Anyone got a complex polygon they can share?
Mon, Apr 17, 2017 7:51 AM
I'm having trouble getting 2D multi-threads to run for long.
and/or a complex hulled 2D object.
Something that renders longer than a blink.
View this message in context: http://forum.openscad.org/Anyone-got-a-complex-polygon-they-can-share-tp21257.html
I'm having trouble getting 2D multi-threads to run for long. and/or a complex hulled 2D object. Something that renders longer than a blink. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Anyone-got-a-complex-polygon-they-can-share-tp21257.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Apr 17, 2017 12:39 PM
If it is a problem to find data at all, the multithread approach might be
overkill.
View this message in context: http://forum.openscad.org/Anyone-got-a-complex-polygon-they-can-share-tp21257p21261.html
If it is a problem to find data at all, the multithread approach might be overkill. -- View this message in context: http://forum.openscad.org/Anyone-got-a-complex-polygon-they-can-share-tp21257p21261.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Apr 17, 2017 12:48 PM
Fractals?
2017-04-17 4:51 GMT-03:00 MichaelAtOz oz.at.michael@gmail.com:
Fractals? 2017-04-17 4:51 GMT-03:00 MichaelAtOz <oz.at.michael@gmail.com>: > I'm having trouble getting 2D multi-threads to run for long. > > and/or a complex hulled 2D object. > > Something that renders longer than a blink. > > > > ----- > Admin - PM me if you need anything, or if I've done something stupid... > > Unless specifically shown otherwise above, my contribution is in the > Public Domain; to the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. Obviously > inclusion of works of previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! > http://www.ourfairdeal.org/ time is running out! > -- > View this message in context: http://forum.openscad.org/ > Anyone-got-a-complex-polygon-they-can-share-tp21257.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
DS
Dan Shriver
Mon, Apr 17, 2017 9:26 PM
fractals are a good suggestion and you can get some ones that get weird
fast if you throw in trig functions:
http://www.mathrecreation.com/2009/08/hypocycloid-scrambler.html
I have an openScad program that does just that but I seem to have some bugs
in mine so the layers have gaps... and there are intersection problems...
On Mon, Apr 17, 2017 at 3:51 AM, MichaelAtOz oz.at.michael@gmail.com
fractals are a good suggestion and you can get some ones that get weird fast if you throw in trig functions: http://www.mathrecreation.com/2009/08/hypocycloid-scrambler.html I have an openScad program that does just that but I seem to have some bugs in mine so the layers have gaps... and there are intersection problems... On Mon, Apr 17, 2017 at 3:51 AM, MichaelAtOz <oz.at.michael@gmail.com> wrote: > I'm having trouble getting 2D multi-threads to run for long. > > and/or a complex hulled 2D object. > > Something that renders longer than a blink. > > > > ----- > Admin - PM me if you need anything, or if I've done something stupid... > > Unless specifically shown otherwise above, my contribution is in the > Public Domain; to the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. Obviously > inclusion of works of previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! > http://www.ourfairdeal.org/ time is running out! > -- > View this message in context: http://forum.openscad.org/ > Anyone-got-a-complex-polygon-they-can-share-tp21257.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Mon, Apr 17, 2017 10:20 PM
Don't need trigs. Sierpinski triangles grow exponentially, both in time and
space, with base 3.
size = 10;
tri = size*[[0,0],[1,0],[1/2,1]];
module Sierpinsky(n=2) {
if(n==0) polygon(tri);
else scale(1/2) {
translate(tri[0]) Sierpinsky(n-1);
translate(tri[1]) Sierpinsky(n-1);
translate(tri[2]) Sierpinsky(n-1);
//hull()
Sierpinsky(9);
Don't need trigs. Sierpinski triangles grow exponentially, both in time and space, with base 3. size = 10; tri = size*[[0,0],[1,0],[1/2,1]]; module Sierpinsky(n=2) { if(n==0) polygon(tri); else scale(1/2) { translate(tri[0]) Sierpinsky(n-1); translate(tri[1]) Sierpinsky(n-1); translate(tri[2]) Sierpinsky(n-1); } } //hull() Sierpinsky(9);
