OpenSCAD 2014.03 on Debian 7.7 renders some facets incorrectly
in the preview window, and the axes are unlabelled (should show X Y Z).
Here is an example showing the problem
https://lh4.googleusercontent.com/-ojCJY79vWDQ/VKH9U3q7dbI/AAAAAAAAD-Q/HNOOUecOF0M/s512/OpenSCAD-problem.jpg
Most of the model appears as expected, but a subset of facets appear full
white.
The problem appears on all .scad files.
Computer:
Debian 7.7 (wheezy) 64-bit
Linux 3.2.0-4-amd64
GNOME 3.4.2
Video Card:
NVIDIA G98 [GeForce 8400 GS] with Nouveau driver
Display:
Resolution 1280x1024 pixels
OpenGL Renderer: Gallium 0.4 on NV98
$ lspci -nn | grep VGA
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation G98 [GeForce
8400 GS] [10de:06e4] (rev a1)
At first I assumed it was just the Nouveau driver or OpenGL renderer was
broken.
But as a check, after doing this:
http://askubuntu.com/questions/299345/how-to-enable-webgl-in-chrome-on-ubuntu
...I found that this WebGL 3D rendering demo works OK (Chrome browser):
https://developer.mozilla.org/en-US/demos/detail/formula1-using-threejs
Last month when this computer was still running Windows XP, I did not see
this problem; I had OpenSCAD 2014.03 rendering OK.
I am reluctant to switch out Nouveau for the NVIDIA proprietary driver
because everything else works. I have tried the NVIDIA driver before on
this box in several different Ubuntu and Debian installs and the computer
would not often even boot up after a suspend, or sometimes even a cold
reset.
View this message in context: http://forum.openscad.org/2014-03-on-Debian-7-7-preview-rendering-problem-some-facets-100-white-tp10803.html
Could you please try if the snapshot version shows the same issue?
See http://www.openscad.org/downloads.html#snapshots-linux-auto for details.
The package and binary are called openscad-nightly to make them installable
in parallel to the normal release version.
Thank you very much for that link! I can confirm that the rendering bug is
fixed on my Debian 7.7 x64 system, using OpenSCAD version 2014.12.30.nightly
(git bebe084)
Now back to being a happy OpenSCAD user!
regards,
John
View this message in context: http://forum.openscad.org/2014-03-on-Debian-7-7-preview-rendering-problem-some-facets-100-white-tp10803p10812.html
