AC
A. Craig West
Thu, Apr 22, 2021 9:47 PM
On 4/22/2021 11:42 AM, Ray West wrote:
The following is much easier to write, it complies with 2.5 d thinking,
and the the concept would work on polygons, or other 2d shapes. It is all
constructed from 2d and extruding, but There is no straightforward way to
convert it to a dxf file within openscad, afaik.
module xyz(x,y,z){
linear_extrude(-z)
translate([x,y])children();
I think you have the signs wrong; you negate Z here but then you supply
negative values below so the result is positive.
I'm going to assume that you only intended one negation; you want to drill
holes down from the Z=0 plane.
So why doesn't this do what you want?
module xyz(x,y,z){
mirror([0,0,1]) linear_extrude(-z)
intersection(){
xyz(0,0,-50)square(200,true); // work piece
// pockets
xyz(0,-30,-50)circle(20);
xyz(0,0,-50)circle(15);
xyz(20,0,-30)circle(20);
xyz(0,0,-20)square([100,50],true);
//island
xyz(0,60,-20)square(40,true);
xyz(0,60,-20)circle(10);
// profile (intersection with object)
xyz(0,0,-49)square(195,true);
On 22/04/2021 13:14, Ray West wrote:
On 21/04/2021 23:29, Jordan Brown wrote:
What would linear-extruding down do that's different from mirroring?
The only thing I can think of offhand is that maybe the direction of the
twist would be reversed - and of course a relatively simple wrapper could
do that.
The following code may explain the overall awkwardness of my efforts
translate([400,0]){
linear_extrude(30)square(250,true);
linear_extrude(20)circle (100);
linear_extrude(50)circle(50);
linear_extrude(50)translate ([0,80]) square(25,true);
linear_extrude(50)translate ([80,0]) circle(20);
// 2d conversion.
square(250,true); //block 250square by 30
circle (100); // bore 20 deep
circle(50); // bore right through
translate ([0,80]) square(25,true); //bore right through
translate ([80,0]) circle(20); //bore right through
The first block of code shows the shape of the object (It is not too
difficult to draw it upside down). the linear_extrude values are the depths
of the pockets/profiles (-z values). To convert it back to 2d for exporting
as dxf, requires differencing some items. On this simple made up example,
it is not much of a problem, but it certainly would be for a more complex
item. (move the small square to [0,90], say. I would like to be able to
produce the 2d drawing (my initial starting point) without fussing with
differences, etc, and simply add some linear-extrudes with depths, to get a
quick look at the solid object.
The starting point would be from the 2d dimensions, a hand drawn sketch,
say.
You will want a higher convexity on that
On Thu, 22 Apr 2021, 17:29 Jordan Brown, <openscad@jordan.maileater.net>
> module xyz(x,y,z){
> linear_extrude(-z)
> module xyz(x,y,z){
> intersection(){
> difference(){
> // pockets
> //island
> difference(){
> do that.
> translate([400,0]){
> difference(){
> // 2d conversion.
> difference(){
> say.
Ray West
Sun, Apr 25, 2021 11:57 AM
On 21/04/2021 18:16, A. Craig West wrote:
Openscad is an amazingly flexible tool, but I do find that it is
overly limited by the assumption that 3d printers are the only
possible use case. I find that the language is great for expressing
geometry in 2d as well, but due to the assumption that all generated
objects must have thickness/volume, you can't actually use it for
things like laser cutting...
I think that is the major problem. However in my quest to overcome that,
in examining what I need for 2.5d 3 axis milling, I've decided to use
'projection', slicing the 3d model at various levels. However, the
levels required for slicing, are not the depths required for machining.
I was translating in x/y each projection and saving it as a single dxf
file, then realigning them in my 2d drawing package, going around the
houses to get back to where i started, so to speak.
I'm wondering if there is a more automated method, whereby each
individual projection could be saved as a dxf, (without translating them
in x/y plane) then I could simply import them into the same drawing in
my 2d drawing package, without having to realign them. I'm thinking it
may require a separate program to parse the scad file, identify the
commented out projections, uncomment them one by one, running openscad
via command line for each projection, and saving as a uniquely named
dxf. . A bit convoluted, but doable. I could also include other
information, too, tool type, for example. I'm not sure if it is worth
the effort, I see it more as a journey, rather than the destination. At
the ed of the day, there is still a fair bit of manual adjustments that
need to be made, in getting from a simple drawing to final object, it is
not the same as profile milling an stl file.
//for dxf drawing
//projection(cut=true) translate([0,0,100])first_op(); // z- 100 T15
//projection(cut=true) translate([0,0,90.1])first_op(); // stand off
T15 z-95
//projection(cut=true) translate([0,0,40])first_op(); // square T15 z-90
//projection(cut=true) translate([0,0,24.9])first_op(); // notch T15 z-25
//projection(cut=true) translate([0,0,.1])first_op(); // lip T21 z-10
//for dxf drawing
T15 z-95
WF
William F. Adams
Sun, Apr 25, 2021 1:46 PM
Yes, iterating on DXF exports is one option --- it's a bit tedious though --- I find the most expedient thing to do is to use an if/then in a module and to surround the various geometries needed with consistently offset and sized rectangles which can all be in one DXF and which can then be imported in a single operation and composited in the CAM tool.
Does DXF have better support for this sort of thing in the 3D extensions I've read about?
Does DXF support layers? If so, could projection() be modified to take an argument of which Z height each operation was for, and then each projection() command could go an a separate layer?
