Tue, May 3, 2022 8:32 PM
I don't know why you are using polygon---I just took it out since it
broke the model. It makes something with zero thickness so it makes
no sense for a 3D model. If you need something like that perhaps
linear_extrude the polygon to some thickness?
For the other matter, if you want to understand the problem, examine
the BOSL2 manual for path_sweep. There is a discussion there about
profiles crossing and how the result will be invalid. It looks like
yours is a case where you can simply substitute path_sweep2d.
On Tue, May 3, 2022 at 3:15 PM Jan Öhman via Discuss
Cc:
Bcc:
Date: Tue, 3 May 2022 19:19:54 +0000 (UTC)
Subject: [OpenSCAD] Re: Export to .stl or .3mf - Error - nothing to export.
We start again (did not understand much of the suggestions I received)
"polygon statement which mixes 2d and 3d" - yes
(but I don't know how to solve it on another way)
What can I do?
Den tisdag 3 maj 2022 13:23:19 CEST, Adrian Mariano avm4@cornell.edu skrev:
Actually ignore what I said about flatten() unless you're trying to
use the profiles=true option of path_sweep. There's a bug where it
doesn't work with regions.
On Tue, May 3, 2022 at 6:37 AM Adrian Mariano avm4@cornell.edu wrote:
Your model has a polygon statement which mixes 2d and 3d. After that
is fixed you get a CGAL error, showing that you have invalid geometry.
Your statement
path_sweep( section, path, closed=false)
produces invalid geometry---the profiles cross in points4. You can
use path_sweep2d instead, or you need to have a larger radius on that
corner.
Note also that wall() is producing an extra level of nesting in
output. You might want to run flatten() on section.
On Tue, May 3, 2022 at 2:14 AM Jan Öhman via Discuss
Cc:
Bcc:
Date: Tue, 3 May 2022 06:17:02 +0000 (UTC)
The 3D-product can probably be created in a more efficient way, but this is what this code looks like now.
fn = 150;
placering="left";
// placering="right"
box(0, 0, 0, placering, "#C0C0C0", fn); // (X, Y, Z, left/right, colorName)
// Monteringsplattan
// mountingPlate(0, 0, 0, placering);
// LED belysning
// LEDlampa(0, 0, 0, placering);
// - - - - m o d u l e r - - - - - - - - - - - - - - - - - -
//====== box
module box(posX=0, posY=0, posZ=0, mountSide="left", colorName="#00FF00", fn=24)
side = mountSide == "left" ? 0
: mountSide == "right" ? 1
: assert(false,"invalid moutSide value"); // message if no case worked
color(colorName)
translate([posX, posY, posZ])
mirror([side, 0, 0])
union()
// Skapa konturer på bottenplattan - x, y, r, angles, [grader], början
// Rotation medurs - vänster lamphållare (bakant saknas)
points1 = circSect( 140, 0, 0, [0, 0], "right", 1, fn); // böj nere till höger
points2 = circSect( 60, 5, 5, [0, 5], "bottom", 1, fn); // brytpunkt längst ned
points3 = circSect( 10, 13, 10, [0, 90], "bottom", 1, fn); // böj nere till vänster
points4 = circSect( 5, 80, 5, [0, 90], "left", 1, fn); // böj uppe till vänster
points5 = circSect( 140, 80, 5, [0, 1], "top", 1, fn); // böj uppe till höger
edge = concat(points1, points2, points3, points4, points5);
path = path3d(reverse(edge));
section = wall();
path_sweep( section, path, closed=false);
// Skapa bakkant lite högre och smalare i topp
bottom1 = concat(points5, points1);
polygon(bottom1);
path1 = path3d(reverse(bottom1));
section1 = wall1(); // lite högre bakvägg wall(b=4, f=8, h=15, t=3.5)
path_sweep( section1, path1, closed=false);
// fyll upp bottenplattansbaksida
