Re: [OpenSCAD] Please help me with this part modification!
O
OzAtMichael
Tue, Apr 10, 2018 12:32 AM
This missed the mailing-list.
Sent: Tue, 10 Apr 2018 09:29
Subject: Please help me with this part modification!
http://forum.openscad.org/file/t2217/image832.png
http://forum.openscad.org/file/t2217/Screenshot_%281%29.png
Hello everyone,
I am a materials engineering student working in a research lab. We are
building a syringepump which has 3d printed components. These components
hold the syringes. The current design allows for only one size of syringes
to be used. We want to make it so that we can use different size syringes on
it; i.e. 5, 10, 20, 60 mL.
My simple solution to do this is the modification I've shown in the picture.
The screenshotted image is the original design and the handrawn one is what
I want to achive
I just don't know how to design this on openscad as I've never used it
before. Can someone help me out wit this problem?
This missed the mailing-list. > -----Original Message----- > From: johneron [mailto:johneron@ymail.com] > Sent: Tue, 10 Apr 2018 09:29 > To: discuss@lists.openscad.org > Subject: Please help me with this part modification! > > http://forum.openscad.org/file/t2217/image832.png > http://forum.openscad.org/file/t2217/Screenshot_%281%29.png > > > Hello everyone, > > I am a materials engineering student working in a research lab. We are > building a syringepump which has 3d printed components. These components > hold the syringes. The current design allows for only one size of syringes > to be used. We want to make it so that we can use different size syringes on > it; i.e. 5, 10, 20, 60 mL. > > My simple solution to do this is the modification I've shown in the picture. > The screenshotted image is the original design and the handrawn one is what > I want to achive > > I just don't know how to design this on openscad as I've never used it > before. Can someone help me out wit this problem? > > > > > > -- > Sent from: http://forum.openscad.org/
Tue, Apr 10, 2018 12:41 AM
I presume the syringe is strapped down somehow?
Would a V shape be suitable, any radius (with parallel sides) will be held
in a V.
I presume the syringe is strapped down somehow? Would a V shape be suitable, any radius (with parallel sides) will be held in a V. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- Sent from: http://forum.openscad.org/
JE
John Eron
Tue, Apr 10, 2018 2:39 PM
In traditional syringe pumps they are but in this design we may not need to.
DIY Syringe Pump (Food 3D Printer - Part 1)
For more information: https://www.drdflo.com/syringe The lab Dr. D-Flo works in needed two syringe pumps for bio...
this is the design.
On ‎Monday‎, ‎April‎ ‎9‎, ‎2018‎ ‎08‎:‎41‎:‎54‎ ‎PM‎ ‎EDT, MichaelAtOz <oz.at.michael@gmail.com> wrote:
in a V.
In traditional syringe pumps they are but in this design we may not need to. DIY Syringe Pump (Food 3D Printer - Part 1) | | | | | | | | | | | DIY Syringe Pump (Food 3D Printer - Part 1) For more information: https://www.drdflo.com/syringe The lab Dr. D-Flo works in needed two syringe pumps for bio... | | | this is the design.  On ‎Monday‎, ‎April‎ ‎9‎, ‎2018‎ ‎08‎:‎41‎:‎54‎ ‎PM‎ ‎EDT, MichaelAtOz <oz.at.michael@gmail.com> wrote: I presume the syringe is strapped down somehow? Would a V shape be suitable, any radius (with parallel sides) will be held in a V. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.”  Fight it! http://www.ourfairdeal.org/   time is running out! -- Sent from: http://forum.openscad.org/ _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
F
fred_dot_u
Tue, Apr 10, 2018 5:43 PM
At this point, I'm lacking the concentration to follow through on my
"discovery," but a preliminary drawing shows that the process of creating
the part can be made parametric. If it doesn't need to be parametric, it's
easier to make the drawing and pull the numbers off via the appropriate tool
for the drawing software.
I'm "building" this model by creating cylinders to be subtracted from the
monolithic base. For practical purposes, the cylinders can be considered
circles in this exercise.
Picture the smallest diameter for the collection of syringes. You want the
most support, but you don't want the C-shape of the cross section to impede
insertion. That makes the end result limited to the diameter of that
syringe. Any cross-section cut higher than the diameter becomes a "gripper"
of sorts and may be beneficial, but impedes this calculation. It can be
added later as a parameter sum of an arbitrary distance of percentage.
http://forum.openscad.org/file/t824/syringelayout.png
The centers of the circles are the parametric aspect that currently escapes
me. I know it's simple, but the pounding headache I have is preventing me
from proceeding.
What I have been able to determine is that the spacing of the center of the
second circle from the first circle is the diameter of the second circle
minus the distance of the chord of the second circle from its center, with
the chord of the second circle being the diameter of the first circle.
I've done math of this sort before and have found an abundance of formulae
to solve for this result. Because each circle references the preceding
circle, the primary formula should be iterative, allowing for as many circle
stacks as desired.
