Re: [OpenSCAD] New site for "omdl" (A Mechanical Design Library)
royasutton
Fri, Apr 14, 2017 3:38 PM
kwankung wrote
failed to compile (Windows OpenSCAD latest version 2015.03-2 ).
If possible, please obtain a recent OpenSCAD  development snapshot
http://www.openscad.org/downloads.html#snapshots  .
Once installed, obtain the referenced demo script from  Thingiverse
http://www.thingiverse.com/thing:2235154/#files  (see demo01.scad).
Please note, omdl v0.6.1 must be  installed
https://github.com/royasutton/omdl#recommended-install-method  to your
system. You can obtain a copy on  Thingiverse
http://www.thingiverse.com/thing:1934498  or from the source  repository
https://github.com/royasutton/omdl  . There are instructions on installing
at the  GitHub pages https://royasutton.github.io/omdl/  .
Hope this helps,
Roy
View this message in context: http://forum.openscad.org/New-site-for-omdl-A-Mechanical-Design-Library-tp20312p21232.html
kwankung wrote > failed to compile (Windows OpenSCAD latest version 2015.03-2 ). If possible, please obtain a recent OpenSCAD development snapshot <http://www.openscad.org/downloads.html#snapshots> . Once installed, obtain the referenced demo script from Thingiverse <http://www.thingiverse.com/thing:2235154/#files> (see demo01.scad). Please note, omdl v0.6.1 must be installed <https://github.com/royasutton/omdl#recommended-install-method> to your system. You can obtain a copy on Thingiverse <http://www.thingiverse.com/thing:1934498> or from the source repository <https://github.com/royasutton/omdl> . There are instructions on installing at the GitHub pages <https://royasutton.github.io/omdl/> . Hope this helps, Roy -- View this message in context: http://forum.openscad.org/New-site-for-omdl-A-Mechanical-Design-Library-tp20312p21232.html Sent from the OpenSCAD mailing list archive at Nabble.com.
