I want to select between multiple different configurations and want to
understand how to do that in a functional language.
In an imperative language I would do:
model = 'A';
if (model == 'A') {
dim_a = 1;
dim_b = 2;
} else if (model == 'B') {
dim_a = 3;
dim_b = 4;
} else { // default configuration
dim_a = 5;
dim_b = 6;
I may have many configurations and variables for each one. This simple
example could be done with ? :, but that gets super messy as things get
more complex.
What's the best way to do this in OpenScad?
Dan
Hi Dan,
I see two practical approaches:
Approach 1:
If you don´t mind Development snapshoots, try our customizer.
You can get those snapshoots from http://www.openscad.org/downloads.html
You also have to go into the preferences and enable the customzier.
In the customizer you can handle your configurations as so called presets.
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/WIP#Customizer
Approach 2:
If you want to stay on the release line of openscad:
I would write a "base_model.scad" (or something like that), which is let
us say model default:
dim_a = 5;
dim_b = 6;
//lots of code that creates the actual model
For model b, I would create a file called "model_b.scad" and then simply
include <base_model.scad>;
dim_a = 1;
dim_b = 2;
dim_a = 3;
dim_b = 4;
The trick is, that the last assignment overwrites any previous
assignments to a variable.
Every model has then its own file.
Most of the code being in base_model.scad.
The other files only need to overwrite the variables.
Depending on what you really want/need, use might also be an option.
But when you use "use", you need a bit more code for each configuration.
see also
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Include_Statement
With Kind regards,
Michael Frey
Thanks!
Approach 2 should work for me.
Dan
On Thu, Sep 13, 2018 at 1:21 PM Michael Frey michael.frey@gmx.ch wrote:
Hi Dan,
Approach 1:
Approach 2:
dim_a = 5;
dim_b = 6;
dim_a = 1;
dim_b = 2;
dim_a = 3;
dim_b = 4;
The trick is, that the last assignment overwrites any previous assignments
to a variable.
see also
With Kind regards,
Michael Frey
Assign values to dim_a and dim_b separately.
Use the Ternary conditional operator - ?:
usage:
/condition expression/ ? /expression if true /: /expression if false/ ;
In this case one ternary operation is nested inside one other.
model = 'A';
dim_a = (model == 'A') ? 1:(model == 'B')?3:5;
dim_b = (model == 'A') ? 2:(model == 'B')?4:6;
// "let" dim_a= "if"(model == 'A')? "then" 1 : "else if"(model == 'B')?
"then" 3: "else" 5
If you have many parameters for each alternative model, it is a good idea to
collect them in a list for each model.
modelA = [ 1, // dim_a
2, // dim_b
[1,2] // vec_a // some vector parameter
modelB = [ 3, // dim_a
4, // dim_b
[2,3] // vec_a
modelC = [ 5, // dim_a
6, // dim_b
[3,4] // vec_a
Then, select the parameter set with just one :? operator
modelset = model=='A' ? modelA : model=='B' ? modelB : modelC;
and retrieve the parameters from modelset:
dim_a = modelset[0];
dim_b = modelset[1];
vec_a = modelset[2];
With a few changes, you will be able to add more parameters without touching
the selection operation.
If the selection key 'model' is an integer instead of a char, you can even
avoid the :? operator at all.
modellist = [modelA, modelB, modelC];
modelset = modellist[model];
The associative array
https://github.com/runsun/OpenSCAD_Tips/blob/master/snippets.md#hash *
might be an option:
models = [ "A", [ dim_a,1, dim_b, 2 ]
, "B", [ dim_a,3, dim_b, 4 ]
data = hash( models, "A");
dim_a = hash( data, "dim_a");
dim_b = hash( data, "dim_b");
2, // dim_b
4, // dim_b
[2,3] // vec_a
6, // dim_b
[3,4] // vec_a
That was what I was thinking, with a couple of additional notes...
I would try to align the definitions of model[ABC] into a table-like form:
// a b c
modelA = [ 1, 2, [1,2], ... ];
modelB = [ 3, 4, [2,3], ... ];
modelC = [ 5, 6, [3,4], ... ];
and if the number of variants is non-trivial, then do something similar
with the ?: sequence:
modelset =
model == 'A' ? modelA :
model == 'B' ? modelB :
modelC
... though better would be to have the final "else" generate an error,
so that a typo doesn't silently give you the default. I don't happen to
remember any good ways to do that, and don't have the time right now to
look.
