You can consider the cylinder() implementation as having a scale that
varies with Z, in that you can specify a lower radius and an upper
radius. Unfortunately, this facility is not available with other
primitives or with more complex objects
I would like to be able to scale a complex object so that the X and Y
scales vary with Z.
Any ideas?
cylinder does have the option to specify the option a radius at the
beginning and at the end.
The result is effectively a cone.(or part of cone)
But with the cone, the radius changes linearily from begin to end.
Other realtions are not possible as the primitive cylinder/cone does only
define points at the very bottom and the very top.
In implement to map nonlinear scale between bottom and top correctly, the
cylinder would have to define points all
around its surface(not done due to performance reasons)
I also wished to to define a thread of a screw by using an angular bar and
then wrap it around a cylinder
with a X - To Angle bending operation, but such operations cannot exist
due to the limited primitives.
Guenther
scales vary with Z.
Any ideas?
My motivation has to do with beveling the interior of a cavity.
Imagine a cube with a some-what oval cavity drilled into it. The
initial layers of my 3D prints are always a bit wider than the remaining
layers, so that cavity would have a lip at the bottom, a lip that is not
part of the 3D design. We either have to file the lip off manually or
create a chamfer or bevel at the bottom of the cavity. Chamfering some
shapes is easy (a cylinder!) but chamfering an arbitrary shape is more
difficult.
My concept was to take the shape of the cavity and subtract it from the
cube, but then use the scale-that-varies-with-Z to make another copy of
that shape which was broader at the bottom and narrower at the top. The
hope is that if I then subtract that shape also, I will get the bevel.
I'm sure there are other ways to do this.
scales vary with Z.
Any ideas?
Checked by AVG - www.avg.com
Version: 2015.0.6125 / Virus Database: 4409/10517 - Release Date:
08/26/15
Jon:
Have you looked at the fillet library? I have used it to round
off edges.
remaining layers, so that cavity would have a lip at the bottom, a lip
that is not part of the 3D design. We either have to file the lip off
manually or create a chamfer or bevel at the bottom of the cavity.
Chamfering some shapes is easy (a cylinder!) but chamfering an
arbitrary shape is more difficult.
the cube, but then use the scale-that-varies-with-Z to make another
copy of that shape which was broader at the bottom and narrower at the
top. The hope is that if I then subtract that shape also, I will get
the bevel.
scales vary with Z.
Any ideas?
08/26/15
========= mailto:david.boyd@usstem.org ============
David W. Boyd
7371 Atlas Walk Way, #242
Gainesville, Va 20155
fax: +1-703-656-4829
cell: +1-703-402-7908
============== http://usstem.org/ ============
First Robotic Mentor - FRC, FTC - www.iliterobotics.org
Board Member- USSTEM Foundation - www.usstem.org
Program Assistant - USFIRST - www.usfirst.org
The information contained in this message may be privileged
and/or confidential and protected from disclosure.
If the reader of this message is not the intended recipient
or an employee or agent responsible for delivering this message
to the intended recipient, you are hereby notified that any
dissemination, distribution or copying of this communication
is strictly prohibited. If you have received this communication
in error, please notify the sender immediately by replying to
this message and deleting the material from any computer.
That works! Thanks!
On 8/28/2015 9:26 AM, David Boyd wrote:
Jon:
off edges.
lip that is not part of the 3D design. We either have to file the
lip off manually or create a chamfer or bevel at the bottom of the
cavity. Chamfering some shapes is easy (a cylinder!) but chamfering
an arbitrary shape is more difficult.
the top. The hope is that if I then subtract that shape also, I will
get the bevel.
that varies with Z, in that you can specify a lower radius and an
upper radius. Unfortunately, this facility is not available with
other primitives or with more complex objects
Y scales vary with Z.
Any ideas?
08/26/15
