objects made with for loops show in preview, but won't render
O
onion
Sun, Mar 1, 2020 10:50 PM
hey folks,
i'm placing .stls in a specific order (using a for loop) and while they show
up in preview, they don't show up in the render, and it occasionally bounces
back warnings like "UI-WARNING: Object may not be a valid 2-manifold and may
need repair!"
my first thought was that my .stl is broken, but i'm actually placing the
same .stl outside of a loop, and that one shows up fine.
here's a snapshot of the code:
http://forum.openscad.org/file/t2636/openscadCode.png
preview:
http://forum.openscad.org/file/t2636/cukeSlice1.png
render:
http://forum.openscad.org/file/t2636/cukeSlice2.png
does anyone know what's wrong? i'm worried it has to do with my function
math but i don't know enough about how that math is processed to
troubleshoot further. any help would be super appreciated.
hey folks, i'm placing .stls in a specific order (using a for loop) and while they show up in preview, they don't show up in the render, and it occasionally bounces back warnings like "UI-WARNING: Object may not be a valid 2-manifold and may need repair!" my first thought was that my .stl is broken, but i'm actually placing the same .stl outside of a loop, and that one shows up fine. here's a snapshot of the code: <http://forum.openscad.org/file/t2636/openscadCode.png> preview: <http://forum.openscad.org/file/t2636/cukeSlice1.png> render: <http://forum.openscad.org/file/t2636/cukeSlice2.png> does anyone know what's wrong? i'm worried it has to do with my function math but i don't know enough about how that math is processed to troubleshoot further. any help would be super appreciated. -- Sent from: http://forum.openscad.org/
Sun, Mar 1, 2020 10:58 PM
Try:
import("cuke.stl");
cube(1);
If you just have one object it doesn't call CGAL, the cube() forces a
union(), I suspect the stl is bad, uploaded it here and I'll have a look.
Try: import("cuke.stl"); cube(1); If you just have one object it doesn't call CGAL, the cube() forces a union(), I suspect the stl is bad, uploaded it here and I'll have a look. ----- Admin - email* me if you need anything, or if I've done something stupid... * click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
O
onion
Sun, Mar 1, 2020 11:09 PM
here's the .stl:
cuke.stl http://forum.openscad.org/file/t2636/cuke.stl
i tried cube(1), interestingly this made it stop rendering any of the
objects?
if it's ok, can i ask why cgal isn't called for one object? i know what cgal
is, technically, but i'm not super familiar with how it works
here's the .stl: cuke.stl <http://forum.openscad.org/file/t2636/cuke.stl> i tried cube(1), interestingly this made it stop rendering any of the objects? if it's ok, can i ask why cgal isn't called for one object? i know what cgal is, technically, but i'm not super familiar with how it works -- Sent from: http://forum.openscad.org/
Sun, Mar 1, 2020 11:28 PM
No if you only have one object then CGAL isn't called, the object is just
drawn and may look OK even if it is broken. As soon as you have two or more
it has to union them, so CGAL will be called and it won't accept anything
that is non-manifold.
On Sun, 1 Mar 2020 at 23:09, onion eschercheshire13@gmail.com wrote:
here's the .stl:
objects?
cgal
No if you only have one object then CGAL isn't called, the object is just drawn and may look OK even if it is broken. As soon as you have two or more it has to union them, so CGAL will be called and it won't accept anything that is non-manifold. On Sun, 1 Mar 2020 at 23:09, onion <eschercheshire13@gmail.com> wrote: > here's the .stl: > cuke.stl <http://forum.openscad.org/file/t2636/cuke.stl> > > i tried cube(1), interestingly this made it stop rendering any of the > objects? > > if it's ok, can i ask why cgal isn't called for one object? i know what > cgal > is, technically, but i'm not super familiar with how it works > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
O
onion
Sun, Mar 1, 2020 11:37 PM
oh ok cool, thanks! i'll look into fixing the .stl, super appreciate the
quick responses
oh ok cool, thanks! i'll look into fixing the .stl, super appreciate the quick responses -- Sent from: http://forum.openscad.org/
Mon, Mar 2, 2020 12:01 AM
quick responses
edit: fixing the .stl worked, thanks again
Yeh, didn't look good:
http://forum.openscad.org/file/t359/onion_cuke.jpg
Purple = duplicate triangles, red=self-intersections
onion wrote > oh ok cool, thanks! i'll look into fixing the .stl, super appreciate the > quick responses > > edit: fixing the .stl worked, thanks again > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org Yeh, didn't look good: <http://forum.openscad.org/file/t359/onion_cuke.jpg> Purple = duplicate triangles, red=self-intersections ----- Admin - email* me if you need anything, or if I've done something stupid... * click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
