Compiling for Windows
Jamie_K
Mon, Jun 20, 2016 5:03 AM
Hey all, I've tried following the instructions here:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Cross-compiling_for_Windows_on_Linux_or_Mac_OS_X
And I've been having a hell of a time.
  1. Installed fresh Fedora 23 (64-bit) on a VM
  2. Installed mxe dependencies
    dnf install
    autoconf automake bash bison bzip2 flex gcc-c++
    gdk-pixbuf2-devel gettext git gperf intltool make
    sed libffi-devel libtool openssl-devel p7zip patch
    perl pkgconfig python ruby scons unzip wget xz
  3. Downloaded and built mxe
    git clone git://github.com/mxe/mxe.git
    cd mxe
    make mpfr eigen opencsg cgal qt
    export PATH=/home/jamie/usr/bin:$PATH
    since this make command succeeds without errors, I believe it worked.
  4. Download and prepare to build OpenSCAD
    cd
    git clone git://github.com/openscad/openscad.git
    cd openscad
    git submodule init
    git submodule update
    ln -s /home/jamie/mxe/usr/i686-w64-mingw32.static/ mingw-cross-env
At this point nothing I try seems to work.
This works but I'm unsure if it populates the correct values:
source ./scripts/setenv-mingw-xbuild.sh 64
Trying this script gives me an error about missing cmake:
./scripts/mingw-x-build-dependencies.sh
But I have cmake (or the nearest thing) at
/home/jamie/mxe/usr/bin/i686-w64-mingw32.static-cmake
but plain 'cmake' is nowhere in the path according to 'which cmake'
I also tried what look like explicit instructions for building, adapting the
qmake command line from near the bottom of the wiki page to the nearest
qmake in my path:
i686-w64-mingw32.static-qmake-qt4 CONFIG+=mingw-cross-env openscad.pro
And it complains about eigen3 (and harfbuzz and freetype2) not being found
in pkg-config search path.
I have also tried the commands from the README.md file, with similar
results.
Is there a complete set of instructions somewhere?  Or is there a specific
set of component versions that is known to work?
-Jamie
View this message in context: http://forum.openscad.org/Compiling-for-Windows-tp17766.html
Hey all, I've tried following the instructions here: https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Cross-compiling_for_Windows_on_Linux_or_Mac_OS_X And I've been having a hell of a time. 1. Installed fresh Fedora 23 (64-bit) on a VM 2. Installed mxe dependencies dnf install \ autoconf automake bash bison bzip2 flex gcc-c++ \ gdk-pixbuf2-devel gettext git gperf intltool make \ sed libffi-devel libtool openssl-devel p7zip patch \ perl pkgconfig python ruby scons unzip wget xz 3. Downloaded and built mxe git clone git://github.com/mxe/mxe.git cd mxe make mpfr eigen opencsg cgal qt export PATH=/home/jamie/usr/bin:$PATH since this make command succeeds without errors, I believe it worked. 4. Download and prepare to build OpenSCAD cd git clone git://github.com/openscad/openscad.git cd openscad git submodule init git submodule update ln -s /home/jamie/mxe/usr/i686-w64-mingw32.static/ mingw-cross-env At this point nothing I try seems to work. This works but I'm unsure if it populates the correct values: source ./scripts/setenv-mingw-xbuild.sh 64 Trying this script gives me an error about missing cmake: ./scripts/mingw-x-build-dependencies.sh But I have cmake (or the nearest thing) at /home/jamie/mxe/usr/bin/i686-w64-mingw32.static-cmake but plain 'cmake' is nowhere in the path according to 'which cmake' I also tried what look like explicit instructions for building, adapting the qmake command line from near the bottom of the wiki page to the nearest qmake in my path: i686-w64-mingw32.static-qmake-qt4 CONFIG+=mingw-cross-env openscad.pro And it complains about eigen3 (and harfbuzz and freetype2) not being found in pkg-config search path. I have also tried the commands from the README.md file, with similar results. Is there a complete set of instructions somewhere? Or is there a specific set of component versions that is known to work? -Jamie -- View this message in context: http://forum.openscad.org/Compiling-for-Windows-tp17766.html Sent from the OpenSCAD mailing list archive at Nabble.com.
