This is probably more an FYI than anything, but when I started working on
the builtin_time function, I ran some timing tests. I had several
nurb_length runs that were running in roughly half a second, and the same
code run in v2025.02.10 is now taking 10x as long. I'll probably start off
with a previous version and see if I can figure out when this happened. If
anyone has an idea of what might be up, please let me know.
EBo --
We did upgrade the 2D subsystem to Clipper2 December 19th: https://github.com/openscad/openscad/pull/5501. It’s possible that there are performance regressions related to 2D operations. If you could test with immediately before and immediately after that, it could give us an idea.
If you find a regression, please share a small but representative example. Opening a GitHub issue is a good steÎp forward in that case.
On Feb 10, 2025, at 17:31, John David via Discuss discuss@lists.openscad.org wrote:
This is probably more an FYI than anything, but when I started working on the builtin_time function, I ran some timing tests. I had several nurb_length runs that were running in roughly half a second, and the same code run in v2025.02.10 is now taking 10x as long. I'll probably start off with a previous version and see if I can figure out when this happened. If anyone has an idea of what might be up, please let me know.
EBo --
Marius,
I'll give this a quick try... <crumbunny> somehow I hosed one of my
libraries bouncing around and I hosed git. I'll have to drop playing with
this until I get my system back in running order.
idea.
On Feb 10, 2025, at 17:31, John David via Discuss <
