Is there a better way?
GM
Gerald McKeown
Sun, Oct 31, 2021 5:59 PM
Hi:
I'm trying to do what seems to be a simple thing - create a ruler with
Openscad.
Originally intended to help me size things in the display window, but now
converted to creating a physical ruler.  Although I've used it for display
purposes before (really slow), this is the first time I've tried a render.
It is not rendering - or, it sat at 595/1000 for hours, and I left it
overnight.  This morning, OpenSCAD was not running.  Of course, I'm not
sure if the machine rebooted overnight.
Any suggestions?
Thanks for your help!
Hi: I'm trying to do what seems to be a simple thing - create a ruler with Openscad. Originally intended to help me size things in the display window, but now converted to creating a physical ruler. Although I've used it for display purposes before (really slow), this is the first time I've tried a render. It is not rendering - or, it sat at 595/1000 for hours, and I left it overnight. This morning, OpenSCAD was not running. Of course, I'm not sure if the machine rebooted overnight. Any suggestions? Thanks for your help!
Sun, Oct 31, 2021 6:23 PM
//make a ruler of sorts
module ruler(end)
for(i=[0:10:end-1])
color("Black")translate([i,0,0])cube([.2,4,.04]);
color("Black")linear_extrude(.02)translate([i,4,0])text(str(i),size =
2);
for (j=[1:end])
color("DeepSkyBlue")translate([j,0,0,])cube([.1,3,.03]);
color ("SpringGreen")translate([j-.5,0,0])cube([.1,2,.03]);
color("pink")
cube ([150,12,1]);
translate([0,0,1])ruler(150);
translate([150,12,1])
rotate([0,0,180])
ruler(150);
On Sun, Oct 31, 2021 at 12:59 PM Gerald McKeown gamck54@gmail.com wrote:
Hi:
Openscad.
Any suggestions?
//make a ruler of sorts module ruler(end) { for(i=[0:10:end-1]) { color("Black")translate([i,0,0])cube([.2,4,.04]); color("Black")linear_extrude(.02)translate([i,4,0])text(str(i),size = 2); } for (j=[1:end]) { color("DeepSkyBlue")translate([j,0,0,])cube([.1,3,.03]); color ("SpringGreen")translate([j-.5,0,0])cube([.1,2,.03]); } } color("pink") cube ([150,12,1]); translate([0,0,1])ruler(150); translate([150,12,1]) rotate([0,0,180]) ruler(150); On Sun, Oct 31, 2021 at 12:59 PM Gerald McKeown <gamck54@gmail.com> wrote: > Hi: > I'm trying to do what seems to be a simple thing - create a ruler with > Openscad. > Originally intended to help me size things in the display window, but now > converted to creating a physical ruler. Although I've used it for display > purposes before (really slow), this is the first time I've tried a render. > > It is not rendering - or, it sat at 595/1000 for hours, and I left it > overnight. This morning, OpenSCAD was not running. Of course, I'm not > sure if the machine rebooted overnight. > > Any suggestions? > > Thanks for your help! > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Sun, Oct 31, 2021 6:36 PM
I don't think you meant to nest the two loops.
This is faster:
module ruler(end){
for(j=[1:end]) {
for(i=[0:10:end]){
= 2);
Also rather than unioning 3D objects, union them as 2D squares and then
linear_extrude the result is much faster.
I also moved the lines to centre them to avoid non-manifold problems where
they overlap. It renders in 1 minute 40 on my machine.
module ruler(end){
linear_extrude(0.03)
for(j=[1:end])
translate([j-0.05,0,])square([.1,3]);
        for(j=[1:end])
            translate([j-.55,0,0])square([.1,2]);
color("Black") {
    linear_extrude(0.04)
        for(i=[0:10:end])
            translate([i - 0.1,0])square([.2,4]);
    linear_extrude(.02)
        for(i=[0:10:end])
On Sun, 31 Oct 2021 at 17:59, Gerald McKeown gamck54@gmail.com wrote:
Hi:
Openscad.
Any suggestions?
