The thing which I'd really like is an optional Block view like BlockSCAD:
https://www.blockscad3d.com/
From: Ron Wheeler via Discuss discuss@lists.openscad.org
Cc: Ron Wheeler rwheeler@artifact-software.com
Sent: Wed, Aug 5, 2020 9:29 pm
Subject: Re: [OpenSCAD] Maintaining and debugging scripts
What would you like in the editor that the OpenSCAD editor lacks?
On 2020-08-05 2:34 p.m., John Lussmyer wrote:
On Wed Aug 05 10:56:24 PDT 2020 dgarrett@acm.org said:
This doesn't help with debugging, but you can get somewhat smarter editing
using Visual Studio Code with the SCAD extension.
On Wed, Aug 5, 2020 at 10:25 AM ken@volksswitch.org wrote:
I?d love that functionality ? and be willing to pay for it. I?ve already
donated to OpenSCAD and I hope that others are doing the same.
What I?m really missing is:
Code refactoring / renaming
I keep hoping that somebody will make an SCAD plugin for Eclipse.
Bobcats and Cougars, oh my! http://john.casadelgato.com/Pets
_______________________________________________OpenSCAD mailing listDiscuss@lists.openscad.orghttp://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Ron Wheeler
Artifact Software
438-345-3369
rwheeler@artifact-software.com _______________________________________________
Syntax checking
auto code formatting
code-completion
If you do this, please allow it to be turned off as an option
Syntax checking
code-completion
I have 20 modules and I can identify about 7 sections in my code that can be
broken up in different files:
The project calculates the size and position of all individual pieces and
there might be several thousands of them.
From: Discuss discuss-bounces@lists.openscad.org On Behalf Of Ron Wheeler
via Discuss
Sent: Wednesday, August 5, 2020 17:26
How many separate modules do you have now?
I was able to break a project up into about 10 modules. Each one is under 80
lines and most are much smaller.
It is probably quite different but the final project consists of over 300
identifiable pieces, each one of which is generated using parameters.
If you can refactor it successfully, you should be able to test each module
separately which helps a lot.
You may have to create some test scaffolding but these might be worthwhile
in reducing the time to test and in reducing the complexity of debugging
individual shapes or sub-assemblies.
I hope that these comments help.
Ron
On 2020-08-05 10:05 a.m., peter_osc@xs4all.nl mailto:peter_osc@xs4all.nl
I've been working on a aerodynamics project for modelling alternative shapes
for some weeks now using OpenSCAD. The shapes are dynamically generated upon
a list of parameters, sometimes calculating several (sub)shapes depending on
surrounding shapes.
Now that my code is going towards 1000+ lines I must restructure and
refactor it. OpenSCAD uses a scripting language and I'm running into some
problems that others might have experienced too but I cannot find much
information about: Are there any tools that ease the development of (large)
scripts?
What I'm really missing is:
A debugger and breakpoints
I'm now debugging using echo statements, which is in fact back to the 80's.
It seems to be impossible to stop the script at an arbitrary point. Not even
a pause statement.
Is a simple text search and replace that doesn't know any context.
Warnings
For example constants that are defined but never used.
Any ideas?
Ron Wheeler
Artifact Software
438-345-3369
rwheeler@artifact-software.com mailto:rwheeler@artifact-software.com
Thanks! I will try that.
From: Discuss discuss-bounces@lists.openscad.org On Behalf Of nop head
Sent: Wednesday, August 5, 2020 18:03
Using assert() instead of echo with stop on first warning is a bit like a breakpoint in that you will get a stack trace as well as any info you add to the assert message.
On Wed, 5 Aug 2020 at 16:26, Ron Wheeler via Discuss <discuss@lists.openscad.org mailto:discuss@lists.openscad.org > wrote:
I was able to break a project up into about 10 modules. Each one is under 80 lines and most are much smaller.
It is probably quite different but the final project consists of over 300 identifiable pieces, each one of which is generated using parameters.
If you can refactor it successfully, you should be able to test each module separately which helps a lot.
You may have to create some test scaffolding but these might be worthwhile in reducing the time to test and in reducing the complexity of debugging individual shapes or sub-assemblies.
Ron
On 2020-08-05 10:05 a.m., peter_osc@xs4all.nl mailto:peter_osc@xs4all.nl wrote:
I’ve been working on a aerodynamics project for modelling alternative shapes for some weeks now using OpenSCAD. The shapes are dynamically generated upon a list of parameters, sometimes calculating several (sub)shapes depending on surrounding shapes.
Now that my code is going towards 1000+ lines I must restructure and refactor it. OpenSCAD uses a scripting language and I’m running into some problems that others might have experienced too but I cannot find much information about: Are there any tools that ease the development of (large) scripts?
What I’m really missing is:
I’m now debugging using echo statements, which is in fact back to the 80’s. It seems to be impossible to stop the script at an arbitrary point. Not even a pause statement.
Is a simple text search and replace that doesn’t know any context.
Warnings
Any ideas?
Ron Wheeler
Artifact Software
438-345-3369
Notepad++ has comparable options.
OpenSCAD's search & replace should be used with care as it doesn't have
options like case sensitivity and whole words only.
In the beginning I messed up my code regularly using the replace option.
Peter
From: Discuss discuss-bounces@lists.openscad.org On Behalf Of Tim V.
Shaporev
Sent: Wednesday, August 5, 2020 19:00
For search and rename I use UNIX tools (e.g. MinGW for Windoze):
grep, sed, vi/vim
grep could also help to find all instances of the given name.
Just my $0.02
Tim
of
(large) scripts?
80's. It seems to be impossible to stop the script at an arbitrary
Warnings
Any ideas?
Looks like you have a very well thought out plan.
It sounds like you are right about breaking up Modules.scad. That should
make it easier to test.
Ron
can be broken up in different files:
and there might be several thousands of them.
From: Discuss discuss-bounces@lists.openscad.org *On Behalf Of
*Ron Wheeler via Discuss
Ron
Warnings
Any ideas?
Ron Wheeler
Artifact Software
438-345-3369
Ron Wheeler
Artifact Software
438-345-3369
My workflow has been to open up the file(s) in my editor of choice, and have only the preview window and the console open from openscad. Simply never using the openscad editor has been much nicer. I found some openscad syntax highlighting for vim, so I’m set there.
Lately I’ve been developing some scripts to use the command line interface, and the terminal program I’m using can display graphics (kitty) so I’m not interacting with the GUI at all anymore, which is even better.
The script is bash, and it’s in github, under the name openscad-cli. Note, the readme is outdated because it’s baby and I haven’t made it a thing yet. I’m only telling y’all in case it helps somebody with their projects.
(I really love openscad, and I’m glad the GUI exists. I’d never have gotten started otherwise.)
Note: If anything I said seems like gibberish and you’d like to know more, please ask. I’m happy to share more.
On Aug 5, 2020, at 13:57, Don Garrett dgarrett@acm.org wrote:
This doesn't help with debugging, but you can get somewhat smarter editing using Visual Studio Code with the SCAD extension.
I’d love that functionality – and be willing to pay for it. I’ve already donated to OpenSCAD and I hope that others are doing the same.
Maybe the people who develop OpenSCAD will consider developing it. I know that there are some complexities around order of statement execution that can make things very complex.
Sent: Wednesday, August 5, 2020 8:06 AM
Subject: [OpenSCAD] Maintaining and debugging scripts
Warnings
Any ideas?
Don
