Thanks for your response. Yes, i considered using a Minkowsky sum, but it's so computationally intense that I was motivated to try to a more parsimonious way. This might make a useful enhancement that would probably be easy to implement.
----- Reply message -----
From: "Lucas Vinicius Hartmann" lucas.hartmann@gmail.com
To: "OpenSCAD general discussion" discuss@lists.openscad.org
Subject: [OpenSCAD] if intersection ?
Date: Thu, Oct 13, 2016 8:25 pm
Not natively, as far as I can tell.
I did find a way to hack it together, though:
https://github.com/lhartmann/HCAD/blob/master/ifsolid.scad
This actually uses Minkowski to grow the result of the intersection huge, unless there is no intersection and there is nothing to grow. This huge solid is then intersected with the "true" solid result, and subtracted from the "false" solid result, so only one of them remains.
Em 13 de out de 2016 22:18, "psnyder" paperbot13@gmail.com escreveu:Does anyone know if there is a way in openScad to determine if intersection
of 2 objects is empty? I'd like to use the info to conditionally create a
support structure for a 3D print.
Thx,
--paul
View this message in context: http://forum.openscad.org/if-intersection-tp18700.html
From: "Lucas Vinicius Hartmann" <lucas.hartmann@gmail.com>
To: "OpenSCAD general discussion" <discuss@lists.openscad.org>
Em 13 de out de 2016 22:18, "psnyder" <paperbot13@gmail.com> escreveu:Does anyone know if there is a way in openScad to determine if intersection
Thx,
--paul
