how to speed up minkowski
K
ken@volksswitch.org
Wed, Aug 8, 2018 5:37 PM
$fn=50;
length = 25;
finger_pull_radius = 5;
thickness = 3;
minkowski(){
                            hull(){
                                            //grip
translate([length+finger_pull_radius, 0, 0])
                                            cylinder(h=thickness, r=10,
center = true);
                                            //base
                                            cube([10,5,thickness],
center=true);
                            cylinder(h=thickness+0.01, r=5, center =
true);
sphere(r=1);
How can I speed up the process?
Thanks,
Ken
$fn=50; length = 25; finger_pull_radius = 5; thickness = 3; minkowski(){ difference(){ hull(){ //grip translate([length+finger_pull_radius, 0, 0]) cylinder(h=thickness, r=10, center = true); //base cube([10,5,thickness], center=true); } translate([length+finger_pull_radius, 0, 0]) cylinder(h=thickness+0.01, r=5, center = true); } sphere(r=1); } How can I speed up the process? Thanks, Ken
S
shadowwynd
Wed, Aug 8, 2018 6:25 PM
The only way in your code is to decrease $fn only for the sphere you are
using for the minkowski operation.
Like this:
sphere (r=1, $fn=10);
Increase it in very small increments - you are trading off processor time
for smoothness, as it were.  Depending on the size of a 3D printed part, you
may not see the extra smoothness of a high $fn value.
For example, your code with the the above modification took about 20 seconds
on my PC, and your original code is still spinning.
The only way in your code is to decrease $fn only for the sphere you are using for the minkowski operation. Like this: sphere (r=1, $fn=10); Increase it in very small increments - you are trading off processor time for smoothness, as it were. Depending on the size of a 3D printed part, you may not see the extra smoothness of a high $fn value. For example, your code with the the above modification took about 20 seconds on my PC, and your original code is still spinning. -- Sent from: http://forum.openscad.org/
