Animation Motion Library
Trygon
Tue, Apr 26, 2016 12:28 PM
I was asked if I could share the code I used to produce smooth motion of
objects animated with OpenSCAD. The following link provides access to a
folder my OneDrive cloud server which contains the files:
https://onedrive.live.com/redir?resid=625391B4CF1D545D!115&authkey=!AHZ3rqfLOct19dU&ithint=folder%2c
I have included a documented example, which is hopefully sufficient to
explain usage. If not please ask.
This post is related to my earlier forum post:
http://forum.openscad.org/Product-Video-produced-with-OpenSCAD-td15783.html
Cheers,
Trygon
View this message in context: http://forum.openscad.org/Animation-Motion-Library-tp17196.html
I was asked if I could share the code I used to produce smooth motion of objects animated with OpenSCAD. The following link provides access to a folder my OneDrive cloud server which contains the files: https://onedrive.live.com/redir?resid=625391B4CF1D545D!115&authkey=!AHZ3rqfLOct19dU&ithint=folder%2c I have included a documented example, which is hopefully sufficient to explain usage. If not please ask. This post is related to my earlier forum post: http://forum.openscad.org/Product-Video-produced-with-OpenSCAD-td15783.html Cheers, Trygon -- View this message in context: http://forum.openscad.org/Animation-Motion-Library-tp17196.html Sent from the OpenSCAD mailing list archive at Nabble.com.
runsun
Tue, Apr 26, 2016 3:30 PM
Thx for sharing.
$  Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), synwrite ( 2 );   $ tips: hash ( 2 ), matrix ( 2 ), sweep ( 2 ), var ( 2 ), lerp , animation ( gif , prodVid ), precision ( 2 ), xl-control , type , rounded polygon , chfont , tailRecur ( 2, 3 ), isosphere , area , vol/center , RGB
View this message in context: http://forum.openscad.org/Animation-Motion-Library-tp17196p17197.html
Thx for sharing. ----- $ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), synwrite ( 2 );   $ tips: hash ( 2 ), matrix ( 2 ), sweep ( 2 ), var ( 2 ), lerp , animation ( gif , prodVid ), precision ( 2 ), xl-control , type , rounded polygon , chfont , tailRecur ( 2, 3 ), isosphere , area , vol/center , RGB -- View this message in context: http://forum.openscad.org/Animation-Motion-Library-tp17196p17197.html Sent from the OpenSCAD mailing list archive at Nabble.com.
