Todd
Sat, Apr 25, 2020 4:49 AM
I'd like to start using openscad to generate drawings I can use in my (tiny) machine shop. This would be basic stuff like isometric and orthographic views with dimension lines and dimensions, exploded orthographic views, etc. I'm using SolidyPython as my abstraction layer as this gives me ton's of functionality from the Python3 ecosystem. SolidPython also has support for holes and BOM generation via the @bom_part annotation.
So, to summarize, what facilities does openscad have for generating dimensioned isometric and orthograhic views?
-Todd
-Todd
KT
Kevin Toppenberg
Sun, Apr 26, 2020 1:53 AM
Short answer, is that OpenSCAD is not very good at this.
Long answer is that there are libraries one can use to put in dimension
lines -- i.e. lines that appear to be part of the 3D object you are
creating. The lines hang in space etc.
Many, including me, have asked for this feature. But I think that
OpenSCAD's approach makes automatic dimension lines hard. FreeCAD starts
with a 2D sketch, so it makes sense for dimension lines to be printable
from that. But imagine creating a loop that generates a start-burst shape
in OpenSCAD. How is the program going to know how to make dimension lines
for that?
Kevin
annotation.
-Todd
for that?
Kevin
On Sat, Apr 25, 2020 at 12:50 AM Todd <toddg@zwrob.com> wrote:
> Hi,
> annotation.
> -Todd
Rob Ward
Sun, Apr 26, 2020 3:39 AM
I would be happy with scaled orthographic views with surfaces collapsed
into 2D as an .svg (not a 2D outline of a slice which is what it can do
now). Colour would be nice, as in F5 Preview. If it can render it on the
GUI, how come it can't export that, and to a scale?
Cheers, Rob
dimension lines -- i.e. lines that appear to be part of the 3D object
you are creating. The lines hang in space etc.
starts with a 2D sketch, so it makes sense for dimension lines to be
printable from that. But imagine creating a loop that generates a
start-burst shape in OpenSCAD. How is the program going to know how
to make dimension lines for that?
Kevin
-Todd
Cheers, Rob
> Kevin
> <mailto:toddg@zwrob.com>> wrote:
> Hi,
> -Todd
Sun, Apr 26, 2020 8:39 AM
You can export colored previews as PNG. Since you can specify the canvas
size and camera position it should be possible to achieve a specified scale
with some trig.
Cheers, Rob
for that?
Kevin
annotation.
-Todd
with some trig.
> Cheers, Rob
> for that?
> Kevin
>> Hi,
>> annotation.
>> -Todd
> OpenSCAD mailing listDiscuss@lists.openscad.orghttp://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Rob Ward
Sun, Apr 26, 2020 11:50 AM
That is an option, but is not what I was after. SVG can preserve dimension accuracy and is a far better format than bit mapped images for scaling purposes. I could just do screen grabs if I wanted something like that. Not to sound disparaging, I have gratefully used them in many useful publications, and they are very handy
However if I was adding dimensions etc like the original post in this thread requested, I would much rather be working in Inkscape than GIMP, with the possibility of layers etc
Could not the graphic be produced at the very end of an F5, when the data structures would be available for interrogation In a stable state?
I think it could be feasible, unlike more unrealistic requests for OpenSCAD extensions that are click and drag on the GUI that are supposed to be mapped back to parts of the code far removed from any simple 1:1 co-ordinate geometry. Eg spiralling transformations from within a for-next loop.
I have programmed a lot of things in my time, but nothing like Open SCAD (complicated GUI+amazing maths) so I am happy to apologise, if my crude understanding offends anyone.
Cheers, RobW
canvas
scale
with some trig.
Cheers, Rob
for that?
Kevin
annotation.
-Todd
Cheers, RobW
>canvas
>scale
>with some trig.
>collapsed
>do
>the
>> Cheers, Rob
>dimension
>starts
>printable
>shape
>lines
>> for that?
>> Kevin
>>> Hi,
>my
>layer as
>@bom_part
>>> annotation.
>>> -Todd
>> OpenSCAD mailing
Sun, Apr 26, 2020 11:58 AM
No because F5 does not calculate geometry, it draws pixels. F6 calculates
geometry but does not handle colour.
If you make the canvas the same size as your printer it would make no
difference if it was vectors or pixels as printers are not vector
output devices but I don't know if a canvas that big is practical with
OpenSCAD.
loop.
Cheers, RobW
with some trig.
Cheers, Rob
for that?
Kevin
annotation.
-Todd
OpenSCAD.
> loop.
> Cheers, RobW
>> with some trig.
>>> Cheers, Rob
>>> for that?
>>> Kevin
>>>> Hi,
>>>> annotation.
>>>> -Todd
