SL
Steve Lelievre
Thu, Jan 19, 2023 4:49 PM
Terry,
If you go with your second option of using the plywood plate with a
cut-out, then this code should help. You would add a straight cylinder
at the top to form your push-in attachment, and a lugs with screw holes
at the bottom for fixing the plywood.
Cheers,
Steve
module funnel(h, d, x, y) {
// Makes a solid shape that is a rectangle at one end and a circle
at the other.
// Could easily be adapted for shaping any regular polygon to any
other regular polygon.
// h: transition height, d: diameter of circular end, x: x-dimension
(length) of rectangular end, y: y-dimension (width) of rectangular end.
hull() {
resize([d, d, h]) cylinder(h = 1, d1 = 0, d2 = 1, $fn =
60); // inverted cone
resize([x, y, h]) rotate(45) cylinder(h = 1, d1 = 1, d2 = 0, $fn
= 4); // cone with 4 sides: pyramid
// Example with additional use of multmatrix to shear the funnel shape
so that the top is off-centre.
height = 20; diameter = 15; length = 40; width = 30; wall = 2; xOffset
= 10; yOffset = 7;
shear = [[1, 0, xOffset / height], [0, 1, yOffset / height]];
multmatrix(shear) funnel(height, diameter + wall, length + wall,
width + wall);
multmatrix(shear) funnel(height, diameter, length, width);
On 2023-01-19 8:06 a.m., fred via Discuss wrote:
Terry,
Cheers,
Steve
at the other.
hull() {
= 10; yOffset = 7;
width + wall);
Terry
Thu, Jan 19, 2023 5:13 PM
Thanks Steve, that would be handy because I expect I do have some
aluminium or plastic tubing that would be the right diameter for my
hose - but my hole cutters are unlikely to match it.
Did it preview OK for you? I took the first section and pasted it into a
new file, but then had various problems with EOLs. With those fixed(I
think) the following gave me: WARNING: No top level geometry to render.
// Makes a solid shape that is a rectangle at one end and a circle at
the other.
// Could easily be adapted for shaping any regular polygon to any other
regular polygon.
//(length) of rectangular end, y: y-dimension (width) of rectangular
end.
hull() {
resize([d, d, h]) cylinder(h = 1, d1 = 0, d2 = 1, $fn = 60);
// inverted cone
resize([x, y, h]) rotate(45) cylinder(h = 1, d1 = 1, d2 = 0, $fn = 4);
On Thu, 19 Jan 2023 08:49:28 -0800, you wrote:
Terry,
Cheers,
Steve
at the other.
hull() {
= 10; yOffset = 7;
width + wall);
the other.
regular polygon.
end.
hull() {
// inverted cone
>Terry,
>Cheers,
>Steve
>at the other.
> hull() {
>= 10; yOffset = 7;
>difference() {
>width + wall);
SL
Steve Lelievre
Thu, Jan 19, 2023 5:54 PM
Terry,
The EOL issue is probably from the source code being messed up when I
pasted it into an email. The lack of geometry to render is because the
first block is a module that gets called from the second part. You need
to include all the sample code to see any output.
In my first message, I forgot to point out that the example funnel
dimensions are the inner dimensions of the two ends of the funnel. You
may need to compensate for that if you're making a shape that goes over
a fitting rather than into it.
Steve
the other.
regular polygon.
end.
hull() {
// inverted cone
Terry,
Cheers,
Steve
at the other.
hull() {
= 10; yOffset = 7;
width + wall);
Terry,
Steve
> the other.
> regular polygon.
> end.
> hull() {
> // inverted cone
>> Terry,
>> Cheers,
>> Steve
>> at the other.
>> hull() {
>> = 10; yOffset = 7;
>> difference() {
>> width + wall);
Terry
Thu, Jan 19, 2023 6:56 PM
Careless of me! Looks good now, thanks.
On Thu, 19 Jan 2023 09:54:39 -0800, you wrote:
Terry,
Steve
the other.
regular polygon.
end.
hull() {
// inverted cone
Terry,
Cheers,
Steve
at the other.
hull() {
= 10; yOffset = 7;
width + wall);
>Terry,
>Steve
>> the other.
>> regular polygon.
>> end.
>> hull() {
>> // inverted cone
>>> Terry,
>>> Cheers,
>>> Steve
>>> at the other.
>>> hull() {
>>> = 10; yOffset = 7;
>>> difference() {
>>> width + wall);