B
buttim
Mon, Jun 20, 2016 10:13 AM
Which version of cmake have you installed? I seem to remember I had the same
problem and solved it downgrading cmake to version 2.8.4
View this message in context: http://forum.openscad.org/Compiling-for-Windows-tp17766p17767.html
Which version of cmake have you installed? I seem to remember I had the same problem and solved it downgrading cmake to version 2.8.4 -- View this message in context: http://forum.openscad.org/Compiling-for-Windows-tp17766p17767.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Jun 20, 2016 3:05 PM
Hard to say without attempting to reproduce, but some ideas:
o Could this be a 32-bit/64-bit mixup? The scripts you’re using take an argument specifying which Windows architecture to build for. That could explain path issues.
o It’s also possible to build natively under Windows (experimental), see https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Building_on_Microsoft_Windows
If you’re a skilled Windows user it might be better to start off with the second option.
(but I also say that because we’d love some help on improving support for Windows as we don’t have any Windows devs on the team right now :))
Cheers,
Hard to say without attempting to reproduce, but some ideas: o Could this be a 32-bit/64-bit mixup? The scripts you’re using take an argument specifying which Windows architecture to build for. That could explain path issues. o It’s also possible to build natively under Windows (experimental), see https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Building_on_Microsoft_Windows If you’re a skilled Windows user it might be better to start off with the second option. (but I also say that because we’d love some help on improving support for Windows as we don’t have any Windows devs on the team right now :)) Cheers, -Marius
Jamie_K
Tue, Jun 21, 2016 5:56 AM
Ok I feel silly.  I was missing cmake, just like the error message was
telling me.  I had a cross-environment cmake binary but I was missing the
/native/ cmake, so it was sufficient to install it:
dnf install cmake
I'm still building openscad_deps now, and it is progressing well enough, I
think it might work this time.
Once all is done, I think I might report back on what went well and what
tripped me up.
-Jamie
View this message in context: http://forum.openscad.org/Compiling-for-Windows-tp17766p17778.html
Ok I feel silly. I was missing cmake, just like the error message was telling me. I had a cross-environment cmake binary but I was missing the /native/ cmake, so it was sufficient to install it: dnf install cmake I'm still building openscad_deps now, and it is progressing well enough, I think it might work this time. Once all is done, I think I might report back on what went well and what tripped me up. -Jamie -- View this message in context: http://forum.openscad.org/Compiling-for-Windows-tp17766p17778.html Sent from the OpenSCAD mailing list archive at Nabble.com.
B
buttim
Wed, Jun 22, 2016 8:44 AM
Your report will be greatly appreciated! I had some luck in the past trying
to rebuild under Windows but am not currently able to do it.
View this message in context: http://forum.openscad.org/Compiling-for-Windows-tp17766p17793.html
Your report will be greatly appreciated! I had some luck in the past trying to rebuild under Windows but am not currently able to do it. -- View this message in context: http://forum.openscad.org/Compiling-for-Windows-tp17766p17793.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Jun 22, 2016 9:28 AM
That seems to be a different topic. What Jamie is doing is the same
way the official Windows binaries are built.
Those are created on a Linux system using the MXE build environment
(See http://mxe.cc/).
For "native" Windows compilation (meaning using Visual Studio and
friends) there is currently no known solution as we don't have
someone who works with that and could give a guideline.
What I tried successfully is building in the MSYS2 environment which
is basically a Unix environment layer on Windows. This is documented
in the manual:
This at least works with the QtCreator as IDE. I don't know if that
still works, but some people did use that procedure successfully in
the past.
Von: buttim <maurizio.butti@gmail.com> > Your report will be greatly appreciated! I had some luck in the past trying > to rebuild under Windows but am not currently able to do it. > That seems to be a different topic. What Jamie is doing is the same way the official Windows binaries are built. Those are created on a Linux system using the MXE build environment (See http://mxe.cc/). For "native" Windows compilation (meaning using Visual Studio and friends) there is currently no known solution as we don't have someone who works with that and could give a guideline. What I tried successfully is building in the MSYS2 environment which is basically a Unix environment layer on Windows. This is documented in the manual: https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Building_on_Microsoft_Windows This at least works with the QtCreator as IDE. I don't know if that still works, but some people did use that procedure successfully in the past. ciao, Torsten.
