I wouldn't expect it to work unless you used $generatecode or the module
was included instead of used.
On Thu, 21 Sept 2023 at 04:58, William F. Adams via Discuss <
To: "discuss@lists.openscad.org" discuss@lists.openscad.org
Cc:
Bcc:
Date: Thu, 21 Sep 2023 03:57:39 +0000 (UTC)
Subject: [OpenSCAD] Should it be possible to reference a variable inside a
module when the module is loaded by use?
Say I have a file with the lines:
use <pygcodepreview.scad>;
generategcode = true;
a = 300;
gcomment(str(a));
and pygcodepreview.scad is loaded from a library directory and contains:
module gcomment(comment) {
if (generategcode == true) {
echo("(",comment,")");
Should that work? If it should, why do I get the error:
Documents/OpenSCAD/libraries/pygcodepreview.scad, line 4
WARNING: Ignoring unknown variable 'generategcode' in file
../Documents/OpenSCAD/libraries/pygcodepreview.scad, line 8
I thought I had used such constructs in the past?
Did something change? Or am I getting this wrong somehow?
(I'm using the nightly build:
https://files.openscad.org/snapshots/OpenSCAD-2023.09.10-x86-64-Installer.exe
From: "William F. Adams via Discuss" discuss@lists.openscad.org
Cc: "William F. Adams" willadams@aol.com
Bcc:
On Thursday, September 21, 2023 at 04:11:24 AM EDT, nop head nop.head@gmail.com wrote:
I wouldn't expect it to work unless you used $generatecode or the module was included instead of used.
That latter was it --- was using include, not use.
Thanks!