linear_extrude(4) // Bottomplate - fill up
polygon(concat(points1, points2, points3, points4, points5));
// skapa Utskjutande del under (tänk spegelvänt)
pt1 = circSect( 19.5, 85, 0, [0, 50], "top", 1, fn); // Uppe till höger - moturs
pt2 = circSect( 39, 1.35, .1, [-5, 90], "right", 1, fn); // Nere till höger
pt3 = circSect( 10, 13.05, 10, [0, 90], "bottom", 1, fn); // Nere till vänster
pt4 = circSect( 5, 80, 5, [0, 90], "left", 1, fn); // Uppe till vänster
translate([0, 0, -2])
linear_extrude(2.1)
polygon(concat(pt1, pt2, pt3, pt4));
// utgången för kabeln på baksidan (diam 10mm) - pekar lite nedåt
cableExit(65, 35, 0, 15, "cyan", $fn=100);
// skapa ett borrhål i bakkant
translate([132,60,15])
{ rotate([0, 90, 0])
{ cylinder(h=10, d=2, $fn=100);
cylinder(h=4, d=9, $fn=100);
// skapa en borrmarkering i bakkant
translate([139,25,15])
cylinder(h=2, d1=1, d2=2.5, $fn=100);
// ingravera årtalet på baksidan
translate([10, 80, -0.5])
{ mirror([side, 0, 0])
{ rotate([0, 180, 0])
{ linear_extrude(3)
text("2022", size=12, direction="ttb", font="Comic Sans MS:style=Bold");
// Markera skruvhål på bakkant
borr=3;
bredd=140;
hojd=8;
avstNed=20;
translate([bredd, avstNed, hojd])
{ rotate([0,90,0])
cylinder(h=2, d1=0.5, d2=borr, center=true, $fn=50);
// borrhål
mountingHole(20, 36, 0, 7, 90.1, 15); // posX, posY, posZ, diam, dist, deep, $fn=50
//======== Slut box
//====== cableExit
module cableExit(posX, posY, posZ, angle, colorName)
{ diamHole = 7;
diamHolder = 9.8;
hight = 12;
topRad = diamHolder/2;
topDiam = diamHolder/2-topRad/2;
bowRad = 7;
offs1 = 0.1;
color(colorName)
{ rotate([180, 0, 180-angle])
{ difference()
{ hull()
{ cylinder(h=hight, d=diamHolder, center=false);
translate([0, 0, hight]) // rundad topp
rotate_extrude(angle=360, convexity=2)
translate([topDiam, 0, 0]) // yttre diam topp
circle(d=topRad); // radie topp
inpHight = 2; // ett värde som styr var utgångshålet hamnar
translate([0, 0, -offs1])
cylinder(h=inpHight+offs1, d=diamHole, center=false); // Bottenhål
translate([-bowRad, 0, inpHight-offs1]) // böjen
{ rotate([90, 0, 0])
rotate_extrude(angle=90, convexity=10)
translate([bowRad, 0, 0]) // ställ in radien på kabelböjen
circle(d=diamHole);
//====== slut cableExit
//====== mountingHole
module mountingHole(posX=0, posY=0, posZ=0, diam=7, dist=90, deep=5, $fn=50)
{ // diam = 6; // [mm]
// dist = 90; // [mm]
// deep = 12; // [mm]
{ translate([0, 0, -10])
cylinder(h=deep, d=diam); // fästhål 1
//cableHold1(dist/2, 0, .2, "#D5D5D5"); // Kabelgenomföring
translate([dist/2, 0, 0])
{ hull()
{ cylinder(h=5, d=6); // fästhål 1
sphere(d=7.5);
translate([dist, 0, -10])
cylinder(h=deep, d=diam); // fästhål 2
//====== slut mountingHole
//====== LEDlampa
// module LEDlampa(posX=8, posY=10, posZ=0)
module LEDlampa(posX=0, posY=0, posZ=0, mountSide="left")
{ side = mountSide == "left" ? 0
xpos = mountSide == "left" ? 121
: mountSide == "right" ? -10
ypos = mountSide == "left" ? 10.5
: mountSide == "right" ? 10.5
zpos = mountSide == "left" ? 5
: mountSide == "right" ? 5
// echo(xpos,ypos,zpos);
// translate([xpos, ypos, zpos])
translate([xpos, 10.5, 5])
mirror([1, 0, 0])
{ LEDbottom();
translate([0, 0, 11])
LEDglas();
//====== Slut LEDlampa
//====== LEDglas
module LEDglas()
// Variabler botten
length = 111; // längd mm
wideMid = 50.5; // bredd i mitten mm
cornRad = 10; // Radien i alla hörn
wideCorn = 48; // Bredd i kanterna
diamHole = 6; // håldiameter i mm
