Re: mistake
AL
a.lefranc@laposte.net
Mon, Nov 1, 2021 4:36 PM
Well  thanks you  I am  not in my home but ‌i can see your solution when i return at home !
De : "Kevin Toppenberg"
A : "OpenSCAD general discussion"
Envoyé: jeudi 28 Octobre 2021 19:02
Objet : [OpenSCAD] Re: mistake
How did you all get it to compile?  When I compile it, I get these errors
WARNING: Ignoring unknown module 'alesage' in file test_bug_fix.scad, line 55
WARNING: Ignoring unknown module 'ContreAlesage' in file test_bug_fix.scad, line 61
WARNING: Ignoring unknown module 'alesage' in file test_bug_fix.scad, line 62
WARNING: Ignoring unknown module 'alesage' in file test_bug_fix.scad, line 73
WARNING: Ignoring unknown module 'ContreAlesage' in file test_bug_fix.scad, line 79
WARNING: Ignoring unknown module 'alesage' in file test_bug_fix.scad, line 80
I had to comment out the line "    //$fn=120;" or it made my system hang or at least go slow enough that I gave up, with an F5.
Kevin
On Thu, Oct 28, 2021 at 12:42 PM Jordan Brown openscad@jordan.maileater.net wrote:
On 10/28/2021 9:40 AM, Jordan Brown wrote:
The transparent segments are a rendering glitch associated with convexity.
Although convexity is best known as an issue for linear_extrude, render, and STL import, it affects any case where CGAL gets involved in the rendering and can return a concave object.  In this case, minkowski() is the culprit.  Although the convexity parameter is not documented for minkowski(), it is implemented.  Changing the minkowski() invocation to set convexity - I used 5, but that's probably overkill - makes the glitch go away.
And as I was sending that, I was thinking "it's trivial, but I should still show explicitly what to do"...
minkowski (convexity=5)
Well  thanks you  I am  not in my home but ‌i can see your solution when i return at home !     De : "Kevin Toppenberg" A : "OpenSCAD general discussion" Envoyé: jeudi 28 Octobre 2021 19:02 Objet : [OpenSCAD] Re: mistake   How did you all get it to compile?  When I compile it, I get these errors   WARNING: Ignoring unknown module 'alesage' in file test_bug_fix.scad, line 55  WARNING: Ignoring unknown module 'ContreAlesage' in file test_bug_fix.scad, line 61  WARNING: Ignoring unknown module 'alesage' in file test_bug_fix.scad, line 62  WARNING: Ignoring unknown module 'alesage' in file test_bug_fix.scad, line 73  WARNING: Ignoring unknown module 'ContreAlesage' in file test_bug_fix.scad, line 79  WARNING: Ignoring unknown module 'alesage' in file test_bug_fix.scad, line 80  Compiling design (CSG Products generation)...   I had to comment out the line "    //$fn=120;" or it made my system hang or at least go slow enough that I gave up, with an F5.   Kevin     On Thu, Oct 28, 2021 at 12:42 PM Jordan Brown <openscad@jordan.maileater.net> wrote: On 10/28/2021 9:40 AM, Jordan Brown wrote: The transparent segments are a rendering glitch associated with convexity. Although convexity is best known as an issue for linear_extrude, render, and STL import, it affects any case where CGAL gets involved in the rendering and can return a concave object.  In this case, minkowski() is the culprit.  Although the convexity parameter is not documented for minkowski(), it *is* implemented.  Changing the minkowski() invocation to set convexity - I used 5, but that's probably overkill - makes the glitch go away.   And as I was sending that, I was thinking "it's trivial, but I should still show explicitly what to do"...   minkowski (convexity=5) { ... _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org
