The functions filled_torus and torus are missing ?
View this message in context: http://forum.openscad.org/Rounding-convex-edges-without-minkowski-tp21621p21631.html
Excellent. I had to adjust some of the parameters to get the dimensions to
work out correctly, but the general scheme worked out very well. Rendering
is much faster, and the preview version is no longer needed. I updated the
script and credited you in the code, although only as "Ronaldo". Thank you.
View this message in context: http://forum.openscad.org/Rounding-convex-edges-without-minkowski-tp21621p21632.html
I tried to come up with my solution. First, I created a
two_connected_circles module:
include <rotate_p.scad>;
include <bezier_curve.scad>;
include <rounded_extrude.scad>;
$fn = 36;
radius = 10;
leng = 40;
t_step = 0.1;
tangent_angle = 40;
module two_connected_circles(radius, dist, tangent_angle, t_step) {
half_dist = dist / 2;
p1 = rotate_p([0, -radius], tangent_angle) + [-half_dist, 0];
p2 = rotate_p([radius * tan(tangent_angle), -radius], tangent_angle) +
[-half_dist, 0];
p3 = [-p1[0], p1[1]];
p4 = [-p2[0], p2[1]];
curve_pts = bezier_curve(t_step, [p1, p2, p4, p3]);
leng_pts = len(curve_pts);
upper_curve_pts =
for(i = [0:leng_pts - 1])
curve_pts[leng_pts - i - 1]
lower_curve_pts =
for(pt = curve_pts)
[pt[0], -pt[1]]
translate([-half_dist, 0])
circle(radius);
translate([half_dist, 0])
circle(radius);
polygon(
concat(
upper_curve_pts,
lower_curve_pts
radius, leng, tangent_angle, t_step
http://forum.openscad.org/file/n21633/two_connected_circles.jpg
After that, I created a tri_connected_circles module:
module tri_connected_circles(radius, leng, tangent_angle, t_step) {
angle = 60;
half_leng = leng / 2;
module two_circles() {
two_connected_circles(radius, leng, tangent_angle, t_step, round_r);
translate([0, -half_leng * tan(30), 0]) union() {
two_circles();
translate([-half_leng, 0, 0])
rotate(angle)
translate([half_leng, 0, 0])
two_circles();
rotate(-angle)
two_circles();
tri_connected_circles(radius, leng, tangent_angle, t_step);
http://forum.openscad.org/file/n21633/tri_connected_circles.jpg
Then, I can rounded it by the following code:
round_r = 3;
rounded_extrude([leng + 2 * radius, leng * tan(60) + 2 * radius], round_r,
180)
circle(radius * 1.5);
http://forum.openscad.org/file/n21633/rounded_connected_circles.jpg
The complete code:
$fn = 36;
radius = 10;
leng = 40;
t_step = 0.1;
tangent_angle = 40;
round_r = 3;
[-half_dist, 0];
upper_curve_pts =
lower_curve_pts =
for(pt = curve_pts)
[pt[0], -pt[1]]
circle(radius);
circle(radius);
polygon(
concat(
upper_curve_pts,
lower_curve_pts
angle = 60;
two_circles();
rotate(angle)
two_circles();
rotate(-angle)
two_circles();
180)
You can find include rotate_p.scad, bezier_curve.scad, rounded_extrude.scad
here:
https://justinsdk.github.io/dotSCAD/
View this message in context: http://forum.openscad.org/Rounding-convex-edges-without-minkowski-tp21621p21633.html
You are right. Here they are:
module torus(R,r) rotate_extrude() translate([R,0,0]) circle(r);
module filled_torus(R,r) { torus(R,r); cylinder(r=R,h=2*r, center=true); }
2017-06-02 19:20 GMT-03:00 Neon22 mschafer@wireframe.biz:
I added a shape_glued2circles function into my library
https://justinsdk.github.io/dotSCAD/ . Now, we can simplify the code:
include <shape_pie.scad>;
include <shape_glued2circles.scad>;
$fn = 48;
radius = 10;
leng = 40;
tangent_angle = 40;
round_r = 3;
module tri_connected_circles(radius, leng, tangent_angle) {
angle = 60;
polygon(
shape_glued2circles(radius, leng, tangent_angle = tangent_angle)
two_circles();
rotate(angle)
two_circles();
rotate(-angle)
two_circles();
180)
tri_connected_circles(radius, leng, tangent_angle);
View this message in context: http://forum.openscad.org/Rounding-convex-edges-without-minkowski-tp21621p21636.html
here a nice and simple constructor:
offset(-15) offset(12) forN(r=26, N=3) circle(20);
module forN(r, N) for(i=[0:N-1]) rotate([0,0,i*360/N]) translate([r, 0,
0]) children();
WITH minkowski the code for the fidget is quite straight forward. 4 minute
render time is not at all bad.
$fn=40; // use 10 for experiments, 40 for finals (4min)
fidget(22,7); // call with bearing diameter and height in mm
module fidget(d, h)
r=d/2;
r3 = r/3;
r8 = r38;
minkowski()
linear_extrude(height = .01, convexity = 4)
offset(-r34-h/2) offset(r34) forN(r8, 3) circle(r35);
sphere(h/2);
forN(r8, 3) cylinder(r=r, h=r, center=true);
0]) children();
View this message in context: http://forum.openscad.org/Rounding-convex-edges-without-minkowski-tp21621p21638.html
Very clever use of offset that avoids the Apollonius circle computation.
However, except for the generation of the profile, your code is essentially
the same as the original spinner_solid and the running time should be about
the same.
2017-06-04 20:19 GMT-03:00 Parkinbot rudolf@parkinbot.com:
module fidget(d, h)
r=d/2;
r3 = r/3;
r8 = r38;
minkowski()
sphere(h/2);
0]) children();
If you use the constructor with a circle you can even omit the first offset
and enlarge the circle radius of course.
offset(-r34-h/2) forN(r8, 3) circle(r39);
What a pity that we don't get hands on the coordinates ...
View this message in context: http://forum.openscad.org/Rounding-convex-edges-without-minkowski-tp21621p21641.html
I've started creating lots of objects with functions that return points
(some my own, some using shapes and transform from SCAD utils) for
exactly this reason, and because I get rounding almost for free.
For instance, this function gives me the points for a rounded rectangle,
and I call it from a RoundedBox function (1) that uses similar loops to
round in the other dimensions. Throw the points into Skin () and the job
is done.
function RoundedRect (xsize=10, ysize=10, r=1, fa=$fa) = [
let (xo=(xsize/2)-r,yo=(ysize/2)-r)
for (a = [0: fa : 360-1]) [cos(a)*r + xo * sign(cos(a)), sin(a)*r +
yo * sign(sin(a))]
(1) - I'd supply the code but I haven't made generic yet and just have
one for my rather special case.
For the same reason, I also created several 2D shapes in my library :)
View this message in context: http://forum.openscad.org/Rounding-convex-edges-without-minkowski-tp21621p21643.html