colorBot = "gray";
colorTop = "orange";
// Variabler top
cornHigh = 5; //Höjd i ändarna
midHigh = 8;
highTop = cornHigh + 1; // höjd mm
p1tx = 10; // the start value
p1ty = 49.25;
p2tx = 55.5; // the middle value
p2ty = 50.5;
p3tx = 101; // the end value
p3ty = p1ty;
p4tx = 101; // the start value
p4ty = 1.25;
p5tx = 55.5; // the middle value
p5ty = 0.0;
p6tx = 10; // the end value
p6ty = p4ty;
// Ger ovalt glas
points1 = 3points_arc([p1tx,p1ty], [p2tx,p2ty], [p3tx,p3ty], fn=100);
points2 = 3points_arc([p4tx,p4ty], [p5tx,p5ty], [p6tx,p6ty], fn=100);
color("orange")
linear_extrude(height=cornHigh+.1)
{ polygon(concat(points1, points2));
translate([length-10 , wideMid / 2, -.2])
circle(d=6);
translate([10 , wideMid / 2, -.2])
circle(d=6);
// Top
color(colorTop)
{ hull()
{ // hörn1
translate([cornRad, wideMid - ((wideMid-wideCorn)/2) - cornRad, 0]) // [10,39]
cylinder(h=cornHigh, d=cornRad2, center=false);
// hörn2
translate([cornRad, cornRad + ((wideMid-wideCorn)/2), 0]) // [10,12]
// hörn3
translate([length - cornRad, wideMid - ((wideMid-wideCorn)/2) - cornRad, 0]) // [101 ,39]
// hörn4
translate([length - cornRad, cornRad + ((wideMid-wideCorn)/2), 0]) //
union()
{ // Monteringshål 1 & 2
cylinder(d=diamHole, h=highTop+.5, center=false);
//======== Slut LEDglas
//====== LEDbottom
module LEDbottom()
{ p1x = 10; // the start value
p1y = 49.25;
p2x = 55.5; // the middle value
p2y = 50.5;
p3x = 101; // the end value
p3y = p1y;
p4x = 101; // the start value
p4y = 1.25;
p5x = 55.5; // the middle value
p5y = 0.0;
p6x = 10; // the end value
p6y = p4y;
// Variabler botten för borrhålen
midHigh = 8;
// offs1 = 0.1;
heightHole = 15; //mm
height = 11; //mm
points1 = circSect( 10, 11.25, 10, [0, 90], "bottom", 1, fn); // Hörn nere till vänster
points2 = circSect( 10, 39.25, 10, [0, 90], "left", 1, fn); // Hörn uppe till vänster
points3 = 3points_arc([p1x,p1y], [p2x,p2y], [p3x,p3y], fn);
points4 = circSect( 101, 39.25, 10, [0, 90], "top", 1, fn); // Hörn uppe till höger
points5 = circSect( 101, 11.25, 10, [0, 90], "right", 1, fn); // Hörn nere till höger
points6 = 3points_arc([p4x,p4y], [p5x,p5y], [p6x,p6y], fn);
// The base plate for the LED lamp
{ color("gray", 0.5)
linear_extrude(height=height)
polygon(concat(points1, points2, points3, points4, points5, points6));
// union()
cylinder(d=diamHole, h=heightHole, center=false);
//======== Slut LEDbottom
//====== circleSect
// Create rounded corners 2D
// https://openhome.cc/eGossip/OpenSCAD/SectorArc.html
// ange .: x, y, radien,
// [från, till] vinkel,
// var vinkeln startar, (left, bottom, right, top)
// vilken rotation (-1=medsol, 1=motsols)
function circSect(x=0, y=0, radius=10, angles=[0,270], startRef="bottom", rotate=1, fn=24) =
let(
startAngel = (startRef == "left") ? 0
: (startRef == "bottom") ? 90
: (startRef == "right") ? 180
: (startRef == "top") ? 270
: startRef, // valfri vinkel
// : assert(false,"invalid moutSide value"); // Error message if no case worked
//: undef,
r = radius,
//r = radius / cos(180 / fn),
step = 360 / fn,
// points = [[x, y],
points = [
for(a = [angles[0]-startAngel : step : angles[1]-startAngel])
[-rotate * r * cos(a)+x, r * sin(a)+y]]
) points;
//======== Slut circleSect
//====== 3points_arc
// Create an arc with three points 2D
function 3points_arc(p0, p1, p2, fn=10) =
// an alternative expression for D
// D = 2 * ( (p1-p0).x * (p2-p0).y - (p1-p0).y * (p2-p0).x )
let( D = 2 * cross(p1-p0, (p2-p0)) )
