Re: [OpenSCAD] reusing unions objects?
Mon, Mar 14, 2016 2:28 AM
In case your question was more basic, there are  modules
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/User-Defined_Functions_and_Modules
So you can do:
module ten_steps() {
for ... //  your code that does the n/10 steps
for(i=[0:10:100])
translate(whatever)
ten_steps();
In theory the first run of ten_steps() will create the cached object, so it
should not need to be regenerated.
View this message in context: http://forum.openscad.org/reusing-unions-objects-tp16464p16473.html
In case your question was more basic, there are modules <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/User-Defined_Functions_and_Modules> . So you can do: module ten_steps() { for ... // your code that does the n/10 steps } for(i=[0:10:100]) translate(whatever) ten_steps(); In theory the first run of ten_steps() will create the cached object, so it should not need to be regenerated. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/reusing-unions-objects-tp16464p16473.html Sent from the OpenSCAD mailing list archive at Nabble.com.
CA
Mon, Mar 14, 2016 5:48 PM
On 14. mars 2016 03:28, MichaelAtOz wrote:
for(i=[0:10:100])
translate(whatever)
ten_steps();
This comes at a considerable cost, does it not? The cache needs to be
somewhere. When I look at the memory use in an OpenSCAD run it tends to
just increase and rarely (never?) decrease. If the model is large
enough, the memory requirements can cause crashes. In such cases it
would be better to have an option to disable caching.
On 14. mars 2016 03:28, MichaelAtOz wrote: > for(i=[0:10:100]) > translate(whatever) > ten_steps(); > > In theory the first run of ten_steps() will create the cached object, so it > should not need to be regenerated. This comes at a considerable cost, does it not? The cache needs to be somewhere. When I look at the memory use in an OpenSCAD run it tends to just increase and rarely (never?) decrease. If the model is large enough, the memory requirements can cause crashes. In such cases it would be better to have an option to disable caching. Carsten Arnholm
Mon, Mar 14, 2016 6:10 PM
I think that is just the way C programs work. As the heap expands it page
faults and the OS allocates more virtual memory. When you free some
object's memory it just gets added to a lists of free chunks for reuse by
the heap manager. It doesn't shrink the virtual address space as it would
leave a gap in it. If it doesn't get used then the OS might page it out,
freeing up physical memory, but the virtual space only ever increase.
for(i=[0:10:100])
translate(whatever)
ten_steps();
it
I think that is just the way C programs work. As the heap expands it page faults and the OS allocates more virtual memory. When you free some object's memory it just gets added to a lists of free chunks for reuse by the heap manager. It doesn't shrink the virtual address space as it would leave a gap in it. If it doesn't get used then the OS might page it out, freeing up physical memory, but the virtual space only ever increase. On 14 March 2016 at 17:48, Carsten Arnholm <arnholm@arnholm.org> wrote: > On 14. mars 2016 03:28, MichaelAtOz wrote: > >> for(i=[0:10:100]) >> translate(whatever) >> ten_steps(); >> >> In theory the first run of ten_steps() will create the cached object, so >> it >> should not need to be regenerated. >> > > This comes at a considerable cost, does it not? The cache needs to be > somewhere. When I look at the memory use in an OpenSCAD run it tends to > just increase and rarely (never?) decrease. If the model is large enough, > the memory requirements can cause crashes. In such cases it would be better > to have an option to disable caching. > > Carsten Arnholm > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
CA
Mon, Mar 14, 2016 7:10 PM
No, this is not generally true. I've written many programs that release
memory along the way, and it shows up as reduced memory footprint in the
operating system. It depends on how programs are written.
However, regardless of how an application returns memory to the OS (or
not), the fact that OpenSCAD keeps consuming more and more memory, means
there is something not quite right, because it really should not be
required.
For the "many holes" example posted by Maël Naccache 03. march, the
memory requirement in OpenSCAD generally just grows in one direction
(up) to more than 900MB (Win7 2015.03-2). For the same example, in my
experimental implementation using carve, the memory use rises and falls
many times between 50-150 MB only, the final results are similar in
resolution. I don't know what OpenSCAD does here, but the memory use is
clearly not optimal. If this has to do with caching I cannot say, but I
would check it.
On 14. mars 2016 19:10, nop head wrote: > I think that is just the way C programs work. As the heap expands it page > faults and the OS allocates more virtual memory. When you free some > object's memory it just gets added to a lists of free chunks for reuse by > the heap manager. It doesn't shrink the virtual address space as it would > leave a gap in it. If it doesn't get used then the OS might page it out, > freeing up physical memory, but the virtual space only ever increase. No, this is not generally true. I've written many programs that release memory along the way, and it shows up as reduced memory footprint in the operating system. It depends on how programs are written. However, regardless of how an application returns memory to the OS (or not), the fact that OpenSCAD keeps consuming more and more memory, means there is something not quite right, because it really should not be required. For the "many holes" example posted by Maël Naccache 03. march, the memory requirement in OpenSCAD generally just grows in one direction (up) to more than 900MB (Win7 2015.03-2). For the same example, in my experimental implementation using carve, the memory use rises and falls many times between 50-150 MB only, the final results are similar in resolution. I don't know what OpenSCAD does here, but the memory use is clearly not optimal. If this has to do with caching I cannot say, but I would check it. Carsten Arnholm
AC
Alan Cox
Mon, Mar 14, 2016 7:48 PM
On Mon, 14 Mar 2016 18:10:42 +0000
In the Linux case at least that is configurable. It doesn't normally
matter however as any unreturned memory will be idle and so just dumped
out to swap when other processes need RAM.
Alan
On Mon, 14 Mar 2016 18:10:42 +0000 nop head <nop.head@gmail.com> wrote: > I think that is just the way C programs work. As the heap expands it page > faults and the OS allocates more virtual memory. When you free some > object's memory it just gets added to a lists of free chunks for reuse by > the heap manager. It doesn't shrink the virtual address space as it would > leave a gap in it. If it doesn't get used then the OS might page it out, > freeing up physical memory, but the virtual space only ever increase. In the Linux case at least that is configurable. It doesn't normally matter however as any unreturned memory will be idle and so just dumped out to swap when other processes need RAM. Alan
Mon, Mar 14, 2016 9:42 PM
Design/Flush_caches
View this message in context: http://forum.openscad.org/reusing-unions-objects-tp16464p16497.html
cacb wrote > When I look at the memory use in an OpenSCAD run it tends to > just increase and rarely (never?) decrease. If the model is large > enough, the memory requirements can cause crashes. In such cases it > would be better to have an option to disable caching. Design/Flush_caches ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/reusing-unions-objects-tp16464p16497.html Sent from the OpenSCAD mailing list archive at Nabble.com.
