Code now working, I'll run your plate through it, see how it works.
-------- Forwarded Message --------
Subject: Re: fan ducts etc
Date: Wed, 30 Nov 2022 21:08:08 +0000
To: gene heskett gheskett@shentel.net
I've been writing the c++ for getting svg to gcode. It is going well,
for my machine. Instead of putting the exact feed and speeds into the
c++ writing program, I've put in place markers for later text editing,
which is usually the way i do it anyway. One minor snag, but easy enough
to fix, like openscad polygons, svg leaves out the last connecting line,
but a square needs 5 g01 commands to get it back to the start position.,
whereas the svg only needs the four corners.
To: gene heskett <gheskett@shentel.net>
