Why is this so heavy to OpenScad?
Mon, Nov 11, 2019 7:22 AM
If you hull spheres to make anything with accurate dimensions you want a
sphere() that has vertices on it poles and equator. See
https://github.com/nophead/NopSCADlib#Sphere
On Mon, 11 Nov 2019 at 02:14, MVAckel via Discuss <
Thank you guys. The new implementation is really lightning fast compared to
the old one. Solved the problem nicely.
If you hull spheres to make anything with accurate dimensions you want a sphere() that has vertices on it poles and equator. See https://github.com/nophead/NopSCADlib#Sphere On Mon, 11 Nov 2019 at 02:14, MVAckel via Discuss < discuss@lists.openscad.org> wrote: > > Thank you guys. The new implementation is really lightning fast compared to > the old one. Solved the problem nicely. > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