B
buttim
Wed, Jun 22, 2016 2:47 PM
Sorry, what I actually meant was "for Windows". I am trying the cross
compilation route too.
Still struggling with strange errors in compiling dependencies, namely glib.
The errors seems to be "m4_copy: won't overwrite defined macro: glib_DEFUN".
Still checking for trivial errors though.
tp3 wrote
Von: buttim <
maurizio.butti@
trying
in the manual:
the past.
Discuss@.openscad
View this message in context: http://forum.openscad.org/Compiling-for-Windows-tp17766p17798.html
Sorry, what I actually meant was "for Windows". I am trying the cross compilation route too. Still struggling with strange errors in compiling dependencies, namely glib. The errors seems to be "m4_copy: won't overwrite defined macro: glib_DEFUN". Still checking for trivial errors though. tp3 wrote > Von: buttim &lt; > maurizio.butti@ > &gt; >> Your report will be greatly appreciated! I had some luck in the past >> trying >> to rebuild under Windows but am not currently able to do it. >> > That seems to be a different topic. What Jamie is doing is the same > way the official Windows binaries are built. > Those are created on a Linux system using the MXE build environment > (See http://mxe.cc/). > > For "native" Windows compilation (meaning using Visual Studio and > friends) there is currently no known solution as we don't have > someone who works with that and could give a guideline. > > What I tried successfully is building in the MSYS2 environment which > is basically a Unix environment layer on Windows. This is documented > in the manual: > https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Building_on_Microsoft_Windows > > This at least works with the QtCreator as IDE. I don't know if that > still works, but some people did use that procedure successfully in > the past. > > ciao, > Torsten. > > _______________________________________________ > OpenSCAD mailing list > Discuss@.openscad > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- View this message in context: http://forum.openscad.org/Compiling-for-Windows-tp17766p17798.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Jun 22, 2016 6:02 PM
Hmm, that's strange as this process and the scripts are used
for the official builds and MXE is pretty self-contained.
Although we don't compile all the dependencies for every build,
so there could be an actual MXE issue too. But in general it's
quite stable - especially for the more commonly used packages.
On 06/22/2016 04:47 PM, buttim wrote: > Sorry, what I actually meant was "for Windows". I am trying the cross > compilation route too. > Hmm, that's strange as this process and the scripts are used for the official builds and MXE is pretty self-contained. Although we don't compile all the dependencies for every build, so there could be an actual MXE issue too. But in general it's quite stable - especially for the more commonly used packages. ciao, Torsten.
B
buttim
Thu, Jun 23, 2016 9:31 AM
What I discovered right now is that having libgl2.0-dev installed caused the
problem.
It manifested with the following message in the build  log
"error: m4_copy: won't overwrite defined macro: glib_DEFUN"
I'm using Ubuntu 16.04
View this message in context: http://forum.openscad.org/Compiling-for-Windows-tp17766p17800.html
What I discovered right now is that having libgl2.0-dev installed caused the problem. It manifested with the following message in the build log "error: m4_copy: won't overwrite defined macro: glib_DEFUN" I'm using Ubuntu 16.04 -- View this message in context: http://forum.openscad.org/Compiling-for-Windows-tp17766p17800.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Jamie_K
Thu, Jun 23, 2016 10:00 AM
First I'd like to say buttim's comment about the cmake version dependency was
spot on.  Later versions of cmake (not exactly sure but guessing cmake 3.3.0
and later) will fail on the version of cgal (4.5) pulled by the openscad
fork of mxe (https://github.com/openscad/mxe).
Unfortunately it appears my Fedora 23 cannot downgrade cmake low enough for
it to work with cgal 4.5.  It might have been possible to get an older cmake
by going outside the package manager to install the older cmake, but that's
beyond what I have patience for, so I'm basically stuck with the newer,
incompatible cmake.
