Re: [OpenSCAD] ranges to vectors
V
vicnet
Wed, Nov 11, 2015 1:37 PM
Hello,
Something missing also is to use range for indexes, like in python.
Example:  v=[0,1,2,3]; v[0:1] should return a vector with 2 fist elems.
Also, v[:2], v[1:], v[:-1]... should work !
a+
Vicnet
View this message in context: http://forum.openscad.org/ranges-to-vectors-tp7651p14368.html
Hello, Something missing also is to use range for indexes, like in python. Example: v=[0,1,2,3]; v[0:1] should return a vector with 2 fist elems. Also, v[:2], v[1:], v[:-1]... should work ! a+ Vicnet -- View this message in context: http://forum.openscad.org/ranges-to-vectors-tp7651p14368.html Sent from the OpenSCAD mailing list archive at Nabble.com.
runsun
Wed, Nov 11, 2015 7:02 PM
vicnet wrote
Hello,
a+
Vicnet
There's a similar discussion couple of months back:  Proposal for range (
[i:j:k] ) improvement
http://forum.openscad.org/Proposal-for-range-i-j-k-improvement-td13184.html
$  Runsun Pan, PhD
$ libs: doctest , faces ( git ), offline doc ( git ),runscad.py( 1 , 2 , git );
View this message in context: http://forum.openscad.org/ranges-to-vectors-tp7651p14374.html
vicnet wrote > Hello, > > Something missing also is to use range for indexes, like in python. > > Example: v=[0,1,2,3]; v[0:1] should return a vector with 2 fist elems. > Also, v[:2], v[1:], v[:-1]... should work ! > > a+ > Vicnet There's a similar discussion couple of months back: Proposal for range ( [i:j:k] ) improvement <http://forum.openscad.org/Proposal-for-range-i-j-k-improvement-td13184.html> . ----- $ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ),runscad.py( 1 , 2 , git ); $ tips: hash( 1 , 2 ), sweep , var , lerp , animGif -- View this message in context: http://forum.openscad.org/ranges-to-vectors-tp7651p14374.html Sent from the OpenSCAD mailing list archive at Nabble.com.
