Hello,
first time i try this, and i don't seem to get it to work....
i forgot to take my laptop with me, and am stuck with an android tablet :'(
so i tryed to run the thing through a ssh shell, but somehow, even after
re-reading the doc, i don't understand what's happening or where i went
wrong:
bboett@hayate:~/3dmodel$ openscad-nightly -v
OpenSCAD version 2021.08.24.nightly
bboett@hayate:~/3dmodel$ openscad-nightly -o lochmaske.png lochmaske.scad
Normalized CSG tree has 1 elements
Unable to open a connection to the X server.
DISPLAY=
Can't create OpenGL OffscreenView. Code: -1.
Geometries in cache: 1
Geometry cache size in bytes: 0
CGAL Polyhedrons in cache: 0
CGAL cache size in bytes: 0
Total rendering time: 0:00:00.000
Speicherzugriffsfehler
i don't get why it should need a connection to the X server, since i want
to run it on the command line....
the created png is empty :( i could live with the spourious error message,
but i need the view of the thing....
so what did i do wrong?
thanks in advance
Dev: Java/Perl/PHP OS:GNU/LINUX, Android
Aïkido: http://aikido.zorn.free.fr, http://www.aikido-club-saverne.fr
OpenSCAD needs an X server to make images on Linux.
IIRC I use:
DISPLAY=:5
export DISPLAY
Xvfb :5 -screen 0 800x600x24 &
On Sun, 29 Aug 2021 at 11:34, Bruno Boettcher bboett@gmail.com wrote:
Hello,
wrong:
DISPLAY=
thanks in advance
I'm slowly working on some code that should hopefully remove
that restriction, but for now you can use Xvfb, Xvnc or any
other kind of "headless" X display like nop head showed.
Unfortunately there's some build related issues that may
mean it will that even if that code makes it into the dev
snapshot, it would still need a special build.
If anyone has ideas how to solve that, here's some technical
details:
So what should work is building OpenSCAD with custom libGLEW
and also custom libOpenCSG making it much more difficult to
maintain.
thanks for the explanation, indeed, seems complicated, the other drawing
formats have the same limitation? e.g. svg?
otherwise thanks nop head, that works!
Torsten Paul Torsten.Paul@gmx.de schrieb am So., 29. Aug. 2021, 16:10:
details:
maintain.
other drawing formats have the same limitation? e.g. svg?
No, SVG and all the mesh exports like STL, 3MF need the full
geometry data calculated. In this case an active display is not
needed, as OpenGL is not used, it's just CPU based calculations.