assert( abs(D)>1e-9, "The 3 points should not be collinear." )
let(
Ux = ( (p2-p0).y*(p1-p0)(p1-p0) - (p1-p0).y(p2-p0)(p2-p0) )/D,
Uy = ( (p1-p0).x(p2-p0)(p2-p0) - (p2-p0).x(p1-p0)(p1-p0) )/D,
radius = norm([Ux,Uy]),
center = [Ux,Uy] + p0,
ang0 = atan2( (p0-center).y, (p0-center).x ),
ang2 = atan2( (p2-center).y, (p2-center).x ),
// the points are in a cw winding iff D<0
// the angular difference between vectors p2-center and p0-center
// measured from p0-center; dang is positive iff D is negative
dang = D<0 ? ang2<ang0 ? ang2-ang0 : ang2-ang0-360
: ang2>ang0 ? ang2-ang0 : ang2-ang0+360
[ for(i=[0:fn-1])
let( ang = ang0 + idang/(fn-1) )
center + radius*[cos(ang),sin(ang)] ];
//======== Slut 3points_arc
//====== Wall som ett "L"
// Normal vägghöjd
function wall() =
let(
b = 4, // botten - tjocklek
f = 8, // Foten
h = 15, // Höjd
t = 3.5, // Top
x = (b+(t/2) - (h - ( (-h / (f-t)) *t) )) / (-h / (f-t))
let(
points = [[0,0], [f,0], [t,h], [0,h]] ,
top = move([t/2, h, 0], circle(d=t, $fn=20)),
sqr = square([10, b]),
diff =
difference([
move([x, b], square([t/2, t/2])),
move([x+(t/2), b+(t/2), 0], circle(d = t, $fn=20) ) ])
union([points, top, sqr, diff]);
//======== Slut Wall
//====== Wall1 som ett "L"
// En högre vägg
function wall1() =
let(
f = 7, // Foten
h = 25, // Höjd
t = 3, // Top
x = (b+(t/2) - (h - ((-h / (f-t)) *t))) / (-h / (f-t))
let(
diff =
difference([
//======== Slut Wall1
//====== Plåt på släp
module mountingPlate(posX=0, posY=0, posZ=0, mountSide="left", colorName="#C0C0C0", $fn=50)
{ // Hörnpositionerna
posX1 = 120;
posY1 = 0;
posX2 = posX1;
posY2 = -200;
posX3 = 120 - 75;
posY3 = -200;
posX4 = 0;
posY4 = 0;
thick=2; // tjocklek
xpos = mountSide == "left" ? 20
: mountSide == "right" ? -20
ypos = mountSide == "left" ? 85
: mountSide == "right" ? 85
zpos = mountSide == "left" ? -thick
: mountSide == "right" ? -thick
color(colorName)
{ translate([posX, posY, posZ])
translate([xpos, 85, -thick])
{ linear_extrude(thick)
hull()
{ translate([posX1, posY1, 0])
square(0.1, center = true);
translate([posX2, posY2, 0])
translate([posX3, posY3, 0])
translate([posX4, posY4, 0])
Den tisdag 3 maj 2022 01:49:27 CEST, Father Horton fatherhorton@gmail.com skrev:
Is the OpenSCAD file small enough to share?
On Mon, May 2, 2022 at 5:23 PM Jan Öhman via Discuss discuss@lists.openscad.org wrote:
To: OpenSCAD General Discussion discuss@lists.openscad.org
Cc:
Bcc:
Date: Mon, 2 May 2022 22:23:28 +0000 (UTC)
Subject: [OpenSCAD] Export to .stl or .3mf - Error - nothing to export.
Thought to check out what a 3D print from openSCAD would cost.
The company can only handle .stl, .3mf, stp
The openSCAD can export to .stl and .3mf
(I don't know the difference).
When "F5" is pressed - no problems occur.
When I select "File" / "Export" / "Export as STL" (F7)
The following message is displayed .:
"ERROR: Nothing to export! Try rendering first (press F6)"
I press "F6"
"WARNING: No top level geometry to render"
The same thing happens when I try to export to ".3MF"
Why / What to do?
From: "Jan Öhman via Discuss" discuss@lists.openscad.org
Cc: "Jan Öhman" jan_ohman@yahoo.com
Bcc:
Bcc:
Bcc:
> ---------- Forwarded message ----------
> From: "Jan Öhman" <jan_ohman@yahoo.com>
> To: OpenSCAD general discussion <discuss@lists.openscad.org>
> Cc:
> Bcc:
> What can I do?
> Den tisdag 3 maj 2022 13:23:19 CEST, Adrian Mariano <avm4@cornell.edu> skrev:
> > Your statement
> > corner.
