Newline changed in .scad files between 2014-11-09 and 2014-12-04?
S
Scalpel78
Tue, Dec 9, 2014 5:39 PM
have a piece of code that is crashing my Windows machine (not just the
OpenSCAD application, but the entire machine), and during troubleshooting I
noticed that the fileformat seems to have changed between the previous
version (2014-11-09) and the one I'm running now (2014-12-04).
When opening the .scad file in Notepad++ all the lines have an empty line
between them. So a four line long script ends up as eight lines. The lines
seems to have both a CR and a CRLF, which ends up as double the amount of
lines.
All the .scad files I created in the previous version only use CRLF as EOL
characters.
View this message in context: http://forum.openscad.org/Newline-changed-in-scad-files-between-2014-11-09-and-2014-12-04-tp10451.html
Hi, have a piece of code that is crashing my Windows machine (not just the OpenSCAD application, but the entire machine), and during troubleshooting I noticed that the fileformat seems to have changed between the previous version (2014-11-09) and the one I'm running now (2014-12-04). When opening the .scad file in Notepad++ all the lines have an empty line between them. So a four line long script ends up as eight lines. The lines seems to have both a CR and a CRLF, which ends up as double the amount of lines. All the .scad files I created in the previous version only use CRLF as EOL characters. -- View this message in context: http://forum.openscad.org/Newline-changed-in-scad-files-between-2014-11-09-and-2014-12-04-tp10451.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Dec 9, 2014 10:53 PM
Are you saying
  1. a new file created in 2014.12.04, saved, opened in Notepad++, has the
    extra blank lines?
  2. a file created with 2014.11.09, saved, opened in Notepad++ have extra
    blank lines?
I use NP++, 1. does not have any extra blank lines, and View/Show-Symbal/All
just shows CRLF at EOL.
View this message in context: http://forum.openscad.org/Newline-changed-in-scad-files-between-2014-11-09-and-2014-12-04-tp10451p10458.html
Are you saying 1. a new file created in 2014.12.04, saved, opened in Notepad++, has the extra blank lines? 2. a file created with 2014.11.09, saved, opened in Notepad++ have extra blank lines? I use NP++, 1. does not have any extra blank lines, and View/Show-Symbal/All just shows CRLF at EOL. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Newline-changed-in-scad-files-between-2014-11-09-and-2014-12-04-tp10451p10458.html Sent from the OpenSCAD mailing list archive at Nabble.com.
S
Scalpel78
Tue, Dec 9, 2014 10:59 PM
Scenario 1 gives blank lines.
I'm on version 2014-12-04. If I create a new file in OpenSCAD, and open it
using Notepad++ it looks like this:
http://forum.openscad.org/file/n10459/crcrlf.png
If I open up a file I created using the older version it looks good in
Notepad++.
View this message in context: http://forum.openscad.org/Newline-changed-in-scad-files-between-2014-11-09-and-2014-12-04-tp10451p10459.html
Scenario 1 gives blank lines. I'm on version 2014-12-04. If I create a new file in OpenSCAD, and open it using Notepad++ it looks like this: <http://forum.openscad.org/file/n10459/crcrlf.png> If I open up a file I created using the older version it looks good in Notepad++. -- View this message in context: http://forum.openscad.org/Newline-changed-in-scad-files-between-2014-11-09-and-2014-12-04-tp10451p10459.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Dec 9, 2014 11:18 PM
Blink,Blink, light bulb finally lights...
I was using the Simple Editor, when I switched to Scintilla, I can reproduce
this.
I'll raise an issue.
View this message in context: http://forum.openscad.org/Newline-changed-in-scad-files-between-2014-11-09-and-2014-12-04-tp10451p10461.html
Blink,Blink, light bulb finally lights... I was using the Simple Editor, when I switched to Scintilla, I can reproduce this. I'll raise an issue. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Newline-changed-in-scad-files-between-2014-11-09-and-2014-12-04-tp10451p10461.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Dec 9, 2014 11:25 PM
Added to existing  issue 915
https://github.com/openscad/openscad/issues/915#issuecomment-66378005  .
View this message in context: http://forum.openscad.org/Newline-changed-in-scad-files-between-2014-11-09-and-2014-12-04-tp10451p10462.html
Added to existing issue 915 <https://github.com/openscad/openscad/issues/915#issuecomment-66378005> . ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Newline-changed-in-scad-files-between-2014-11-09-and-2014-12-04-tp10451p10462.html Sent from the OpenSCAD mailing list archive at Nabble.com.
S
Scalpel78
Wed, Dec 10, 2014 5:49 PM
Also, if I go back to version 2014-11-09, open up a file originally created
in 2014-12-04, and save it, the double lines go away.
View this message in context: http://forum.openscad.org/Newline-changed-in-scad-files-between-2014-11-09-and-2014-12-04-tp10451p10475.html
Also, if I go back to version 2014-11-09, open up a file originally created in 2014-12-04, and save it, the double lines go away. -- View this message in context: http://forum.openscad.org/Newline-changed-in-scad-files-between-2014-11-09-and-2014-12-04-tp10451p10475.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Dec 16, 2014 11:49 PM
Confirmed this too. Scintilla was doing it correctly, so something changed.
View this message in context: http://forum.openscad.org/Newline-changed-in-scad-files-between-2014-11-09-and-2014-12-04-tp10451p10574.html
Scalpel78 wrote > Also, if I go back to version 2014-11-09, open up a file originally > created in 2014-12-04, and save it, the double lines go away. Confirmed this too. Scintilla was doing it correctly, so something changed. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Newline-changed-in-scad-files-between-2014-11-09-and-2014-12-04-tp10451p10574.html Sent from the OpenSCAD mailing list archive at Nabble.com.
