Good morning,
Long time lurker, first time poster.
I'm trying to create a case for a PCB. I have the PCB as an STL, and I'm
using projection and hull to create an outline as a basis for the case,
like so:
case_internal_offset = 2;
case_wall_thickness = 5;
offset(r = case_internal_offset + case_wall_thickness )
projection(cut = true)
import("pcb.stl");
offset(r = case_internal_offset )
import("pcb.stl");
It looks like projection is computationally intensive, so I would like to
perform the projection computation only once, and reuse the results of it
several times.
Or is OpenSCAD already doing this for me, and I need to find some other way
to speed things up? (such as saving the results of the projection as a DXF)
Thanks,
Matthias.
OpenSCAD caches it, assuming it has enough memory. You may want to increase the two CGAL cache sizes in Preferences/Advanced.
One way to force it is to use render() before the projection().
And it is clearer in code if you stick that in a module and call it twice, it indicates it is identical code.
Sent: Sat, 24 Jul 2021 08:57
Subject: [OpenSCAD] Reusing intermediary shapes to reduce computation
Good morning,
I'm trying to create a case for a PCB. I have the PCB as an STL, and I'm using projection and hull to create an outline as a basis for the case, like so:
import("pcb.stl");
import("pcb.stl");
It looks like projection is computationally intensive, so I would like to perform the projection computation only once, and reuse the results of it several times.
Or is OpenSCAD already doing this for me, and I need to find some other way to speed things up? (such as saving the results of the projection as a DXF)
Thanks,
Matthias.