Or, why not just allow exporting of arbitrary text files in the course of running a file? TeX allows one to define and set up multiple outputs and open/write to/close files (it also allows reading files which would be handy).
Writing out files might even allow hand-coding a DXF as part of a 3D model, no projection() necessary, or it could allow adding support for arbitrary CAD/CAM formats such as the JSON-based .c2d file format used by the freely available Carbide Create (yes, I work for the company).
Or, it could allow one to directly write out G-Code allowing one to cut (and possibly 3D print) geometries which no other CAM tool would allow.
Mon, Apr 26, 2021 3:22 AM
them in x/y plane) then I could simply import them into the same
drawing in my 2d drawing package, without having to realign them. I'm
thinking it may require a separate program to parse the scad file,
identify the commented out projections, uncomment them one by one,
running openscad via command line for each projection, and saving as
a uniquely named dxf. . A bit convoluted, but doable. I could also
include other information, too, tool type, for example. I'm not sure
if it is worth the effort, I see it more as a journey, rather than the
destination. At the ed of the day, there is still a fair bit of manual
adjustments that need to be made, in getting from a simple drawing to
final object, it is not the same as profile milling an stl file.
You don't want to externally parse the .scad file. That could be a
nightmare. But you don't need to. OpenSCAD knows how to parse them,
and it'll do it right. You just need to use OpenSCAD to derive the
list, and then to select the desired layer.
//for dxf drawing
T15 z-95
Something like so:
// Display/operation mode
mode = "3d"; // [ 3d, all, one, list ]
// Which layer to select if mode="one"
layer = 0; // [0:0.1:200]
// List of layers
layers = [ 100, 90.1, 40, 24.9, 0.1 ];
if (mode=="3d") {
first_op();
} else if (mode == "list") {
for (z = layers) {
echo("LAYER", z);
} else if (mode == "all") {
for (z = layers) {
translate([0,0,z])
translate([0,0,-z])
first_op();
} else if (mode == "one") {
projection(cut=true) translate([0,0,-layer]) first_op();
You write an external script that runs openscad with -Dmode="list"
(which, if you're in a UNIX shell, would be something like
-Dmode="list"). You have the script collect the output, looking for
lines that look like
ECHO: "LAYER", 100
and stripping off everything before the comma and space. Your then have
it repeatedly execute openscad with -Dmode="one" -Dlayer=N, where N is
the successive layer values, having it generate a DXF file.
Congratulations, you now have your N DXF files.
Note that it's rigged to let you use the Customizer to play with the
options manually.
> //for dxf drawing
> T15 z-95
Something like so:
// List of layers
if (mode=="3d") {
first_op();
for (z = layers) {
echo("LAYER", z);
for (z = layers) {
translate([0,0,z])
translate([0,0,-z])
first_op();
-Dmode=\"list\"). You have the script collect the output, looking for
ECHO: "LAYER", 100
options manually.
lar3ry
Mon, Apr 26, 2021 3:47 AM
I'm probably missing something, but wouldn't it be easier to run an STL or
3MF though a slicer and then write an external program to parse the GCode
layer by layer?
layer by layer?
Mon, Apr 26, 2021 6:05 AM
STL or 3MF though a slicer and then write an external program to parse
the GCode layer by layer?
GCode is a toolpath, and your CAM pipeline is going to want something
more like a line drawing. You'd have to figure out that those hundreds
or thousands of tool movements total up to a a 2D shape, that the CAM
pipeline can then turn into its own totally different toolpaths.
lar3ry
Mon, Apr 26, 2021 10:58 AM
OK, so what about something like a slicer designed for MSLA 3D printing?
Perhaps something like Chitubox? It's binary and not open source, but are
there other, similar programs that give you a layer by layer representation
that would be easier to parse than an STL?
Gene Heskett
Mon, Apr 26, 2021 1:43 PM
parse the GCode layer by layer?
something more like a line drawing. You'd have to figure out that
those hundreds or thousands of tool movements total up to a a 2D
shape, that the CAM pipeline can then turn into its own totally
printing? Perhaps something like Chitubox? It's binary and not open
source, but are there other, similar programs that give you a layer by
layer representation that would be easier to parse than an STL?
Sure. I slice with cura, which has a preview mode where you can watch it
build your project or take it apart if you pull the slider backwards,
or an enterprising bash author could knock out a script that could split
the resulting gcode up into layer by layer files if you need that level
of granularity. But tall projects will generate hundreds of files doing
that.
Cheers, Gene Heskett
-Ed Howdershelt (Author)
that.
- Louis D. Brandeis
Ray West
Mon, Apr 26, 2021 2:27 PM
Something like a slicer would work, after all that is what
projection(cut=true) does. If i sliced it in Cura, say, then I can get
the gcode for a specific layer height, but it would need parsing a large
file of possibly thousands of layers to get the four or five usually
needed. The Cura g-code is for laying down the path for a filament of a
finite width. I would need the outline of the final printed path,
including the width of the layer as a dxf file. The Cura gcode would
need a lot of maths applied to get back to the outline of the object,
convert it to dxf or hpgl format or if going straight to cnc machinable
g-code would need to add the tool offsets, which may not be known at
this stage.
I can directly machine stl files anyway, more or less automatically, but
although that process is maybe good enough for wood, or ornamental work,
there is generally not precise enough control of the cutter paths and
speeds for what I need. I possibly have an irrational mistrust of stl
format for precision work.
hundreds
are there other, similar programs that give you a layer by layer
this stage.
> parse
> hundreds
> Sent from the OpenSCAD mailing list archive
> <http://forum.openscad.org/> at Nabble.com.
