I've ben experimenting with svg file import. It seems that openscad does
not render svg text.
e.g.
<svg xmlns = "http://www.w3.org/2000/svg" > <style>.small{ font: 12px sans-serif; fill: black; }</style> <text x = "212.000" y = "173.000" class = "small">not in openscad</text> </svg>displays fine in a browser, or image viewer, but not in openscad. Is
there any simple way around this, or any other 'gotchas' with openscad
and svg
Thanks
Ray
openscad does not render svg text.
Yes, correct, as documented in the manual:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/SVG_Import#Limitations
And also as written there, there will never be a perfect
import, simply because the format supports raster graphic
features that are impossible to translate to geometry. It
even includes JavaScript support for animation and other
things.
For text, the workaround can be to convert the text to a
path in Inkscape (I suppose other tools support that too)
That said, text support is possible but quite complicated
due to the full SVG text specification being very strange.
I started implementing this, if it will ever be finished, I
don't know.
