On 3/12/26 10:19, Glenn Butcher via Discuss wrote:
Here's my use case:
When I build a large model, I'll construct parts and assemblies in individual openscad scripts, which get printed. I also make an integration script, which <use>s the part/assembly scripts to place them in their intended positions to render the complete model. I don't print this, but I've recently found it useful to give to other participants to plan work.
I have done similar like when designing a new hotend, I first build all
the parts and show them as assembled in the viewer. Then 1 var at the
top triggers a disassembly and repositions the parts on the build plate
and to bottom=0 for simultaneous printing of the whole thing. Fits my
mental work flow better. IWFM. ;<)>
I'm using o3dv to make a viewer website for them to do their regarding, would like to put a single 3mf file with all the individual meshes from the integration script in the viewer, where it has a mesh list and tools to toggle their visibility. So, the lazy- union export to 3mf behavior of one mesh for each individual render is needed. Giving the individual meshes descriptive names instead of "OpenSCAD Model #" would also be helpful.
Thanks,
Glenn Butcher
On March 12, 2026 12:51:33 AM MDT, Jordan Brown openscad@jordan.maileater.net wrote:
but i do want to point out that single- part 3d printing isn't the only CAD use case.
Of course. Lazy Union just isn’t likely to be the ultimate solution.
Cheers, Gene Heskett, CET.
- Louis D. Brandeis
> Here's my use case:
> Thanks,
> Glenn Butcher
> On March 12, 2026 12:51:33 AM MDT, Jordan Brown <openscad@jordan.maileater.net> wrote:
- Louis D. Brandeis