Ultimately I was able to build two ways:
  1. By using the latest mxe and fixing a dynamic vs. static bug in it
  2. By fixing cgal 4.5 to be compatible with cmake 3.4.3
For the first method, pointing to the latest mxe was fairly simple:
  1. Get all the openscad stuff
    git clone https://github.com/openscad/openscad.git
  2. modify scripts/mingw-x-build-dependencies.sh to point to mxe/mxe.git
    instead of openscad/mxe.git by modifying line 69 to be:
    git clone git://github.com/mxe/mxe.git $MXEDIR
    and also remove "git checkout openscad-snapshot-build", to get master
    instead of branch
  3. within release-common.sh, change references 'i686-pc-mingw32-makensis' to
    'i686-w64-mingw32.static-makensis' instead, since that's the name of the
    makensis binary (lines 136 and 144)
  4. There is apparently a bug in the latest mxe, where it will always build
    shared libraries for cgal regardless of whether static or dynamic is
    requested.  I believe this update introduced the problem:
    https://github.com/mxe/mxe/commit/9f0dbfafc60b725dc09c85059b5b58c3298e3319
    This update removed "-DBUILD_SHARED_LIBS=OFF" and added
    "-DCGAL_BUILD_SHARED_LIBS=$(CMAKE_SHARED_BOOL)"
    but it seems that cgal makefiles don't much care about the value of
    CGAL_BUILD_SHARED_LIBS and when BUILD_SHARED_LIBS is unspecified, it
    defaults to dynamic.
    I submitted an issue https://github.com/mxe/mxe/issues/1402
    And as a workaround, I modified the ~/openscad_deps/mxe-w64/src/cgal.mk,
    changing back to '-DBUILD_SHARED_LIBS=FALSE'
  5. The static and dynamic libraries can't both be present, so if you've
    accidentally built the dynamic ones libCGAL.dll.a, libCGAL_Core.dll.a,
    libCGAL_ImageIO.dll.a, and libCGAL_Qt4.dll.a, these must be removed or else
    the final linking of the .exe will fail.  They reside in
    ~/openscad_deps/mxe-w64/usr/i686-w64-mingw32.static/lib/  Remove the
    ".dll.a" versions and leave the ".a" versions.
  6. Then building openscad works, via ./scripts/release-common.sh mingw32
Now, to fix cgal 4.5 so that it doesn't fail with newer cmake...  this was a
challenge.
First I observed that it generated two log files, one here, which seemed
useless:
~/openscad_deps/mxe/tmp-cgal-i686-w64-mingw32.static/CGAL-4.5/CMakeFiles/CMakeOutput.log
and another one here, which was more informative:
~/openscad_deps/mxe/log/cgal_i686-w64-mingw32.static
The latter gave this as the error:
-- Sources for CGAL component library 'CGAL_Qt4/CMakeLists.txt' detected
CMake Error at src/CMakeLists.txt:81 (add_subdirectory):
add_subdirectory given source
"/home/vector/openscad_deps/mxe/tmp-cgal-i686-w64-mingw32.static/CGAL-4.5/src/CGAL_Qt4/CMakeLists.txt"
which is not an existing directory.
Apparently it was choking from being given a file (.../CMakeLists.txt) when
it was expecting a directory.  After a LOT of digging I found the place
where the string was generated, coinciding with a commit on the CGAL source
tree with a promising comment:
https://github.com/CGAL/cgal/commit/61e61220eb43ea8c3d4a6ebd84d44b0510d8533d
This seemed like a 'smoking gun' for the string being messed up due to a
cmake version dependence.
To fix it, I modified the CGAL package, at
~/openscad_deps/mxe/CGAL-4.5.tar.xz.  I opened the archive and essentially
applied the patch, replacing "string(REPLACE ...)" with
"get_filename_component(...)" as shown in the commit.  The proper way to do
this would be to insert a patch into the mxe/src, but I don't know the
details of how to do that.
I then recompiled cgal (from mxe directory, "make
build-only-cgal_i686-w64-mingw32.static"), using build-only to prevent
checksum failure and re-download from wiping my changes to CGAL-4.5.tar.xz.
Finally, I was ready to try compiling openscad itself:
This went without a hitch, and the resulting .exe worked.
