AFAIK, rotate([a,b,c]) is equivalent to:
rotate([0,0,c]) rotate([0,b,0]) rotate([a,0,0])
which is opposed to the usual Euler angle order. However, the angles
expected by $vpr assignments are taken in the inverse order: first Z, last
X.
I wrote a function to calculate the Euler angles of a viewport frame in
order to feed $vpr. But I cannot use it with rotate(). I would expect the
same rule in both.
View this message in context: http://forum.openscad.org/Why-rotate-and-vpr-use-opposed-rotation-orders-tp18092.html
same rule in both.
Say hello to legacy issues...
https://github.com/openscad/openscad/blob/master/src/Camera.cc#L41
$vpr use Euler angle rotation order. The issue is the rotate() order.
Another legacy?
2016-08-08 18:19 GMT-03:00 Torsten Paul Torsten.Paul@gmx.de:
same rule in both.
It is easy to do your own e_rotare() module.
View this message in context: http://forum.openscad.org/Why-rotate-and-vpr-use-opposed-rotation-orders-tp18092p18095.html
