I've got a little project in which I have a SCAD file and all of the STLs
generated from that SCAD checked into a git repo. I include the STLs so
people unfamiliar with OpenSCAD can still make use of the STLs directly.
I have a script that re-generates the STLs from the SCAD, but the float
non-determinism in the meshes means I must manually pick and choose the
meaningfully different STLs to include in a commit alongside the SCAD
changes, and discard the changes to the STLs that weren't affected by the
change except for float rounding changes and/or vertex ordering.
Has anyone solved this problem? It's not a big deal - just a minor
annoyance.
I fix it by post processing all my STLs with this Python script:
https://github.com/nophead/NopSCADlib/blob/master/scripts/c14n_stl.py
annoyance.
Floating point isn't non-deterministic. It's difficult for mere humans
to predict the results of non-trivial operations out to the last decimal
place, but if you run the same calculation twice you should get
exactly the same answer. (Note, though: different implementations
might produce slightly different results.)
But: why not just commit the new versions of the files? Github doesn't
charge per byte-of-change; it seems like you are spending effort to to
reduce a cost that is almost zero.
OpenSCAD STL export is non-deterministic, you don't get the same results
for exactly the same model, nothing to do with floating point. The order of
vertices and facets depends on the machine addresses, so a change of
machine or just some extra code that has no effect on the STL causes its
order to change, making github think it has changed when it hasn't.
It is useful to know when your model has changed and when it hasn't so you
catch unintended changes and also no if you need to reprint it.
On Mon, 7 Jun 2021 at 21:11, Jordan Brown openscad@jordan.maileater.net
Floating point isn't non-deterministic. It's difficult for mere humans to
place, but if you run the same calculation twice you should get exactly
the same answer. (Note, though: different implementations might produce
results for exactly the same model, nothing to do with floating point.
The order of vertices and facets depends on the machine addresses, so
a change of machine or just some extra code that has no effect on the
STL causes its order to change, making github think it has changed
when it hasn't.
Ah. Good information. Yeah, that's pretty wrong. It sounds like even
two runs in sequence could produce subtly different output.
like even two runs in sequence could produce subtly different
output.
The infrastructure for that, based on nopheads script, is already
prepared. Only 3MF uses it so far, STL still needs to be converted
to use it.
https://github.com/openscad/openscad/blob/master/src/export.h#L124-L146
Something like this? https://github.com/openscad/openscad/pull/3806
output.
to use it.
