So I created a function that creates a hollow cube by differencing two
cubes. For some reason though it wont compile. I keep getting a syntax
error on the first bracket after the difference function is called. If I
comment out the difference function it works fine. What am I missing here?
You can use the difference function in a user defined function right? If
not how can I create a function to create an object?
function CreateNonArchedBody(boxLength,
boxWidth,
boxHeight,
boxDepth,
boxWallThickness,
boxHingeDiameter,
boxHingePinDiameter,
boxHingeXOffset,
boxHingeYOffset,
boxHingeTolerance,
pinTolerance,
controlArmPinDiameter,
controlArmHoleXOffset,
controlArmHoleYOffset) =
cube([boxLength,boxWidth,boxHeight],
center = true
translate([0,0,((boxHeight-boxDepth)/2)])
cube([boxLength - boxWallThickness,
boxWidth - boxWallThickness,
boxDepth],
center = true
View this message in context: http://forum.openscad.org/Difference-in-a-Function-Definition-tp12303.html
This should be a module rather than a function. Just change the keyword and
drop the "="
View this message in context: http://forum.openscad.org/Difference-in-a-Function-Definition-tp12303p12304.html
Oh Thanks that works. What is the difference between the two? What
determines when you use a function vs a module?
View this message in context: http://forum.openscad.org/Difference-in-a-Function-Definition-tp12303p12305.html
Functions in Openscad are functions in the mathematical sense. They return the solution to an equation rather than creating geometry.
Sent from the OpenSCAD mailing list archive at Nabble.com (http://Nabble.com).
Discuss@lists.openscad.org (mailto:Discuss@lists.openscad.org)
I learned it this way:
a = x; // x is a parameter, previously defined as x=something;
b = x( ); // x is a function
x; // x is a module
So in OpenScad you can have same name x representing 3 different things.
$ Runsun Pan, PhD
$ -- OpenScad_DocTest: doc and unit test ( Github , Thingiverse )
$ -- Linux Mint 17.1 Rebecca x64 + OpenSCAD 2015.03.15
$ -- Linux Mint 17.1 Rebecca x64 + OpenSCAD 2015.04.01.nightly
View this message in context: http://forum.openscad.org/Difference-in-a-Function-Definition-tp12303p12356.html