In the image above, I used syringe diameters based on arbitrarily taking the
capacity and making those numbers diameters, only to manage a relatively
proportional image.
I found a  web page containing the formula
https://www.ck12.org/trigonometry/Length-of-a-Chord/lesson/Length-of-a-Chord-TRIG/
I'd likely use to pursue this as an OpenSCAD project.
The "welded" version of the above diagram:
http://forum.openscad.org/file/t824/syringelayout2.png
At this point, I'm lacking the concentration to follow through on my "discovery," but a preliminary drawing shows that the process of creating the part can be made parametric. If it doesn't need to be parametric, it's easier to make the drawing and pull the numbers off via the appropriate tool for the drawing software. I'm "building" this model by creating cylinders to be subtracted from the monolithic base. For practical purposes, the cylinders can be considered circles in this exercise. Picture the smallest diameter for the collection of syringes. You want the most support, but you don't want the C-shape of the cross section to impede insertion. That makes the end result limited to the diameter of that syringe. Any cross-section cut higher than the diameter becomes a "gripper" of sorts and may be beneficial, but impedes this calculation. It can be added later as a parameter sum of an arbitrary distance of percentage. <http://forum.openscad.org/file/t824/syringelayout.png> The centers of the circles are the parametric aspect that currently escapes me. I know it's simple, but the pounding headache I have is preventing me from proceeding. What I have been able to determine is that the spacing of the center of the second circle from the first circle is the diameter of the second circle minus the distance of the chord of the second circle from its center, with the chord of the second circle being the diameter of the first circle. I've done math of this sort before and have found an abundance of formulae to solve for this result. Because each circle references the preceding circle, the primary formula should be iterative, allowing for as many circle stacks as desired. In the image above, I used syringe diameters based on arbitrarily taking the capacity and making those numbers diameters, only to manage a relatively proportional image. I found a web page containing the formula <https://www.ck12.org/trigonometry/Length-of-a-Chord/lesson/Length-of-a-Chord-TRIG/> I'd likely use to pursue this as an OpenSCAD project. The "welded" version of the above diagram: <http://forum.openscad.org/file/t824/syringelayout2.png> -- Sent from: http://forum.openscad.org/
N
NateTG
Tue, Apr 10, 2018 7:28 PM
...  spacing of the center of the second circle from the first circle is
the chord of the second circle being the diameter of the first circle. ...
Unless you want to get fancy, if you have circles with radius r_0 and r_1,
then the z-distance between centers is
simply sqrt(r_1r_1 - r_0r_0) since there's a right triangle.
A (probably managable) issue with this design is that the position of the
center line of the syringe then depends on the syringe size, so the other
parts need to accommodate that as well.
> ... spacing of the center of the second circle from the first circle is the diameter of the second circle minus the distance of the chord of the second circle from its center, with the chord of the second circle being the diameter of the first circle. ... Unless you want to get fancy, if you have circles with radius r_0 and r_1, then the z-distance between centers is simply sqrt(r_1*r_1 - r_0*r_0) since there's a right triangle. A (probably managable) issue with this design is that the position of the center line of the syringe then depends on the syringe size, so the other parts need to accommodate that as well. -- Sent from: http://forum.openscad.org/
F
fred_dot_u
Tue, Apr 10, 2018 7:49 PM
It's not the distance between centers, it's the distance between the center
of circle 1 and the center of circle 2 minus the distance from the chord on
circle 2 that has the diameter of circle 1, if the other aspects of the
design are valid.
I had not considered that the center line of the syringe has to be
maintained, and the information from the OP doesn't give that indication.
If it's necessary to maintain a common center, it would be easier to create
a series of inserts/sleeves to secure each smaller syringe in the larger
mounting hole.
It's not the distance between centers, it's the distance between the center of circle 1 and the center of circle 2 minus the distance from the chord on circle 2 that has the diameter of circle 1, if the other aspects of the design are valid. I had not considered that the center line of the syringe has to be maintained, and the information from the OP doesn't give that indication. If it's necessary to maintain a common center, it would be easier to create a series of inserts/sleeves to secure each smaller syringe in the larger mounting hole. -- Sent from: http://forum.openscad.org/
N
NateTG
Tue, Apr 10, 2018 11:07 PM
Here's code to show what I'm thinking of:
cutout.scad http://forum.openscad.org/file/t2140/cutout.scad
Here's code to show what I'm thinking of: cutout.scad <http://forum.openscad.org/file/t2140/cutout.scad> -- Sent from: http://forum.openscad.org/
N
NateTG
Wed, Apr 11, 2018 3:36 AM
FWIW: I ran down the project that this appears to be based on:
https://github.com/naroom/OpenSyringePump
FWIW: I ran down the project that this appears to be based on: https://github.com/naroom/OpenSyringePump -- Sent from: http://forum.openscad.org/
