I see that we now have is_list(), is_num(), is_bool(), and is_string(), but
there is no is_range. It seems like maybe right now you can write
function is_range(x) = !is_list(x) && !is_num(x) && !is_bool(x) &&
!is_string(x), but I'm not sure if I've missed anything, and this seems kind
of clumsy. Also it's problematic down the road if a new type is ever added.
Have I missed something here?
It's not likely that is_range() will ever be added.
See https://github.com/openscad/openscad/issues/1584 for details.
In issue 1584, I was proposing that range values should behave exactly like lists of numbers, so that is_list([1:3]) would be true. I proposed this for OpenSCAD2 and implemented it in Curv. If there are no plans to ever unify lists and ranges in OpenSCAD, then it would make sense to introduce an is_range function.
function is_range(A) = is_num(A[0]) && !is_list(A);
A range checker needs to fulfill:
-- a list of all numbers
-- same distance for all i~i+1 pairs
function is_range(o, _d, _i=0){ _i==0? ( is_num(o[0]) && is_num(o[1])?
is_range( o, _d= o[1]-o[0], _i=1) : false ) : _i<length-1?
( is_num(o[i+1]) && _d != o[i+1]-o[i] ? false : is_range( o,
_d=_d, _i=_i+1) ) : true}</pre>
This code has not been tested yet.
My apology to the group for the wrong syntax in my previous post. I have been
working on javascript intensively and mess it up in my head with the syntax
of OpenSCAD. Here is the correct and tested one:
function is_range(o, _d, _i=0) =( _i==0? ( isnum(o[0]) && isnum(o[1])?
is_range( o, _d= o[1]-o[0], _i=1) : false ) : _i<len(o)-1?
( isnum(o[_i+1]) && _d != o[_i+1]-o[_i] ? false : is_range( o,
_d=_d, _i=_i+1) ) : true );</pre>Test:
| 0> is_range([2:6])= true| 1> is_range([2:2:10])= true| 2>
is_range([1,2,3])= true| 3> is_range([1,2,3,5])= false| 4> is_range("abc")=
false
I would expect a false in this case.