I don't think you meant to nest the two loops. This is faster: module ruler(end){ for(j=[1:end]) { color("DeepSkyBlue")translate([j,0,0,])cube([.1,3,.03]); color ("SpringGreen")translate([j-.5,0,0])cube([.1,2,.03]); } for(i=[0:10:end]){ color("Black")translate([i,0,0])cube([.2,4,.04]); color("Black")linear_extrude(.02)translate([i,4,0])text(str(i),size = 2); } } Also rather than unioning 3D objects, union them as 2D squares and then linear_extrude the result is much faster. I also moved the lines to centre them to avoid non-manifold problems where they overlap. It renders in 1 minute 40 on my machine. module ruler(end){ color("DeepSkyBlue") linear_extrude(0.03) for(j=[1:end]) translate([j-0.05,0,])square([.1,3]); color ("SpringGreen") linear_extrude(0.03) for(j=[1:end]) translate([j-.55,0,0])square([.1,2]); color("Black") { linear_extrude(0.04) for(i=[0:10:end]) translate([i - 0.1,0])square([.2,4]); linear_extrude(.02) for(i=[0:10:end]) translate([i,4,0])text(str(i),size = 2); } } On Sun, 31 Oct 2021 at 17:59, Gerald McKeown <gamck54@gmail.com> wrote: > Hi: > I'm trying to do what seems to be a simple thing - create a ruler with > Openscad. > Originally intended to help me size things in the display window, but now > converted to creating a physical ruler. Although I've used it for display > purposes before (really slow), this is the first time I've tried a render. > > It is not rendering - or, it sat at 595/1000 for hours, and I left it > overnight. This morning, OpenSCAD was not running. Of course, I'm not > sure if the machine rebooted overnight. > > Any suggestions? > > Thanks for your help! > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
GM
Gerald McKeown
Sun, Oct 31, 2021 7:37 PM
Thank you both.
This is definitely a learning experience - and the most direct way isn't
necessarily the best!
Gerald
This is faster:
module ruler(end){
for(j=[1:end]) {
for(i=[0:10:end]){
module ruler(end){
for(j=[1:end])
         for(j=[1:end])
 color("Black") {
         for(i=[0:10:end])
     linear_extrude(.02)
         for(i=[0:10:end])
Hi:
Openscad.
Any suggestions?
Thank you both. This is definitely a learning experience - and the most direct way isn't necessarily the best! Gerald On Sun, Oct 31, 2021 at 2:37 PM nop head <nop.head@gmail.com> wrote: > I don't think you meant to nest the two loops. > > This is faster: > > module ruler(end){ > for(j=[1:end]) { > color("DeepSkyBlue")translate([j,0,0,])cube([.1,3,.03]); > color ("SpringGreen")translate([j-.5,0,0])cube([.1,2,.03]); > } > for(i=[0:10:end]){ > color("Black")translate([i,0,0])cube([.2,4,.04]); > > color("Black")linear_extrude(.02)translate([i,4,0])text(str(i),size = 2); > } > } > > Also rather than unioning 3D objects, union them as 2D squares and then > linear_extrude the result is much faster. > > I also moved the lines to centre them to avoid non-manifold problems where > they overlap. It renders in 1 minute 40 on my machine. > > module ruler(end){ > color("DeepSkyBlue") > linear_extrude(0.03) > for(j=[1:end]) > translate([j-0.05,0,])square([.1,3]); > > color ("SpringGreen") > linear_extrude(0.03) > for(j=[1:end]) > translate([j-.55,0,0])square([.1,2]); > > color("Black") { > linear_extrude(0.04) > for(i=[0:10:end]) > translate([i - 0.1,0])square([.2,4]); > > linear_extrude(.02) > for(i=[0:10:end]) > translate([i,4,0])text(str(i),size = 2); > } > } > > > > > > On Sun, 31 Oct 2021 at 17:59, Gerald McKeown <gamck54@gmail.com> wrote: > >> Hi: >> I'm trying to do what seems to be a simple thing - create a ruler with >> Openscad. >> Originally intended to help me size things in the display window, but now >> converted to creating a physical ruler. Although I've used it for display >> purposes before (really slow), this is the first time I've tried a render. >> >> It is not rendering - or, it sat at 595/1000 for hours, and I left it >> overnight. This morning, OpenSCAD was not running. Of course, I'm not >> sure if the machine rebooted overnight. >> >> Any suggestions? >> >> Thanks for your help! >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
