Hello,
Watching memory usage with Xfce task manager, I first notice that only one
cpu core is in use, and it is saturated. Can multiple cores be used? Second,
my simple little model, a perforated tube geometry, is dying before
rendering is finished, unless I reduce the tube length to about half of what
I need to generate. Memory used does not appear to reach 100% of 4GB, so I'm
guessing this has more to do with fragmentation than real consumption. I
last saw it using about 75%, went away for 10 minutes, and it was crashed
when I returned to check on it. So I'm not "certain" about this, just my
best guess...
Anyone care to comment or have you seen this happening on 64 bit systems?
Thanks,
Bill
View this message in context: http://forum.openscad.org/memory-use-32-bit-Linux-system-version-2014-10-02-tp10374.html
Currently that's not possible.
https://github.com/openscad/openscad/issues/391 is did not succeed in
attracting developers yet ;-).
Second, my simple little model, a perforated tube geometry, is dying before
I need to generate.
Without looking at the model, it's hard to guess what the cause could
be. Crashes could be caused by recursion using up the stack (fix for that
is on the way) or it could be due to bad geometry generated, e.g. due
to rounding issues...
I would be happy to post the model file, if that is ok for this list. It
is very small. It is
also my very first model generation attempt! Liking this SCAD program.
-bill
only one
before
of what
I need to generate.
Feel free to share it.
View this message in context: http://forum.openscad.org/memory-use-32-bit-Linux-system-version-2014-10-02-tp10374p10384.html
oz.at.michael@gmail.com
Ok, since it is so tiny I'll just paste it inline.
BTW: the t_len variable is desired to be 420mm.
-bill
echo(version=version());
t_len = 105;
seg_h = 6; //6mm tall ring segment
base = seg_h/2; //get back to zero on Z axis
ID = 48; //main tube ID
OD = 50; //main tube OD
h_cc = 6; //center-to-center perforation spacing
h_dia = 3; //perforation hole diameter
p_deg = 360/(PIOD/h_cc); //degrees between perf holes
n_rot = floor(PIOD/h_cc) -1; //inner loop count
//weird, but it does the job!
function O(cnt) = cnt*p_deg/2 ; //rotate around the tube this much
"extra" each ring segment along length
module perf_tube()
translate( [0, 0, t_len/2] )
cylinder(h = t_len, d=OD, $fn=100, center = true);
cylinder(h = t_len, d=ID, $fn=100, center = true);
for ( j = [0 : t_len/seg_h] ) {
translate( [0, 0, (j*seg_h) + base] )
for ( i = [ 0 : n_rot ] ) {
rotate( [90, 0, i*p_deg + O(j)] )
translate( [0, 0, (ID+OD)/4] )
cylinder(h = OD-ID+1, d = h_dia, $fn=100, center = true);
perf_tube();
Well, that is doing something strange, I'll have to look deeper.
It managed to get OpenSCAD to use 95% of my dual core CPU (and almost hang
the app), which is strange for a non-multi threaded app...
View this message in context: http://forum.openscad.org/memory-use-32-bit-Linux-system-version-2014-10-02-tp10374p10388.html
BTW, I'd suggest getting something later than 2014.10.02, it had issues.
View this message in context: http://forum.openscad.org/memory-use-32-bit-Linux-system-version-2014-10-02-tp10374p10389.html
That's strange, I got noheads email (below), but it is not posted here???
I think $fn = 100 for a 3mm hole is excessive. It will take a very long
time and produce more precision than is needed for most manufacturing
techniques.
I agree, but with $fn=10 everywhere it is still behaving badly.
View this message in context: http://forum.openscad.org/memory-use-32-bit-Linux-system-version-2014-10-02-tp10374p10390.html
Ok, thanks for taking a look. I'm not intending to
"manufacture" as in 3-d printing, just create a good mesh file
to input to the SU2 code from Stanford. Once I get the file format
into something SU2 likes...
-bill
ps: recommended version of openSCAD?
techniques.
Current snapshot 2014.12.04 here http://www.openscad.org/downloads.html
, may have some features to handle memory better and performance is better
too.
I'm running Win 7/64 OpenSCAD 64bit, I used the 2014.03 Production Release.
With slightly modified code (incl somewhat lower $fn values), I just did a
t_len = 420, F6 (no F5) it took 2h 14m 38s, and used 1.55GB of memory. That
has 1750 holes and taxes OpenSCAD, F5 is useless and F6 takes a long time.
The export to STL took a few minutes and not much more memory.
Do you want this STL (ie a bit chunkier than yours but looks OK to me)?
I'm going to try refactoring to see if there is a better way.
View this message in context: http://forum.openscad.org/memory-use-32-bit-Linux-system-version-2014-10-02-tp10374p10392.html