-Jamie
View this message in context: http://forum.openscad.org/Compiling-for-Windows-tp17766p17801.html
First I'd like to say buttim's comment about the cmake version dependency was spot on. Later versions of cmake (not exactly sure but guessing cmake 3.3.0 and later) will fail on the version of cgal (4.5) pulled by the openscad fork of mxe (https://github.com/openscad/mxe). Unfortunately it appears my Fedora 23 cannot downgrade cmake low enough for it to work with cgal 4.5. It might have been possible to get an older cmake by going outside the package manager to install the older cmake, but that's beyond what I have patience for, so I'm basically stuck with the newer, incompatible cmake. Ultimately I was able to build two ways: 1. By using the latest mxe and fixing a dynamic vs. static bug in it 2. By fixing cgal 4.5 to be compatible with cmake 3.4.3 For the first method, pointing to the latest mxe was fairly simple: 1. Get all the openscad stuff git clone https://github.com/openscad/openscad.git 2. modify scripts/mingw-x-build-dependencies.sh to point to mxe/mxe.git instead of openscad/mxe.git by modifying line 69 to be: git clone git://github.com/mxe/mxe.git $MXEDIR and also remove "git checkout openscad-snapshot-build", to get master instead of branch 3. within release-common.sh, change references 'i686-pc-mingw32-makensis' to 'i686-w64-mingw32.static-makensis' instead, since that's the name of the makensis binary (lines 136 and 144) 4. There is apparently a bug in the latest mxe, where it will always build shared libraries for cgal regardless of whether static or dynamic is requested. I believe this update introduced the problem: https://github.com/mxe/mxe/commit/9f0dbfafc60b725dc09c85059b5b58c3298e3319 This update removed "-DBUILD_SHARED_LIBS=OFF" and added "-DCGAL_BUILD_SHARED_LIBS=$(CMAKE_SHARED_BOOL)" but it seems that cgal makefiles don't much care about the value of CGAL_BUILD_SHARED_LIBS and when BUILD_SHARED_LIBS is unspecified, it defaults to dynamic. I submitted an issue https://github.com/mxe/mxe/issues/1402 And as a workaround, I modified the ~/openscad_deps/mxe-w64/src/cgal.mk, changing back to '-DBUILD_SHARED_LIBS=FALSE' 5. The static and dynamic libraries can't both be present, so if you've accidentally built the dynamic ones libCGAL.dll.a, libCGAL_Core.dll.a, libCGAL_ImageIO.dll.a, and libCGAL_Qt4.dll.a, these must be removed or else the final linking of the .exe will fail. They reside in ~/openscad_deps/mxe-w64/usr/i686-w64-mingw32.static/lib/ Remove the ".dll.a" versions and leave the ".a" versions. 6. Then building openscad works, via ./scripts/release-common.sh mingw32 Now, to fix cgal 4.5 so that it doesn't fail with newer cmake... this was a challenge. First I observed that it generated two log files, one here, which seemed useless: ~/openscad_deps/mxe/tmp-cgal-i686-w64-mingw32.static/CGAL-4.5/CMakeFiles/CMakeOutput.log and another one here, which was more informative: ~/openscad_deps/mxe/log/cgal_i686-w64-mingw32.static The latter gave this as the error: > -- Sources for CGAL component library 'CGAL_Qt4/CMakeLists.txt' detected > CMake Error at src/CMakeLists.txt:81 (add_subdirectory): > add_subdirectory given source > > "/home/vector/openscad_deps/mxe/tmp-cgal-i686-w64-mingw32.static/CGAL-4.5/src/CGAL_Qt4/CMakeLists.txt" > which is not an existing directory. Apparently it was choking from being given a file (.../CMakeLists.txt) when it was expecting a directory. After a LOT of digging I found the place where the string was generated, coinciding with a commit on the CGAL source tree with a promising comment: https://github.com/CGAL/cgal/commit/61e61220eb43ea8c3d4a6ebd84d44b0510d8533d This seemed like a 'smoking gun' for the string being messed up due to a cmake version dependence. To fix it, I modified the CGAL package, at ~/openscad_deps/mxe/CGAL-4.5.tar.xz. I opened the archive and essentially applied the patch, replacing "string(REPLACE ...)" with "get_filename_component(...)" as shown in the commit. The proper way to do this would be to insert a patch into the mxe/src, but I don't know the details of how to do that. I then recompiled cgal (from mxe directory, "make build-only-cgal_i686-w64-mingw32.static"), using build-only to prevent checksum failure and re-download from wiping my changes to CGAL-4.5.tar.xz. Finally, I was ready to try compiling openscad itself: ./scripts/release-common.sh mingw32 This went without a hitch, and the resulting .exe worked. -Jamie -- View this message in context: http://forum.openscad.org/Compiling-for-Windows-tp17766p17801.html Sent from the OpenSCAD mailing list archive at Nabble.com.
