tp18928p18936.html Sent from the OpenSCAD mailing list archive at Nabble.com.
