Preview Performance, repaint behaviour, Window resizing, Not Responding.
Sat, Dec 13, 2014 2:57 AM
See my issues with designs with lots of elements.
The multiple repaint shows up here, sometimes it flashes white/showing/white
a number of times.
Resizing the window with constant repaints is hopelessly slow.
Changing the view is really slow, often causing 'Not Responding'
Changing it to larger=false (100x100) is just usable.
Removing difference or using Thrown together works normally.
This is not version dependent, same in 2014.03, later versions are
marginally better.
Code
cut_-_memory_use.scad
http://forum.openscad.org/file/n10510/cut_-_memory_use.scad
Video (boring - sorry for all the waiting, but the flashing takes time and
is inconsistent)
v4_resampled_2.mp4 (8MB, 7m37s)
http://forum.openscad.org/file/n10510/v4_resampled_2.mp4
I'm happy to raise an issue of someone can supply words to describe that
behaviour more concisely.
View this message in context: http://forum.openscad.org/Preview-Performance-repaint-behaviour-Window-resizing-Not-Responding-tp10510.html
See my issues with designs with lots of elements. The multiple repaint shows up here, sometimes it flashes white/showing/white a number of times. Resizing the window with constant repaints is hopelessly slow. Changing the view is really slow, often causing 'Not Responding' Changing it to larger=false (100x100) is just usable. Removing difference or using Thrown together works normally. This is not version dependent, same in 2014.03, later versions are marginally better. Code cut_-_memory_use.scad <http://forum.openscad.org/file/n10510/cut_-_memory_use.scad> Video (boring - sorry for all the waiting, but the flashing takes time and is inconsistent) v4_resampled_2.mp4 (8MB, 7m37s) <http://forum.openscad.org/file/n10510/v4_resampled_2.mp4> I'm happy to raise an issue of someone can supply words to describe that behaviour more concisely. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Preview-Performance-repaint-behaviour-Window-resizing-Not-Responding-tp10510.html Sent from the OpenSCAD mailing list archive at Nabble.com.
S
Scalpel78
Sat, Dec 13, 2014 9:37 AM
Hi Michael, I can confirm the same bad performance here. Tried on both
2014-11-09 and 2014-12-04 versions on two Win64 machines.
View this message in context: http://forum.openscad.org/Preview-Performance-repaint-behaviour-Window-resizing-Not-Responding-tp10510p10512.html
Hi Michael, I can confirm the same bad performance here. Tried on both 2014-11-09 and 2014-12-04 versions on two Win64 machines. -- View this message in context: http://forum.openscad.org/Preview-Performance-repaint-behaviour-Window-resizing-Not-Responding-tp10510p10512.html Sent from the OpenSCAD mailing list archive at Nabble.com.
B
Bananapeel
Sat, Dec 13, 2014 10:12 AM
Although it is a bit sluggish, I don't have any "real" problems here.
Upgrading to the integrated graphics in your i7 3xxx processor will
definetely solve this problem for you.
View this message in context: http://forum.openscad.org/Preview-Performance-repaint-behaviour-Window-resizing-Not-Responding-tp10510p10513.html
Although it is a bit sluggish, I don't have any "real" problems here. Upgrading to the integrated graphics in your i7 3xxx processor will definetely solve this problem for you. -- View this message in context: http://forum.openscad.org/Preview-Performance-repaint-behaviour-Window-resizing-Not-Responding-tp10510p10513.html Sent from the OpenSCAD mailing list archive at Nabble.com.