> > > Cc:
> > > Bcc:
> > > include <BOSL2/std.scad>
> > > fn = 150;
> > > placering="left";
> > > // LED belysning
> > > //====== box =====================================================================
> > > color(colorName)
> > > difference()
> > > union()
> > > section = wall();
> > > polygon(bottom1);
> > > linear_extrude(2.1)
> > > { linear_extrude(3)
> > > borr=3;
> > > bredd=140;
> > > hojd=8;
> > > avstNed=20;
> > > { rotate([0,90,0])
> > > // borrhål
> > > //======== Slut box ==============================================================
> > > //====== cableExit ===============================================================
> > > { diamHole = 7;
> > > diamHolder = 9.8;
> > > hight = 12;
> > > bowRad = 7;
> > > offs1 = 0.1;
> > > color(colorName)
> > > { difference()
> > > { hull()
> > > circle(d=diamHole);
> > > //====== slut cableExit ==========================================================
> > > //====== mountingHole ============================================================
> > > { hull()
> > > sphere(d=7.5);
> > > //====== slut mountingHole =======================================================
> > > //====== LEDlampa ================================================================
> > > mirror([1, 0, 0])
> > > { LEDbottom();
> > > LEDglas();
> > > //====== Slut LEDlampa ===========================================================
> > > //====== LEDglas =================================================================
> > > module LEDglas()
> > > // Variabler botten
> > > colorBot = "gray";
> > > // Variabler top
> > > midHigh = 8;
> > > p1ty = 49.25;
> > > p2ty = 50.5;
> > > p3ty = p1ty;
> > > p4ty = 1.25;
> > > p5ty = 0.0;
> > > p6ty = p4ty;
> > > // Ger ovalt glas
> > > color("orange")
> > > difference()
> > > circle(d=6);
> > > circle(d=6);
> > > // Top
> > > color(colorTop)
> > > difference()
> > > { hull()
> > > { // hörn1
> > > cylinder(h=cornHigh, d=cornRad*2, center=false);
> > > // hörn2
> > > // hörn3
> > > // hörn4
> > > union()
> > > //======== Slut LEDglas ==========================================================
> > > //====== LEDbottom ===============================================================
> > > module LEDbottom()
> > > p1y = 49.25;
> > > p2y = 50.5;
> > > p3y = p1y;
> > > p4y = 1.25;
> > > p5y = 0.0;
> > > p6y = p4y;
> > > midHigh = 8;
> > > // offs1 = 0.1;
> > > height = 11; //mm
> > > difference()
> > > // union()
> > > //======== Slut LEDbottom ========================================================
> > > //====== circleSect ==============================================================
> > > let(
> > > //: undef,
> > > r = radius,
> > > step = 360 / fn,
> > > points = [
> > > ) points;
> > > //======== Slut circleSect =======================================================
> > > //====== 3points_arc =============================================================
> > > let(
> > > Ux = ( (p2-p0).y*(p1-p0)*(p1-p0) - (p1-p0).y*(p2-p0)*(p2-p0) )/D,
> > > Uy = ( (p1-p0).x*(p2-p0)*(p2-p0) - (p2-p0).x*(p1-p0)*(p1-p0) )/D,
> > > [ for(i=[0:fn-1])
> > > let( ang = ang0 + i*dang/(fn-1) )
> > > //======== Slut 3points_arc ======================================================
> > > //====== Wall som ett "L" ========================================================
> > > // Normal vägghöjd
> > > function wall() =
> > > let(
> > > f = 8, // Foten
> > > h = 15, // Höjd
> > > t = 3.5, // Top
> > > let(
> > > diff =
> > > difference([
> > > //======== Slut Wall =============================================================
> > > //====== Wall1 som ett "L" =======================================================
> > > // En högre vägg
> > > function wall1() =
> > > let(
> > > f = 7, // Foten
> > > h = 25, // Höjd
> > > t = 3, // Top
> > > let(
> > > diff =
> > > difference([
> > > //======== Slut Wall1 ============================================================
> > > //====== Plåt på släp ============================================================
> > > posX1 = 120;
> > > posY1 = 0;
> > > posX2 = posX1;
> > > posY2 = -200;
> > > posX3 = 120 - 75;
> > > posY3 = -200;
> > > posX4 = 0;
> > > posY4 = 0;
> > > color(colorName)
> > > hull()
> > > Den tisdag 3 maj 2022 01:49:27 CEST, Father Horton <fatherhorton@gmail.com> skrev:
> > > On Mon, May 2, 2022 at 5:23 PM Jan Öhman via Discuss <discuss@lists.openscad.org> wrote:
> > > To: OpenSCAD General Discussion <discuss@lists.openscad.org>
> > > Cc:
> > > Bcc:
> > > I press "F6"
> > > Why / What to do?
> > > From: "Jan Öhman via Discuss" <discuss@lists.openscad.org>
> > > Cc: "Jan Öhman" <jan_ohman@yahoo.com>
> > > Bcc:
> > > _______________________________________________
> > > OpenSCAD mailing list
> > > To unsubscribe send an email to discuss-leave@lists.openscad.org
> > > Bcc:
> Bcc:
